4 bump stops in the front?
Discussion in 'Suspension' started by Stefan68, Feb 8, 2024.
  1. Feb 8, 2024 at 4:37 PM
    Stefan68
    Stefan68 [OP] New Member
    Hi,
    I'm new to this forum and to the Tundras and I have a question about the front bump stops in a 2020 model: Out of the factory it is coming with 4 bump stops in the front, and I know that durobump is recommending replacing only the ones closer to the rear (so 2 out of 4, leaving the front-most OEM). However Durobump is taller than OEM, while Timbren is very close to OEM height. Did anybody try to replace all 4 front bump stops with Timbren? Any good reason (besides $) for not replacing all 4?
    Thank you,
    Stefan
