  1. Feb 10, 2024 at 5:30 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    @FrenchToasty how are the new gears treating you? What are the RPMs around 40, 70-90?
  2. Feb 10, 2024 at 5:32 PM
    Voss
    2003 AC TRD 4x4
    I don’t know much about a lot but just looking at all that rust says that may be an issue?
    metalpete likes this.
  3. Feb 10, 2024 at 5:42 PM
    I’m not sure on 40 or 90 but around 2500-2600 doing 65-70, took some getting used to being in that rpm range, but the power and get up is pretty awesome with minimal throttle input. It’s been a little rainy but not raining the last few mornings to work and it will spin the tire so much I have to get out of the throttle to hook up
  4. Feb 10, 2024 at 5:46 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Honestly I'm not sure what the code was anymore, it came on and off for a couple years even after new sensors all around. I thought the same about the exhaust gases but it's been like 6 months and it hasn't come back.
    Only thing they replaced was from the cats to the Y, had a pipe welded in place of the resonator and a new muffler about 4 years ago.
    BroHon[QUOTED] likes this.
  5. Feb 10, 2024 at 5:52 PM
    Which mod do you think made a bigger difference long tubes or gears?
  6. Feb 10, 2024 at 5:54 PM
    Voss
    2003 AC TRD 4x4
    txagg and FrenchToasty[QUOTED] like this.
  7. Feb 10, 2024 at 5:55 PM
    Voss
    2003 AC TRD 4x4
    I don’t have long tubes but I’d assume gears all the way.
  8. Feb 10, 2024 at 5:57 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I didn't do either :rofl:
  9. Feb 10, 2024 at 5:58 PM
    Yeah I’d say gears probably
  10. Feb 10, 2024 at 6:02 PM
    Voss
    2003 AC TRD 4x4
    I got them shorties which may be nothing but Ypipe, 12hole injectors, all the bells n whistles didn’t come close to gears after the 33’s were on. Best option for us commifornia folks at least.
  11. Feb 10, 2024 at 6:03 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Definitely an issue :rofl:, but one that has nothing to do with kicking my p0430. They are not leaking.... yet.
    The whole truck is Full of rust issues, I'm kind of just comforting her on her way to the crushero_O
    Got a peak at my frame today too.
    Pretty sure this spooge is the early treatment Toyota did to our frames (front boxed in rails)
    Mr.bee and Voss[QUOTED] like this.
  12. Feb 10, 2024 at 6:05 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Shocks. I dont have to slow down for speedbumps or potholes anymore.
    bmf4069, FishNinja, artsr2002 and 6 others like this.
  13. Feb 10, 2024 at 6:05 PM
    Damn that looks 100 times better than mine.
  14. Feb 10, 2024 at 6:06 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Gears
    whodatschrome, FrenchToasty and Voss like this.
  15. Feb 10, 2024 at 6:06 PM
    Voss
    2003 AC TRD 4x4
    Splatter some grease on it after sanding it down. She’ll be fine as PHM would say.
    Tho that spot where your CO2 sensor connects looks like it’s potentially leaking.
    The Black Mamba and txagg like this.
  16. Feb 10, 2024 at 6:07 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    dirty meme template.
  17. Feb 10, 2024 at 6:08 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Seriously jack?
    When it warms up that's getting vacuumed out, maybe scrapped a bit, and shot with my used 10w-30 with a garden sprayer lol
  18. Feb 10, 2024 at 6:09 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    yeah, I laid under there and didn't hear it though.
  19. Feb 10, 2024 at 6:10 PM
    @BroHon This is my before and after voltages for my O2 sensors when I did it on my truck at around 100k miles.
    before:
    after (all sensors replaced; downstream most obvious):
    BroHon likes this.
  20. Feb 10, 2024 at 6:11 PM
    I’ll post in the PM. I’m too embarrassed to post here. :oops:
    NUDRAT, txagg, shifty` and 1 other person like this.
  21. Feb 10, 2024 at 6:14 PM
    Voss
    2003 AC TRD 4x4
    Oh you won’t hear it. Had a similar issue once. Turned out to be the welding on flange of the Cat. Slightest leak and the sensor was going off. Was a brand new Cat, warranty replaced and passed smog. Reason I assume it was a leak was cause Cats were new, worked fine, took off for headers and while putting them back on I slightly bend the flange. No leaks visible at all but sensor knew something was off.
    shifty` likes this.
  22. Feb 10, 2024 at 6:14 PM
    Shocking
    bmf4069, KNABORES, khooiii and 3 others like this.
  23. Feb 10, 2024 at 6:16 PM
    Spocking
  24. Feb 10, 2024 at 6:34 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I get what your saying, but my code is specific to bank 2, and bank 2 is reading "rich" or higher voltage spikes. If oxygen was being sucked in by venturi effect anywhere, the readings would be "lean" or low voltage.
    Voss[QUOTED] likes this.
  25. Feb 10, 2024 at 6:36 PM
    Voss
    2003 AC TRD 4x4
    As I said, “I don’t know much about a lot” so don’t pay me no attention. I can only speak of experience not knowledge.
  26. Feb 10, 2024 at 7:13 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Just did a rear forward-> front->X to back rotate. First rotate since DT scuffed up my new wheels and told me they didn't. Forgot they fucked up 2 of my splined lug nuts for me. I just don't under stand why it's so hard to have the socket on before the WHAM BAM THANK YOU MAM trigger is pulled. Changed the oil a week ago or there abouts.
  27. Feb 10, 2024 at 7:26 PM
    They are usually really good at setting your lug cap upside down and sliding them all over the floor like that
    oscardog86, bmf4069 and txagg like this.
  28. Feb 10, 2024 at 7:43 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I only take em dismounted wheels.
    NUDRAT, metalpete and FrenchToasty like this.
  29. Feb 10, 2024 at 8:48 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Sooo many wires behind the new head unit... I stuffed her like a Christmas turkey! For real, I can't even direct the air back to the "face" setting lol. I'll pull it apart and mess with it in the near future, push some shit out of the way and make it work again, but I never take it off defrost anyway. Harness is back the way it was supposed to be and that's what matters in the long run.
    I nabbed some power acoustik, double din unit for cheap... I know, I know, "you get what you pay for", and that phrase always rings truest when it comes to car audio, but I wanted something slightly fancier that still plays fuckin cds...why is that so hard to find?!
    Couple thoughts on this HU. Biggest upgrade I thought I would get using a more full band EQ (don't @ me bro, I know built in EQ ain't where it's at lol), but i think my single din Sony captured a better range with the basic low-mid-hi. Plus, the HU I just put in might be the first HU to sound worse with "loud" turned on! It doesn't seem have the same frequency range either, especially on the lows, but now might be the time to finally install the matching, infinity 6.5s, in the rear doors.
    It'll do the job for now, until I can upgrade to an older alpine or excelon...that still plays discs!
  30. Feb 10, 2024 at 9:09 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    We can't all be collectora of fine rubber and metal. :boink:
