CATALYTIC CONVERTER SHIELD FITS 22+ TOYOTA TUNDRA
Discussion in '3rd Gen Tundras (2022+)' started by Caliraisedled, Dec 15, 2023.
  1. Dec 15, 2023 at 9:27 AM
    Caliraisedled
    Caliraisedled [OP] New Member Vendor
    Jake
    Welcome
    Cali Raised LED
    www.CaliRaisedled.com
    Phone: 888-385-5036 l Email: info@caliraisedled.com l Instagram: @cali_raised_led
    https://caliraisedled.com/collections/catalytic-converter-shield-fits-22-toyota-tundra
    Cali Raised LED's Catalytic Converter Shield is laser cut and CNC bent, made with American 12Gauge 304 brushed Stainless Steel. This product is one of the best ways to protect your catalytic converter. Our circular hole design on the product provides ample heat dissipation while maintaining high quality.
    The kit includes a passenger and driver-side cat guard with security hardware and tools. The best part of this cat guard is, that it is compatible with 99% of the skid plates on the market. It's a complete bolt-on product that requires no drilling, welding, or modification to your vehicle.
    FITS:
    • 22+ TOYOTA TUNDRA CREW MAX 4X4/2WD NON-HYBRID MODELS​
    • CREW CAB LONG BED 4X4/2WD NON-HYBRID MODELS​
    NOTE:
    • The Tundra shields will NOT work on the Hybrid models​
    Install Video
    https://youtu.be/47KUU6PiIl0
    Tartan1 likes this.
  2. Dec 15, 2023 at 9:51 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Even with it being a harder stainless steel I see those three little tabs as being pretty quick to zip off with a Sawzall or angle grinder. 12ga steel means its 0.1054 inches thick where as 1/8" thick would be 0.125. Its less than and 1/8", so that would only take a couple seconds. Would be much better if those tabs tied into the shield with more material to make cutting them off more difficult. In my opinion this would maybe provide a 50/50 chance that the thief takes the extra few seconds to just cut em off after they already slid under the truck. Maybe these are intended to be installed under a skid plate then? With them being stainless steel I see your saying they can be installed under 99% of skid plates, but if the stainless steel comes in contact against an aluminum skid plate the galvanic corrosion between the two dissimilar metals are going to eat each other when they are mixed with the heat of the cats and salt/dirt on the road. Might want to add a disclaimer to not install it under a aluminum skid plate. Great looking product, just think you need some tweaks to make them a little more robust against being cut off. Really like the amount of ventilation to keep the cats more cool.
  3. Jan 15, 2024 at 12:31 PM
    Caliraisedled
    Jake
  4. Jan 15, 2024 at 3:03 PM
    Vipers28
    Vipers28 New Member
    Are they still 3-4 weeks out?
  5. Jan 16, 2024 at 7:57 AM
    Caliraisedled
    Jake
    They are 4 weeks out. Please let us know if you have any more questions :thumbsup:
  6. Jan 16, 2024 at 10:14 AM
    manapiko
    manapiko New Member
    Patrick
    Soon to own 2023 TRD Pro
    Plans for a hybrid compatible model?
    Tundrastruck91 and Cova_84 like this.
  7. Jan 16, 2024 at 5:50 PM
    Cova_84
    Cova_84 New Member
    Stephen
    Southern California
    2024 Terra Tundra TRD Pro
    Nitto Recon Grappler LT295/70/17 Taco Vinyl Heritage front grill vinyl Tint 50% windshield 15% all other windows. BAKFlip MX4 Bed Cover
    I hope so . I’m fortunate enough to live by their shop. I purchased the covers and went to get them installed. After an hour or so I get back from a tasty breakfast across the street at the airport and one of the guys tells me that they’re not compatible with my TRD Pro. They refunded the purchase.
  8. Jan 17, 2024 at 12:53 PM
    manapiko
    manapiko New Member
    Patrick
    Damn, thats what I got. I'd like to use something like these instead of another big ol plate.
    Caliraisedled[OP] likes this.
  9. Jan 22, 2024 at 8:41 AM
    Caliraisedled
    Jake
    It is better to use our catalytic converter shields then a big plate haha. If you have any questions please reach out, we are here to help :)
  10. Jan 22, 2024 at 1:29 PM
    manapiko
    manapiko New Member
    Patrick
    I'd rather get two smaller plates to add to my truck than put another larger one on. thats all. Maybe some weight savings, maybe easier for oil changes with the pro skid plate. But ultimately seems like an easier option, once they have them for the hybrids.
    Tundrastruck91 likes this.
  11. Jan 24, 2024 at 9:11 AM
    Caliraisedled
    Jake
    With our design of the two piece cat shield, it does help provide better access to your maintenance:thumbsup: such as: transmission fluid & drive shaft & much more. It does help provide less weight and tucks close to the cats to ensure their fully enclosed.
  12. Jan 25, 2024 at 8:09 AM
    Caliraisedled
    Jake
    Thieves can not remove them, as ours have security bolts. Don't wake up with your cats missing, get them protected today! It's a complete bolt-on product that requires no drilling, welding, or modification to your vehicle. The best part of this cat guard is, that it is compatible with 99% of the skid plates on the market!
    Have you been a victim of cat theft or known someone that has been?
    Product link: https://caliraisedled.com/products/catalytic-converter-shield-fits-22-toyota-tundra
    https://www.instagram.com/reel/Cnxmd1koHUw/
  13. Jan 25, 2024 at 8:41 AM
    teab
    Ty
    Denver
    So these don't come in contact with 99% or the aluminium skid plates on the market then? If you want to see some funky corrosion put stainless steel and aluminium together with road salt and a heat source and you'll have a fun galvanic corrosion experiment under your truck. Hey if they don't come into contact with those then no problem. Might want to clarify that in your literature though if they do. Or just continue to ignore...
    Mattedfred likes this.
  14. Jan 25, 2024 at 4:29 PM
    manapiko
    manapiko New Member
    Patrick
    Exactly. So start making them for the hybrids! :thumbsup::D
  15. Jan 25, 2024 at 5:21 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    From what I can tell looking at these mounting locations, there should be no direct contact with the OEM aluminum TRD (pro) skid plate.
    EDIT: NVM... I just went outside to take another look and it appears they share the rear mounting location.
    teab[QUOTED] and Mattedfred like this.
  16. Jan 25, 2024 at 5:45 PM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    “Thieves can not remove them” is the nuttiest thing I’ve read all week. A thief could just unbolt it as quickly as it takes to install it with the same exact tools.
  17. Jan 26, 2024 at 8:58 AM
    Caliraisedled
    Jake
    So far with our skid plates and along with many other on the market we have confirmed that the skid plates do not touch each other, so there should be no issues with contact.
  18. Jan 26, 2024 at 9:01 AM
    Caliraisedled
    Jake
    We do provide a security key/nuts that does not allow the thief to easily remove them. At the end of the day if the thief has the exact tools he can take them off, but what are the odds of him having the exact security tool is little to none. If people do not feel that this helps they do not have to buy it, but we are very fortunate to hear that our shields have helped thousands of people already.
    Mr Rick likes this.
  19. Jan 26, 2024 at 12:01 PM
    teab
    Ty
    Denver
    Especially considering they are 4 weeks out to ship them. The math definitely checks out there!! I'm assuming they are referring to the Tacoma and 4runner shields and not specifically the Tundra.
    Mattedfred[QUOTED] likes this.
  20. Jan 26, 2024 at 12:20 PM
    teab
    Ty
    Denver
    The ultimate universal socket.... a Sawzall with a metal blade to take out the two mounting tabs and then bend the 12ga sheet metal out of the way leaving the single mounting point as the pivot point to bend. The thief already had the Sawzall in their hand when they slid under the truck, so might as well use it.
    Tom976 and Mattedfred like this.
  21. Jan 29, 2024 at 9:32 AM
    manapiko
    manapiko New Member
    Patrick
    Folks, somebody can flat bed the whole truck too, so why bother locking your doors? Its a mitigation tool, not a complete failsafe.
    shawn474, Mr Rick and Boomer08 like this.
  22. Jan 29, 2024 at 9:34 AM
    Caliraisedled
    Jake
    At the end of the day this is a deterrent, we are just saying how we have had great success from our costumers and they have not got their cats stolen with our protectors
    teab[QUOTED] likes this.
  23. Jan 29, 2024 at 10:05 AM
    teab
    Ty
    Denver
    If these were made with aluminum I might be more inclined to buy a set to put under my current aluminum skid/cat plate to act as a double deterrent if a thief got past the skid. When you have multiple products on the market some are more effective than others. Your cover is $269.00 (stainless is pricey as you know) and when you compare that to spending $265.00 at Talons Garage for a 10 gauge powder coated steel skid plate that accomplishes a slightly higher level of deterrence IMO with the added bonus of some protection for the transmission.... I know where I'm spending my money (would be $359 for aluminum). Thanks the reply and engaging with current and potential customers. One of these days you'll get some of my money when I buy a couple of the the other cool products you sell.
    Twin2turbo likes this.
  24. Jan 31, 2024 at 8:43 AM
    Caliraisedled
    Jake
    Of course & thanks we appreciate you thinking of use for your future purchases!
  25. Jan 31, 2024 at 2:00 PM
    Cova_84
    Cova_84 New Member
    Stephen
    Southern California
    Any updates on the hybrid version?
    Boomer08 and Caliraisedled[OP] like this.
  26. Feb 1, 2024 at 8:47 AM
    Caliraisedled
    Jake
    No updates on that as of now. We may make it in the future :thumbsup:, we will let you know if we ever do.
    manapiko and Tundrastruck91 like this.
  27. Feb 5, 2024 at 7:39 AM
    Caliraisedled
    Jake
    Product:
  28. Feb 9, 2024 at 7:02 AM
    Caliraisedled
    Jake
    According to @abc13houston a catalytic converter can be stolen in a matter of seconds. How crazy is that?!
    Product:
  29. Feb 11, 2024 at 11:04 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Check out Talons Garage.
    they have Catalytic Converter covers for Non-Hybrid & Hybrid Tundras.
  30. Feb 15, 2024 at 5:30 AM
    kramerv
    kramerv New Member
    Do these protect all four cats?
