Traction control
Discussion in '3rd Gen Tundras (2022+)' started by matth66, Feb 11, 2024.
  1. Feb 11, 2024 at 12:57 PM
    matth66
    matth66 [OP] New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Just had the weirdest issue. When I press the traction control switch, it says traction control off, but the indicator light on my dash which is next to the fuel and temperature never comes on. Any of you guys have this issue?
  2. Feb 11, 2024 at 12:59 PM
    matth66
    matt
    Nor cal
    Here’s an image
  3. Feb 11, 2024 at 3:11 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Mattedfred and Jettster like this.
  4. Feb 11, 2024 at 5:07 PM
    matth66
    matt
    Nor cal
    right on man I really appreciate it. I guess I should’ve looked in the manual, but for some reason, I thought I pressed the switch, and the indicator came on on the dash. Guess I’m loosing it.
    pwpblue likes this.
  5. Feb 11, 2024 at 6:17 PM
    pwpblue
    Greensburg,PA
    All good, I'm still trying to figure out if I do or Do not have the alsd. OM just states optional when you press the TC button Alsd lights up if you have it??? Not sure if it's a off road thing or SR thing??
    I see the Pro does not have it either as you have a real locking diff.
  6. Feb 12, 2024 at 5:25 AM
    AJT_23
    AJT_23 New Member
    2011 RockWarrior, 2023 SR5 (sold)
    I believe I saw the alsd is only in the rwd trucks.
    pwpblue likes this.
  7. Jan 10, 2025 at 2:11 PM
    jtweezy
    jtweezy New Member
    Jeffrey
    I think I'm having this "issue" as well. Went to run some errands today and the truck started flickering the ABS light and VSC warning message on the MID (left side of the digital cluster). When I press the traction control button/toggle (car with the squiggly tread marks) I get a "Traction Control OFF" message on the MID, but no traction control (car with the squiggly tread marks) light on the cluster next to the transmission position indicator.
    I'm 80% sure I've hit this button before and the light comes on with the "Traction Control OFF" message.
