2024 DRL Question
Discussion in '3rd Gen Tundras (2022+)' started by close59956, Feb 10, 2024.
  1. Feb 10, 2024 at 10:48 AM
    close59956
    close59956 [OP] New Member
    I have a 2024 SR5 with the TRD sport package. Do these had the LED daytime lights, it looks like just the normal headlights that are on as the DRL’s. I know the later year 2nd gen’s had the LED lights. You would think a $60k 2024 would have more than just the old fashioned DRL headlights!!
  2. Feb 10, 2024 at 11:28 AM
    nafterclifen
    nafterclifen New Member
    Pocono's, PA
    From what I've read, all new 3rd gen Tundras have LED headlights. Which means that the DRL's should be LED because they're not separate lights. Also, there seems to be two variations of the LED headlight housings - Reflector (standard) and Projector (premium).
  3. Feb 10, 2024 at 11:44 AM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    I think what the OP is trying to say is that while DRL's on 3rd gen are LED they're not in the way the 2.5 gen Tundra or 3rd gen Tacoma was - accent LED light on the bottom or top and bottom of the headlight housing - just low beam as a DRL instead.
    Up here in Canada even Limited doesn't get premium lights.
  4. Feb 10, 2024 at 11:54 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    You’ll have the top headlights. I believe the indicator is a halogen bulb. But it’s a bulb none the less.
    dagsom likes this.
  5. Feb 10, 2024 at 12:13 PM
    close59956
    So basically 2010 style but with LED lights, not the LED strip like every other vehicle made past 2015. Disappointing but not surprising.
  6. Feb 10, 2024 at 12:17 PM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    Correct.
  7. Feb 10, 2024 at 12:55 PM
    Ipaddick
    Ipaddick New Member
    Canada
    Yep.
    I’m sure it convinces people to buy higher trims.
  8. Feb 10, 2024 at 1:08 PM
    close59956
    Even though every other manufacturer, it seems, to offer it standard on all models…typical Toyota.
  9. Feb 10, 2024 at 1:14 PM
    Ipaddick
    Ipaddick New Member
    Canada
    Not really. f-150 nor Silverado lower trims don’t have them… they ever have halogen headlights… so this isn’t even close to true. Lol
    pwpblue likes this.
  10. Feb 10, 2024 at 1:17 PM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    While you are right, lower trims of other brands don't have the LED DRLs, the point is 2021 Tundra SR5 had it so obviously Toyota took a step back and do not offer them now.
  11. Feb 10, 2024 at 1:24 PM
    close59956
    Are you a used car salesman??? LOL
  12. Feb 10, 2024 at 1:29 PM
    close59956
    What I do know is almost every car on the road has them nowadays and you can’t tell me ALL of them are higher trim models!! My wife’s Honda Pilot has them and hers isn’t top trim…so this IS close to true
  13. Apr 6, 2024 at 12:02 PM
    LunarRckplati
    LunarRckplati New Member
    Tundra hybrid Platinum
    TRD 3 inch on 35's looking for TRD pro wheels!!
    Curious how some people who have third gen tunders have amber daytime running lights but mine are white. I have a 2024 Tundra Platinum hybrid.
  14. Apr 6, 2024 at 12:11 PM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    That has to be an aftermarket option like Alpharex.
    LunarRckplati[QUOTED] likes this.
  15. Apr 6, 2024 at 6:53 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    No one had LED headlights in 2010. Your HI/LOW/DAY and lower driving lights are all LED. Just your front turn signals/running lights are regular incandescent bulbs. All side running lights and tail lights are LED. I like how these headlights black-out during the daylight when off.
