Vacuum Noise Up Hill?
Discussion in '2nd Gen Tundras (2007-2013)' started by SonsOfTundra, Jan 7, 2024.
  1. Jan 7, 2024 at 1:36 PM
    SonsOfTundra
    SonsOfTundra [OP] New Member
    Cory
    2011 Black Rock Warrior
    Toytec 3” Methods Kenda Klever RT
    I’ve been scouring the forums for answers but can’t seem to find one.
    My 2011 Rock Warrior 5.7 is making the “vacuum” like sound you normally hear on startup, but it’s doing when at higher rpm’s while driving up hills. Does anyone know what this means?
    I had the local oreillys check for codes or code history and nothing came up.
  2. Jan 7, 2024 at 2:40 PM
    treeandsome
    treeandsome New Member
    That is the fuel pump sucking hard going uphill.:yay:
  3. Jan 7, 2024 at 2:41 PM
    SonsOfTundra
    Cory
    Would it be doing that with a 3/4 - full tank?
    also for context - I just noticed it starting doing this a few months ago. Thanks again for your insight!
  4. Feb 8, 2024 at 9:42 AM
    SonsOfTundra
    Cory
  5. Feb 8, 2024 at 10:00 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Do you have an intake?
  6. Feb 8, 2024 at 10:14 AM
    SonsOfTundra
    Cory
    No everything under the hood is stock. The noise sounds closest to a vacuum noise but it has the rhythm of a miss, if that makes sense. Pretty erratic.
  7. Feb 8, 2024 at 10:16 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Interesting- I'd check for vacuum leaks on hoses etc. The vacuum sound on startup is typically the secondary vacuum intakes.
