range indicator
Discussion in '2nd Gen Tundras (2007-2013)' started by twuckman, Feb 9, 2024.
  1. Feb 9, 2024 at 7:59 AM
    twuckman
    twuckman [OP] New Member
    2011 Black Tundra SR5
    Cab-hi camper shell with carpet package, cat-back exhaust, NFG TAs with Motometal chromes
    About 6 weeks ago, I filled up my tank (about 1/4 tank remaining) and the gas gage read 'Empty'. Did not do anything and it began working about 2 days later. Now my range indicator read '0' and does not change. ANy suggestions?
  2. Feb 9, 2024 at 8:37 AM
    RobertD
    Robert
    DFW, Texas
    Have you tried a simple reset? As in, disconnect battery, leave it off for like 10 minutes, and then reconnect.
  3. Feb 9, 2024 at 9:27 AM
    twuckman
    No I did not, but I will. Thanks for the quick reply. I appreciate it. :thumbsup:
    RobertD likes this.
  4. Feb 9, 2024 at 11:18 AM
    RobertD
    Robert
    DFW, Texas
    More knowledgeable folks may be able to point you to something else, but disconnecting the battery is easy and cheap and sometimes does the trick.
  5. Feb 9, 2024 at 12:23 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    The old on/off switch trick.
    RobertD likes this.
