Shifting hard
Discussion in '3rd Gen Tundras (2022+)' started by Jthawks, Feb 11, 2024.
  1. Feb 11, 2024 at 10:15 AM
    Jthawks
    Jthawks [OP] New Member
    Jeff
    2022 tundra limited silver trdoffroad
    So I unplugged my battery so I can get the check engine light and the parking emergency braking off.
    I had debris fly up hit my grill and broke my grill shutters, so I replaced the grill and grill shutters, the grill shutters warning went away but still had check engine light on. Anyways, unplugging the battery got rid of tiny lights, now as I'm driving its shifting hard into second gear, does unplugging the battery delete and software updates? I would assume no. I do know that the transmission will relearn my driving habits but I never had it shift hard.
    Any advice will be great.
    Thanks
  2. Feb 11, 2024 at 10:43 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    So unfortunately our trucks are like driving a computer. They are so advanced trust me I’ve had my share of problems over the last 23 years of owning Tundras that it’s best to have the dealer run diagnostics check on it. The one thing I know is it is not always a good thing to disconnect the battery like we used to. I had some problems on my 22 and fortunately I have a friend who is a 30 year veteran of Toyota and he told me not to disconnect the battery.
    I have had some problems that were resolved by Toyota but I can tell you I have had a Toyota Engineer connect his laptop to my Tundra.
    Take your Tundra back to the dealership and let them see what’s going on. I get you want to fix it yourself, I’m the same way but unfortunately our trucks are computers on wheels.
  3. Feb 11, 2024 at 11:37 AM
    Jthawks
    Jeff
    Ya, my service guy said it should go off after a couple drives, when my grill shutters broke g there was no codes right away, it was 2 or 3 times of me starting the truck and driving for the codes to come up. I did 2 drives after I fixed the grill shutters and the that went away but check engine stayed on. I was probably inpatient. So you think my truck lost its software update?
  4. Feb 11, 2024 at 5:17 PM
    xc_tc
    xc_tc New Member
    Disconnecting the battery clear learning/adaptation on the engine and transmission computers. It’ll relearn after some time so the shifts will get smoother.
    EDIT: As a note, it doesn’t learn your “driving behavior”. The transmission learns the fluid characteristics of the ATF to smooth out the shifts.
    Jthawks[OP] likes this.
  5. Feb 11, 2024 at 5:26 PM
    Jthawks
    Jeff
    Thank you so much for that clarification. So I am going to wait it out. No reason to go see my dealer?
  6. Feb 11, 2024 at 7:58 PM
    xc_tc
    xc_tc New Member
    The dealer will probably say the same if you mention that the battery was disconnected.
  7. Feb 11, 2024 at 8:02 PM
    18" TRD Off Road Wheels
    If it's shifting hard, that's a reason to take it in. If it's under warranty, why in the world would you not get an issue addressed?
    Jthawks[QUOTED][OP] likes this.
  8. Feb 11, 2024 at 8:36 PM
    Jthawks
    Jeff
    I'm at 41k, I do have the extended warranty plus I believe doing those updates falls under the powertrain warranty. I messaged my service advisor in sure he'll get back to me tomorrow.
  9. Feb 11, 2024 at 8:39 PM
    Transmission would be under the powertrain warranty. Hard shifts may not have anything to do with the battery either. That's the big reason to get it in, rather than assuming or hoping that it's something simple or related to the battery.
    Fingers crossed it's something simple and quick for them to diagnose/fix!
  10. Feb 12, 2024 at 4:16 AM
    Jthawks
    Jeff
    Ya you're right. My service advisor has been great to work with so it won't hurt to bring it in.
