Installed BullRings in my 2019 CrewMax stake holes
Discussion in '2.5 Gen Tundras (2014-2021)' started by Selcouth, Feb 8, 2024.
  1. Feb 8, 2024 at 10:53 PM
    Selcouth
    Selcouth [OP] New Member
    Josh
    2019 Smoked Mesquite 1794
    I recently installed BullRings in my stake holes and I had a hard time finding info on where exactly to cut. I took some photos with measurements, so hopefully this helps someone.
    BullRing sells a router bit that has four bearings at the bottom. The goal is to cut out the hole without hitting the metal.
    I pried up the rail covers to roughly mark the centers, drilled out a hole with a step bit, then used the router to clear them out. I have a BAKFlip tonneau cover so the router wouldn't sit flat for portions of the cut, but I made it work.
    SAGE63, borla123, texasrho83 and 4 others like this.
  2. Feb 9, 2024 at 3:20 AM
    CHESSIEMAN
    CHESSIEMAN New Member
    STEVE
    PA
    2025 ICE CAP RALLY CREWMAX
    Nice work, looks great.
    SAGE63 likes this.
