  1. Feb 7, 2024 at 3:55 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Because I never thought of that.
    I don't know enough about electricity or antennas to know whether or not that's a potentially bad idea. I do know that my truck is already the ground to alot of stuffs haha.
    No idea if grounding the antenna would be good, bad, or indifferent.
    oscardog86 and shifty`[QUOTED] like this.
  2. Feb 7, 2024 at 3:56 PM
    :D You would be amazed how much easier this thing was to remove. I remember how hot and miserable it was that day. Seemed like it took us forever to install it.
    I'm going to remove as much rust as I can then hit it with Rust-Oleum primer and follow up with their Truck Bed spray. I used that in the past for touch up and it's almost a perfect match.
  3. Feb 7, 2024 at 3:56 PM
    daveeasa
  4. Feb 7, 2024 at 4:01 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I dont know if the rs3000 is where the rs3200 was.behind the gauges on the tundras or not.
    I know on the Tacomas it was behind the driver kick panel. But some people reported it being under their driver seat.
    I just know it's a grey wire. Lots of info on it on TW.
    https://www.tacomaworld.com/threads/how-to-increase-oem-keyless-entry-range.406672/
    https://www.tacomaworld.com/threads/oem-keyless-entry-extended-range-mod.472886/
  5. Feb 7, 2024 at 4:08 PM
    daveeasa
    Oh I’ve located mine before. I know where it is. Just didn’t think about the antenna. And my range sucks donkey balls.
  6. Feb 7, 2024 at 4:11 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    What sort of range do you get if you hold the remote against your head?
  7. Feb 7, 2024 at 4:14 PM
    My forehead gets better range than my chin
  8. Feb 7, 2024 at 4:23 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Bonus ten feet or so
    BroHon and VR6T like this.
  9. Feb 7, 2024 at 4:24 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I usually do chin or temple
    VR6T likes this.
  10. Feb 7, 2024 at 4:26 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    always the temple
  11. Feb 7, 2024 at 4:39 PM
  12. Feb 7, 2024 at 6:55 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You've learned a lot of tips, and tricks along your wrenching journey too. That helps. Plus it was a Florida day that day.
    Anyways, I've always used jobs I've done in the past to gauge how much I've learned/grown to current. Constantly comparing myself now, to where I was then.
    From your posts alone, your confidence has grown, as well as your general knowledge of "wrenching." When was the last time you mangled something, huh?
  13. Feb 7, 2024 at 8:07 PM
    VR6T
  14. Feb 7, 2024 at 9:18 PM
    I mangled a toilet today. Why the hell are the threads on the handle nut backwards? Took me like 20 minutes to fix that thing.
  15. Feb 7, 2024 at 9:28 PM
    VR6T
    Counter rotational threads.its so the nut dont fall off in the tank
  16. Feb 8, 2024 at 3:33 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  17. Feb 8, 2024 at 5:02 AM
    Nobody wants their nuts to fall off in the tank.
  18. Feb 8, 2024 at 6:35 AM
    VR6T
    Exactly lol
    shifty`[QUOTED] likes this.
  19. Feb 8, 2024 at 6:37 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Looks like I might have had a factory amp at one point?? Found these screw holes on the post behind/under the temp controls...can't think of what else they'd be for.
    VR6T likes this.
  20. Feb 8, 2024 at 7:56 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    You have pictures of anything going on in there? Wire harnesses anything?
    Just trying to see if anything is salvageable.
  21. Feb 8, 2024 at 7:58 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    That's where a blaster helps. Like up in the compound 45/90 degree buttresses in the back. But looks like you've gotten after it well with the wheel! Those grinders go on sale for $10 sometimes!
  22. Feb 8, 2024 at 8:36 AM
    VR6T
    Whelp that got messy quick. Alsolike 1.25 quarts low...... Might have something to do with my leaky axle seals.
    Also judging by the color, this has all the 219xxx mikes on it. No metal on the magnet tho so there's that.
  23. Feb 8, 2024 at 8:43 AM
    How did it smell? And good luck on those axle seals.
  24. Feb 8, 2024 at 9:14 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    lol mine definitely had all of the 250k miles as well. It was basically jet black. Thank god it wasnt gunked up
  25. Feb 8, 2024 at 9:18 AM
    metalpete
    ID
    Yeah I should have just taken the picture of everything yesterday. I think it's salvageable, but, essentially...
    The small, factory, white, 4pin and 8pin connectors, are each hanging by a single white/green wire off to the side. The connector that's currently plugged into the receiver, is crimped straight into the harness. They're just the wire nut style of crimps, so there might be enough factory wire to salvage, splice, and tape without too much problem. The Metra & Soesthbe connectors will be here tomorrow.
    I'm curious if the stereo harness, as a whole, can be traced back to a connector(s) on the fuse box under the dash. Or does it splice into some god-forsaken area right behind the firewall?
  26. Feb 8, 2024 at 10:18 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Check the wiring diagram, but S6 looks like the harness you need and at first glance is accessible below the center dash behind the panel where the 12v outlets are.
    2001 Tundra EWD429U.pdf
    BroHon, VR6T and metalpete[QUOTED] like this.
  27. Feb 8, 2024 at 10:27 AM
    VR6T
    It smelled exactly like un burnt 219xxx mile gear oil would smell. Stinky, but not burnt.
    bmf4069[QUOTED] likes this.
  28. Feb 8, 2024 at 10:27 AM
    VR6T
    Same
  29. Feb 8, 2024 at 10:31 AM
    VR6T
    While I was under there I pulled the peacock vent and cleared it so it will vent the axle case pressure now, maybe help slow down the weepiness. And then I just had it with the spare winch slipping on the jacking spindle. So I welded a spare extension I liberated from the junk yard yesterday0208241211.jpg
    NUDRAT, BroHon, bmf4069 and 2 others like this.
  30. Feb 8, 2024 at 10:33 AM
    metalpete
    ID
    My guy... a billion likes upon you.
    BroHon, bmf4069, artsr2002 and 2 others like this.
