  1. Feb 9, 2024 at 6:03 PM
    I think it reads thru the wheel speed sensors? I don’t know, that’s a Tuesday question
  2. Feb 9, 2024 at 6:14 PM
    albru2
    albru2 Keep it simple stupid
    2002 Tundra Limited 4.7l 4WD AC
    Before and after ATS HD springs with a half yard of gravel. Very noticeable while driving. I think that clear coat on the door is my next project now that I've got all the "essentials" taken care of.
  3. Feb 9, 2024 at 6:37 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Coriolis effect. In the southern hemisphere the threads go the other direction.
    BroHon, oscardog86, JasonC. and 5 others like this.
  4. Feb 9, 2024 at 6:50 PM
    kentuckyMarksman
    kentuckyMarksman New Member
    Thanks. I just bought the same links for my truck, redoing the front end...
  5. Feb 9, 2024 at 8:30 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Nothing better than hearing the 2UZ hit 7k purring like a kitten doing donuts after you kicked the girlfriend out.
    V Day is going to be cheaper this year.
    I tried to get a pic but the flash was too slow.
    She’ll probably be back though, I’m like a T Swift song.
    BroHon, oscardog86, JakeJake and 3 others like this.
  6. Feb 9, 2024 at 9:00 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So was the duplicolor spray can of 056 natural white that I got
  7. Feb 9, 2024 at 9:02 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Did you change your rear shocks too? If not, get you some 5100's.
  8. Feb 9, 2024 at 9:04 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    7k????!!! Damn, my tuned 06 only hits 5.9k
  9. Feb 9, 2024 at 9:14 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    How do you crank it to 7? Mine only goes to 5.
    455h0le_dachshund likes this.
  10. Feb 10, 2024 at 4:08 AM
    It does. But, I thinks it's expecting a certain amount of revolutions at a certain speed, just like our trans speed sensors. But but, since your MPG measurement before and after was on the same size tire, it should be accurate. It'll just change the speedo reading to be more accurate.
    That's what my awake to early thinking says. It's probably wrong.
  11. Feb 10, 2024 at 6:18 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I met up with @khooiii yesterday and grabbed the extra drivers seat he had. My plan is to pull the backs off and swap the bottom cushion and frame assembly. I started with the donor seat just to make sure that I don’t screw anything up with my seat.
    He gave the seat away because the seat back left side bolster had given way. You can see it in the first pic. Here’s what I discovered, there was nothing wrong with the foam. The foam inside the seat back is secured with some fabric and a metal lock ring. I can’t get pictures because there was only enough space to fit my one hand. The fabric had torn allowing for the foam to be manipulated towards the back of the seat. Once I discovered this, I peeled enough of the cover back to access that area, manipulated it back into position and secured with a zip tie. Essentially, the seat back is now as good as it ever was.
    I have the bench seat set up in mine and this is a captains chair. Now that I know all of these parts are good, I will save them in case one day I swap from the bench. Now on to separate my current seat and swap the base.
    bmf4069, ToyotaDude, Voss and 7 others like this.
  12. Feb 10, 2024 at 7:26 AM
    The Black Mamba
    DFW
    Imma keep it stock
    03 Captains chair base with 00 40 bench back
    bmf4069, Voss, JasonC. and 3 others like this.
  13. Feb 10, 2024 at 7:52 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Installed and tested. Seatbelt light functions. I’m going to consider this a mod as my truck did not originally come with the adjustable base.
    bmf4069, Voss, Mr.bee and 8 others like this.
  14. Feb 10, 2024 at 8:10 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Pictures do not do it justice. I wish you could see how clean this arm rest cover is fresh out of the washing machine
    oscardog86, KNABORES, khooiii and 4 others like this.
  15. Feb 10, 2024 at 8:12 AM
    The Black Mamba
    DFW
    Imma keep it stock
  16. Feb 10, 2024 at 8:14 AM
    Flip it inside out and stitch up that hole?
  17. Feb 10, 2024 at 9:52 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    I went to the junkyard after work yesterday to eyeball the wiring on a 2000 they had. What an absolute fcking nightmare it would be to actually pull this off. The diagram is correct, BUT, those connections do tie into the main harness throughout the dash. The juice ain't worth the squeeze, this time.
    So I just lopped off the connectors on the 2000 (+ a generous amount of wire) and will tie into my existing harness. Then the Metra adapters into the new stereo plugs.
  18. Feb 10, 2024 at 10:54 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I want to see how messed up yours was before
  19. Feb 10, 2024 at 1:15 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Changed the oil in both the Tundra and the Corolla, and changed the fuel filter in the KTM. Everything is running happy.
    oscardog86, bmf4069, daveeasa and 7 others like this.
  20. Feb 10, 2024 at 2:53 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Good call. I should check my LBJ bolts. I put mine on in June lol
    shifty`[QUOTED] likes this.
  21. Feb 10, 2024 at 2:58 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Hell yeah that'll work! I never thought to run the upholstery through the washing machine. I just have little green carpet cleaner I use periodically. Glad that worked out for you.
  22. Feb 10, 2024 at 3:07 PM
    It’s never the fuel filter!!!!
    bmf4069, txagg, metalpete and 5 others like this.
  23. Feb 10, 2024 at 4:37 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Oil and filter. OEM filter and drain plug gasket. 5W-30 Mobil 1 fully synthetic oil @ 104,609 miles. Just a shade under 5000 miles since the last one was performed. I don't drive the truck unless I need it, but I always get the oil hot and up to temp when I do. The last oil change was about 14 months ago and I like to do it about once a year even if I don't have 5k on the oil. Checked underneath real well with a trouble light for any problems or leaks and nothing was noted so I guess I'm good for another year.
  24. Feb 10, 2024 at 4:53 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    When I was a kid, this was my dream ride. To this day I think about building one up. 04C3AD04-7E8E-4015-A599-678CB991CA9B.jpg
    SharkDog, NUDRAT, oscardog86 and 11 others like this.
  25. Feb 10, 2024 at 5:00 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Those are neat. Definitely not the most popular, but I can appreciate the hell out of one every time I see it. I'm right behind you wanting a 60/62 series with a modern drivetrain...maybe some coilovers and bypasses to go with lol.
  26. Feb 10, 2024 at 5:05 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Did a little further investigation on my P0430, swapped O2s to make sure it wasn't a bad sensor, it's not. Still getting spikes when it should be flat like B1S2.
    That spike near the end is a 15sec 2200ish rpm while parked. Think I'll take a close listen to them (fuel injectors) with my stethoscope tomorrow and see if one stands out.
    If not then start swapping a new one in and out of each location and see if I get a better graph. Def not doing cats on this old beast, I may try an O2 spacer if the injectors are fine.
    O2 flanges are just barley hanging in there as well :rofl:
    A couple more caps messing with the live data displays, I kinda like this BlueDriver
    Screenshot_20240210_131549_BlueDriver.jpg Screenshot_20240210_131709_BlueDriver.jpg Screenshot_20240210_132413_BlueDriver.jpg
  27. Feb 10, 2024 at 5:11 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Flanges could definitely be causing your issues. Mine were pretty bad and after replacement I haven't seen a check engine light since, the shop just chopped the pipes off at the converters and welded in new.
  28. Feb 10, 2024 at 5:16 PM
    chunk
    chunk New Member
    That is so bitchen, it reminds me of the later Isuzu Trooper. Such a simple basic vehicle, I think it might have had a straight 6 in it? My friend had a Cressida with a straight six and it was such a good motor, but I'm a fan of the 300 six in old Ford trucks. But what do I know, I like BMW airheads and slant six Dodge Darts too.
    txagg and Voss[QUOTED] like this.
  29. Feb 10, 2024 at 5:19 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    So you had Catalyst System Efficiency code? Were your sensor 2 voltages High or Low? Did they do anything else besides replacing the exhaust from the cats back?
    Asking because even if it was leaking around the flange it still would be reading the exhaust before it leaked out. :monocle:
  30. Feb 10, 2024 at 5:25 PM
    I thought the downstream sensors averaged around 0.4-0.5 volts instead of zero? Weird.
    BroHon[QUOTED] likes this.
