What are these stubs on the frame?
Discussion in '3rd Gen Tundras (2022+)' started by raylo, Feb 8, 2024.
  1. Feb 8, 2024 at 12:29 PM
    raylo
    raylo [OP] not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    So, I ran into a problem trying to install AMP powersteps today. One of these little transverse cantilever stubs on the frame that sticks out toward, but does not connect to, the running board is in the way of one of the motors so it won't physically fit. AMP says they aren't on all Tundras, but they have run across this issue before and are willing to take the kit back. These things don't connect to the body or anything else or have any visible purpose. I was wondering if anyone here knows what they are?? I am thinking of cutting this one back toward the frame with an angle grinder and/or reciprocating saw to make clearance.
  2. Feb 8, 2024 at 12:55 PM
    lapoolboy
    lapoolboy New Member
    Looks like a stiffener/reinforcement to me
  3. Feb 8, 2024 at 12:57 PM
    raylo
    Frederick, MD
    Can't be. It isn't attached to anything other than the frame itself. Not to the bed, not to the body. Nothing. It is just cantilevered out and ends in mid air.
  4. Feb 8, 2024 at 12:57 PM
    lapoolboy
    Are they on both sides?
  5. Feb 8, 2024 at 12:58 PM
    raylo
    Frederick, MD
    There are a couple on each side. Not sure if they match up exactly side to side.
  6. Feb 8, 2024 at 12:59 PM
    2mchfun
    Something for the hybrid maybe.
  7. Feb 8, 2024 at 12:59 PM
    lapoolboy
    Hmm interesting....I thought maybe it was a bracket for an optional bigger gas tank?
  8. Feb 8, 2024 at 12:59 PM
    raylo
    Frederick, MD
    That's what AMP was wondering. If some hybrid frames got diverted.
    2mchfun[QUOTED] likes this.
  9. Feb 8, 2024 at 1:00 PM
    lapoolboy
    Take a more overall pic of that area so I can ID where it's at and I'll look under my hybrid to see if it has the same.
  10. Feb 8, 2024 at 1:02 PM
    raylo
    Frederick, MD
    Just under the rear door looking out towards the rocker panel. The bolt holes are for the OEM running boards at the rear driver's side... the aftermarket guys use the same holes. Mine is a DC so the "brace" or whatever may not be in the same place.
  11. Feb 8, 2024 at 1:04 PM
    raylo
    Frederick, MD
  12. Feb 8, 2024 at 2:06 PM
    raylo
    Frederick, MD
    A couple more photos looking from the back towards the front.
  13. Feb 8, 2024 at 2:23 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    They look like unused cab mounts. You said you have the DC? Maybe those are for the CrewMax cab.
    Or they are there for the hybrids for support of the battery. But I have a feeling cab configuration is going to be a part of it, HV or not.
  14. Feb 8, 2024 at 2:24 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Looks to me like crash bars. Kinda like the one in wheel well that people chop off when going 37’s. In the case you get T boned. Aluminum body is soft, easily crumples and pinning the driver/passengers.
    Skorch, Soupbean77 and raylo[OP] like this.
  15. Feb 8, 2024 at 2:25 PM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    Strange. Just went and looked and I have one on the driver side roughly middle of the front door.
  16. Feb 8, 2024 at 2:29 PM
    raylo
    Frederick, MD
    That at least makes a little sense, to protect the passenger compartment at the doors from side collision. Taking a few inches off shouldn't hurt much, and people don't fit in the back of this DC anyway.
    Skorch, Soupbean77 and 4genRunner like this.
  17. Feb 8, 2024 at 3:49 PM
    Working Man
    Working Man New Member
    Chuck
    Black - 23 Tundra Limited TRD OFF ROAD
    Tires & Wheels, Levelling kit, Chrome delete, Painted Taillamps , Under hood Glow , Vent Visors. Window tint, box mounted Recovery gear. Re movable Magnetic light bar & movable flood lamps , Step Bars , Off Road GPS Navigation
    In the Collision Biz & Embarrassed I don't know. I WILL Find out , We have yet to pull 22/23 Tundra frame , will pull up my own truck specs tomorrow see if they are target points to check frames , or collision safety points, possibly both . will check if they have anything to do with the Sequoia body mounting or trim package i could see that happening. Will post update
    oddhours, 22whatwedo, Blufin and 2 others like this.
  18. Feb 8, 2024 at 4:20 PM
    lapoolboy
    My 2024 hybrid truck does not have any of those.
    raylo[OP] and 2mchfun like this.
  19. Feb 8, 2024 at 4:53 PM
    2mchfun
    Could they be suggested jacking locations?
  20. Feb 8, 2024 at 5:06 PM
    Could be mounts for manufacturing....
    Blufin likes this.
  21. Feb 9, 2024 at 1:32 AM
    raylo
    Frederick, MD
    The plot thickens!
  22. Feb 9, 2024 at 2:13 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    I’ll take some pics of mine when I get it back from the dealer. They are presently looking into my diff whine…I do remember seeing something like that when I ran the harness for the Go Rhino steps.
    Update…it’s going to be a while before I can help. The diff on my truck with 1,100 miles on it has to be replaced. Metal filings everywhere. Glad it happened before I went on any long trips.
  23. Feb 9, 2024 at 3:00 PM
    Working Man
    Chuck
    found out very little - Attempted to pull up my Trucks Frame specs today, Shocker awaiting on software update for 23/24 Toyotas. 2022 dose not show them brackets as messaging points , nor can we put a repair on it thus making it a none repairable part, nor was there are part# perhaps this is different for 23/24? witting on the update. Makes good conversation they would be Collision points keeping occupants safe from being branded by the grille emblem of what ever hit ya? best of luck with the running boards, maybe another brand will not require cutting in to your Rig?
    I thought great spot to attach hidden Rock sliders.
  24. Feb 9, 2024 at 3:38 PM
    raylo
    Frederick, MD
    IDK... the body has several stout ribs built into in that direction already, adjacent to these mystery things. In any case the 2 rear ones on mine are now stubbier. First the one had to go for the drivers side motor, then the passenger side one had to go for the linkage brace. Bit of a PITA but it's done. And the new boards work a treat.
  25. Feb 9, 2024 at 4:23 PM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    My 23 trd off road has them. Crew max non hybrid. Noticed them while undercoating my truck
  26. Feb 9, 2024 at 4:43 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    I have one extending out from the frame where the power steps (OEM) uses it as a holding point for power wires
    23 Plat HV
  27. Feb 9, 2024 at 4:45 PM
    lapoolboy
    Ah, there's our likely answer!
    2mchfun and raylo[OP] like this.
  28. Apr 9, 2024 at 6:01 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Screenshot_20240409_170043_Gallery.jpg Screenshot_20240409_170026_Gallery.jpg
    Few more shots, found one each on drivers and passenger side about in line with front door handles. Pro that came equipped with duel step running boards.Screenshot_20240409_194957_Gallery.jpg
  29. Aug 29, 2024 at 5:26 AM
    M S Tundra
    M S Tundra New Member
    I guess no one every figured this out?
    mine DC non-hybrid has 2 on each side
  30. Aug 29, 2024 at 7:29 AM
    Tundrastruck91
    Looks figured out to me ..
