Tracking down what is loose and causing a noise vibration
Discussion in '1st Gen Tundras (2000-2006)' started by Geeze_Loiuse, Feb 7, 2024.
  1. Feb 7, 2024 at 8:45 AM
    Geeze_Loiuse
    Geeze_Loiuse [OP] New Member
    2006 Blue Steel Metalic, SR5, Access Cab, 2wd, 6Cyl, Auto Trans.
    I have something loose on the passenger side that makes noise. The source is either inside of the passenger side dash or in the engine compartment just in front of it. The annoying part is that it only makes the noise when the truck is in gear and usually not when the brake is applied. Being alone I can't do anything but guess because if I start the engine and put it in park there is no noise to help track down to what is loose.
    The only thing I can do for now is look for missing or loose bolts without tearing into the dash. Assuming most trucks develop the same quirks over time I wonder if anyone has run into this particular noise-causer.
  2. Feb 7, 2024 at 8:49 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    On that side you have blower motor, glove box, airbag. Check those items first. You can remove the glove box, test drive. remove the hvac blower motor, test drive. Just a way to help isolate your noise.
    shifty` and Geeze_Loiuse[OP] like this.
  3. Feb 7, 2024 at 9:03 AM
    Geeze_Loiuse
    I think I found it.
    I think I found it right away. The plug-in that holds where indicated was broken. It was still sitting on the metal clip so I did not notice it on first observation. I just pulled on the hose and it fell of without resistance. It was just sitting in place.
  4. Feb 7, 2024 at 9:05 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Cool. Fix that and test :thumbsup:
  5. Feb 7, 2024 at 11:53 AM
    Geeze_Loiuse
    I need to replace that part and cannot seem to find the wording for exactly what it is.
  6. Feb 7, 2024 at 12:22 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Black zip tie in the short term and then junk yard in the mid to long term.
