Shift solenoid connector on side of transmission
Discussion in '1st Gen Tundras (2000-2006)' started by Kingnewf, May 20, 2023.
  1. May 20, 2023 at 12:56 PM
    Kingnewf
    Kingnewf [OP] New Member
    I am underneath the truck trying to get this connector disconnected. It’s awkward spot and I I have never seen a connector like this as it looks like a locking mechanism but I don’t want to break it trying to pull harness out. Is there a locking mechanism on this connector like most sealed junctions. How does this one open.
    Please help before I try to open to test resistance of solenoids.
  2. May 20, 2023 at 1:29 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Looks like a sorta cam lock to me.
    like these ears will ride in the tracts of the latch.
    so you'd rotate the little handle out, then it should unplug.
  3. May 20, 2023 at 1:35 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If you push the release tab at red arrow toward pins, will it not pull out ?
  4. May 20, 2023 at 1:50 PM
    Kingnewf
    Yes I got it released when you pull white tab down the connector slides up out of housing good idea for connector. Do you know the pin outs for this connector. Layout my service manual inhave what pins to check but not the connector layout. I can’t find that connector. I think I can check at E6 at ecm as well.
  5. May 20, 2023 at 2:03 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    RainMan_PNW likes this.
  6. May 20, 2023 at 2:06 PM
    koditten
    Kirk
    Midland of the Mitten
    That connector is a 1 hand job. Swing the cam lever and it unplugs the connector for you. I wish they all were like that.
  7. May 20, 2023 at 2:07 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Im gonna guess '05-'06, cause i looked and didnt see that connector on mine.
  8. May 20, 2023 at 2:12 PM
    Kingnewf
    06 double cab and I could
    Not find the pin outs for that connector it’s has 15 pins. I want to test pins 7,8,15 the 2 shift solenoids and the SR solenoids
  9. May 20, 2023 at 2:31 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    pg 339 in 2006 EWD linked above....
    RainMan_PNW and shifty` like this.
  10. May 20, 2023 at 2:34 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Think i saw it on page 310 but didnt know what i was looking for. Magical wires are above my pay grade.
  11. May 22, 2023 at 6:41 PM
    Kingnewf
    Iremoved connector found pins 8 & 6 broke off inside harness it
    Looks like. Hard to see in tranny connector. Needed a mirror and hard to get pic. Put
    Connector back as I could not get pins out. P0986 is cleared but now I suspected broken pin 6 is pressure solenoid p2716 which has come in. I suspected both these might have been corroded. My next questions is the housing connector on the tranny is that a replaceable part. If I can’t get pins out of the harness then i would need a new harness as well or section.Not what I was expecting to find or happen. Pins 8!maybe making contact but may not last. I’m gonna take it for a drive to see how it shifts.
    The pressure solenoid i suspect it when your transmission is loaded for hauling.
    Kalewillis likes this.
  12. Feb 4, 2024 at 8:59 PM
    Kalewillis
    Kalewillis New Member
    Kale
    05' Black DC
    Brush gaurd
    Hey bud did you find a solution to your problem! I'm going to dig into mine tomorrow. I got code p2716 as well and I'm wondering if it's the connector
  13. Feb 8, 2024 at 8:13 PM
    Kalewillis
    Kale
    05' Black DC
    Brush gaurd
    Ok I thought I would post again for the record even though I haven't gotten a reply. My truck is completely rust free, but I found a good amount of corrosion in the connector. The pin that leads to the line pressure solenoid was broken off in the female end. I'm sure this is what's causing the P2716 code. I went ahead and ordered a new internal harness from Toyota, as well as the solenoid just in case ($200 ouch) pan gasket 4 qts Toyota ATF WS and filter. I'm going to be putting silicone on top of the connector so water doesn't get back down into the pins. There is no where for it to go once it's makes it into the connector so it just sits on the pins and eats it away. Not a good design
    shifty` likes this.
  14. Feb 9, 2024 at 4:17 AM
    Thanks for the update despite lack of reply. Do yourself a favor. Skip the silicone. Liberally brush dielectric grease into both sides of the connector. Same stuff many of us use on our battery terminals. It will waterproof without loss of conductivity.
  15. Feb 9, 2024 at 4:59 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Is this connector design 05-06 only?
  16. Feb 9, 2024 at 5:12 AM
    Kalewillis
    Kale
    05' Black DC
    Brush gaurd
    Thanks shifty. I should probably have explained better. I am going to put dielectric between the connectors. But the backside of the female end where the wires enter is where water was allowed to enter. I think the wire seals may have shrunk over time or werent tight to begin with. That is where i was planning on putting the silicone
    shifty` likes this.
  17. Feb 9, 2024 at 5:13 AM
    Kalewillis
    Kale
    05' Black DC
    Brush gaurd
    From my understanding 00-04 do not have the connector
    TX-TRD1stGEN[QUOTED] likes this.
  18. Feb 10, 2024 at 5:41 PM
    Kalewillis
    Kale
    05' Black DC
    Brush gaurd
    Ok I just wanted to say for the record that my problem was solved by replacing the Internal harness which had one pin corroded and broken off into the female end. I replaced the solenoid for good measure (200 bucks ouch) The truck shifts better than before which is probably due to the new fluid. Thanks guys for your guidance
    TX-TRD1stGEN and shifty` like this.
