  1. Feb 10, 2024 at 9:11 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    2 trucks. So you can haul parts from one in the other. The ultimate way would be to have identical matching trucks so you could fix the vin on one, and only have to have one insurance policy.
    NUDRAT, oscardog86, BroHon and 3 others like this.
  2. Feb 10, 2024 at 9:44 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Before and after quite a bit of elbow grease and rubbing compound ... but could use another round. Looks like volcanic crush thrown over snowy/icy roads embedded in the paint. Ideas on how to clean this out of matte black wheels more easily?
    Jack McCarthy and Voss like this.
  3. Feb 10, 2024 at 9:57 PM
    ToyotaDude
    ToyotaDude Member
    What year are you thinking? Got a 72 FJ40. Some years have more features saving some mods like adding Saginaw or discs.
    Voss[QUOTED] likes this.
  4. Feb 11, 2024 at 4:01 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  5. Feb 11, 2024 at 4:15 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    @metalpete I have an old Kenwood KDC-X599 Excelon and a Kenwood KDC-BT365U available. They were installed in my DC and my brothers Passat respectively. Worked when removed from either vehicle and replaced with touchscreen double din units, a Kenwood in my DC and an Alpine in the Passat.
  6. Feb 11, 2024 at 4:23 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Not messed up. Just the foam cushion on the door side of the driver seat was not up to par from 24 years of getting in and out. Also had a few small 1/4” or so tears in the fabric. The replacement one has a bit more girth to it. The seat frame and track assembly is still good. It would not be difficult to swap the seat cushion from one to another.
  7. Feb 11, 2024 at 5:36 AM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Don’t know enough about them to consider existing options but roughly the power train & Mall Crawler.
  8. Feb 11, 2024 at 6:30 AM
    Mother's Powerball, maybe?
  9. Feb 11, 2024 at 6:58 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Maybe an iron remover may help with that?
    I’d also try to see if I could get a dremel and attach a small brissle brush to the end Ann’s go to town with a degreaser or some other sort of cleansing agent.
  10. Feb 11, 2024 at 7:01 AM
    In truth, any buffing / polishing compound would suffice. It'd bring the shine back too.
  11. Feb 11, 2024 at 7:19 AM
    Main problem is those wheels are matte. Surface finish affects ability of wheels to stay clean. Matte finish is more porous and less resistant to dirt, grime and water. Glossier finishes are less porous and will resist getting dirty and clean up easier when they do. You could clean them up really well and hit em with some gloss to make them easier to clean in the future.
    Jack McCarthy and Hi06silver like this.
  12. Feb 11, 2024 at 7:44 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Iron remover then agitate see what ya get. It's hard to tell in the 2nd picture but it looks like the matte finish came off from polishing? at that point try to get the rest of the black off and polish to a satisfactory finish or recoat and then put a protective coating of some sort on to help preserve.
  13. Feb 11, 2024 at 7:49 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    Lesson learned. Not going back to that location again manager was a prick and flat out just trying to save his store rep and any bonus he may get Imo. Perfectly circular scratches after a balance.... Their insurance paid for it anyway.
  14. Feb 11, 2024 at 7:49 AM
    If your wheels get that bad during the winter it might be advantageous to get steelies and inexpensive tires to get you through the winter. Either that or drive another sacrificial vehicle if you have one.
    BroHon likes this.
  15. Feb 11, 2024 at 7:49 AM
    I'm not sure that I could have matched this any better. I'm going to do one more coat. Por-15 is a great product and the Rust-Oleum Truck Bed coating on top gets it done. I did two coats of primer on top of the POR.
    Does anyone think I'll regret this edge trim? If it traps dirt it could make the issue worse.
    oscardog86, txagg, BroHon and 4 others like this.
  16. Feb 11, 2024 at 7:52 AM
    I’ve got edge trim on my doors and they don’t last very long before they start to get gooey and come off. They’re good if you need to park on a non level surface and worry about your door hitting someone else’s and scraping it.
  17. Feb 11, 2024 at 7:55 AM
    Where are you planning on putting the edge trim?
    Also the trim I got/used has metal teeth impregnated and that’s what actually grabs onto the metal to hold
    my rear fenders at the bumper is starting to fall off, but it’s at a weird curve below the light, I should be able to just push it back up/on
  18. Feb 11, 2024 at 7:58 AM
    FishNinja
    Lee
    06DC2wd
    If you wanna get crazy you maybe even put a small bead of clear silicone sealant before putting that on. It’ll keep moister and dirt and shit out 100% wipe away any excess and it should t even look like it’s there.
    I use this on my kayaks for anywhere I drill holes and I’ve never had a leakIMG_4257.jpg
    oscardog86 likes this.
  19. Feb 11, 2024 at 8:03 AM
    Only the part where it rubs the fender. Still going to put something on top too. For the same reason.
  20. Feb 11, 2024 at 8:07 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Yep, that's me! I get a lot of flak for being a guy that still buys cds, but guess who's gonna have the tunes when shit goes full "Mad Max"?!
    @artsr2002 I appreciate it, sir, but those are basically what I just took out of my truck.
    This is more what I have. In fact, I wish this was on sale when I bought the other!
    https://www.onlinecarstereo.com/CarAudio/p_75490_Kenwood_DDX5707S.aspx
  21. Feb 11, 2024 at 8:14 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    It's better than nothing especially since it's not at the bottom where water can drain as well and pool up. If you can easily replace it would be good too!
  22. Feb 11, 2024 at 9:27 AM
    metalpete
    ID
    @The Black Mamba
    Was it you that said he needed a lock cylinder for your gas door? I had this backorder show up yesterday, well after I bought another.
    TX-TRD1stGEN and FrenchToasty like this.
  23. Feb 11, 2024 at 9:35 AM
    bfunke
    bfunke Tundra Curmudgeon
    Can those lock cylinders be ordered keyed to a specific key code? If not can they easily be re-keyed?
  24. Feb 11, 2024 at 10:18 AM
    I credit @KNABORES for this idea..
    Still working on fitment.
  25. Feb 11, 2024 at 10:19 AM
    metalpete
    ID
    That is a great question. I don't think so, since they send the keys with the cylinder, seems pretty specific.
    I have a separate key for my ignition, doors, and gas door lol.
  26. Feb 11, 2024 at 10:37 AM
    Pronto13
    Pronto13 New Member
    ‘06 white DC SR5 V8/4wd
    What did you use to get the old adhesive off? I’m having trouble with mine and this is what I’m left with currently
    oscardog86 and VR6T like this.
  27. Feb 11, 2024 at 10:46 AM
    Wd40, it may take a few applications of rubbing it in/off with a microfiber towel or something
    oscardog86, Jack McCarthy and shifty` like this.
  28. Feb 11, 2024 at 10:52 AM
    Eraserwheel works great, but don't by the generic ones on scAmazon. Otherwise, every LAPS carries sticker & label remover sprays, don't let it run in behind the trim, it's held on by adhesive too.
  29. Feb 11, 2024 at 11:00 AM
    The Black Mamba
    DFW
    Imma keep it stock
    I do. What I also done have is the clip for the back of the cylinder that attaches it to the door.
    Yes. The cylinder can be removed and the tumblers adjusted or even removed for a different key or even no key
    metalpete[QUOTED] likes this.
  30. Feb 11, 2024 at 11:02 AM
    Nice, think it was @Festerw that suggested the peel and stick tile if your going that direction.
    BroHon likes this.
