  1. Feb 7, 2024 at 8:35 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Sad day, fellas. My new stereo arrived and, when I went out to inspect the situation, found out the factory wiring harness was cut.
    When I bought the truck (back in 06 or 07), part of the agreement was that the dealer fix the stereo, as it never worked. Well, when they put in the single din player, they must've cut the original harness. At least they were kind enough to leave the 2 connectors still attached to a single wire each...but, damn, man.
    I have a couple adapters coming so I can re-wire and then attach the new stereo, but...damn, man.:boom:
    whodatschrome, bmf4069 and oscardog86 like this.
  2. Feb 7, 2024 at 8:43 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    where's the dislike button? :(
  3. Feb 7, 2024 at 9:37 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
  4. Feb 7, 2024 at 9:45 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    This option works for anyone interested in switching those to LEDs:
    https://www.amazon.com/gp/product/B013HJGOAA?ie=UTF8
  5. Feb 7, 2024 at 10:01 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    BroHon and des2mtn[QUOTED] like this.
  6. Feb 7, 2024 at 10:04 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Wow! I kind of want to go test drive it just to see.
  7. Feb 7, 2024 at 10:06 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    BroHon, bmf4069 and oscardog86 like this.
  8. Feb 7, 2024 at 10:34 AM
    Awesome color.
    BroHon and 455h0le_dachshund like this.
  9. Feb 7, 2024 at 10:41 AM
    des2mtn
    SW
    Tonto cover
    Yeah, you know that's the type of seller you want to deal with when they're posting the prices other trucks have sold at, and that they've already turned down a $24k offer.
    And the airbag light is on, but "it never bothered me"
  10. Feb 7, 2024 at 10:49 AM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    I went to the junk yard today, just looking for head light blinker tie bolts. Walked out with like 20 front end bolts, glove box hing bolts, and new fog light plus ad mine were cut at some point. Found some other stuff...... Some pics may hurt your feelings0207241025_HDR.jpg 0207241025a_HDR.jpg 0207241025b_HDR.jpg 0207241012.jpg 0207241012a.jpg 0207241012b.jpg 0207241012c.jpg 0207241013.jpg 0207241013_HDR.jpg
    KingSequioa007, Voss, bmf4069 and 2 others like this.
  11. Feb 7, 2024 at 10:54 AM
    metalpete
    ID
    If I'm ever to drop $30k on a 1st gen, I'm going here.
    https://www.jordanmotorsport.com/us...MakeModel&searchtext=Tundra&inventorysearch=1
    I don't know where these guys find these trucks but they always have them. Always lift them, do the timing belt, coat the frame, etc. They had a dark purple 1st gen, like 5-6 years ago, that might have been the coolest truck I'd ever seen. Should've paid the $18k back then!
  12. Feb 7, 2024 at 12:03 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Does your truck have the in dash amp behind the climate controls? If it does you're in luck. Unplug it and buy a $10 harness and you're set. Pics may help if you're not sure.
    NUDRAT and bmf4069 like this.
  13. Feb 7, 2024 at 12:03 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    The low miles are impressive.
  14. Feb 7, 2024 at 12:06 PM
    ToyotaDude
    ToyotaDude Member
    Quick reason to move the cluster to LED? Usually have dash fairly dim. Is it to just increase bulb longevity and not brightness? The kick panels, overhead, reverse, and cargo lamps would all seem to benefit from increased light output.
  15. Feb 7, 2024 at 12:13 PM
    daveeasa
    Interesting. I wonder if they might do restoration work too. Probably not cost effective but still, I might consider it if I stumbled on the cash. The list of work to do is long.
  16. Feb 7, 2024 at 12:14 PM
    metalpete
    ID
    No matter how sure of something I am, my sure-ness drops by 25% when asked a question.
    Currently sitting at 75% sure. Will double check when I get home...
    BroHon and bmf4069 like this.
  17. Feb 7, 2024 at 12:17 PM
    metalpete
    ID
    The LC deserved better than that...
    BroHon, 87warrior, bmf4069 and 2 others like this.
  18. Feb 7, 2024 at 12:26 PM
    metalpete
    ID
    Definitely. Even that 07', if that was a double-cab... I'd probably go buy it now! My AC is gonna get even tighter when baby #2 shows up in a week.
    oscardog86 likes this.
  19. Feb 7, 2024 at 1:44 PM
    For $15, this Chinese angle grinder is getting it done. Just hard to hit the tight spaces.
    Voss, whodatschrome, BroHon and 7 others like this.
  20. Feb 7, 2024 at 1:51 PM
    Be sure to hit that with some Naval Jelly after, it'll neutralize the rust down in the pits and valleys.
    NUDRAT likes this.
  21. Feb 7, 2024 at 2:03 PM
    Loctite brand? Don't have any on hand yet.
  22. Feb 7, 2024 at 2:23 PM
    Yes, I believe they own it now. You should really have a bottle. It's one of those tools that, if you're dealing with rust on something where liquids won't work well (i.e. not a perfectly flat panel), you can't beat the stuff. And it eats rust like nobody's business. Just read the instructions!
    You can buy it on scAmazon if you're too lazy to go to the store. I recommend this bottle: https://www.amazon.com/dp/B000C016OC/
    But scAmazon charges a premium, the LAPS probably has it for $13-14.
  23. Feb 7, 2024 at 3:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Today I successfully extended the range on my rs3200 keyless system, from 5-10 feet before, to about 30 yards now. I could have never locked/unlocked my truck with my key fobs from inside the house before. Or from the mailbox to the garage. Stoked.
    All you gotta do is locate the RS3200's ECU, behind the gauge cluster, then undue the largest plug, locate the grey wire on the end of the plug, opposite side of the retention clip. Then splice into it with a 3 to 4 foot wire and run it up the A-pillar, into the headliner.
  24. Feb 7, 2024 at 3:27 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Dude if you needed fogs you should said something. My old fogs are just sitting in the lower half of my bumper lol
  25. Feb 7, 2024 at 3:32 PM
    daveeasa
    If you need me to look at anything on your behalf, hit me up.
    metalpete[QUOTED] likes this.
  26. Feb 7, 2024 at 3:34 PM
    daveeasa
    Oh that’s interesting for sure. I wonder if the 3000 would be similarly improved.
  27. Feb 7, 2024 at 3:36 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Ohhhhhhhhhh I seeeee now
    I think that rust is from my sweaty, greasy belly :rofl:
    Getter done Erik!
    Rattle canned bed liner going back on or????
  28. Feb 7, 2024 at 3:42 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yes, I did this one my 99 Tacomas rs3000 over a decade ago and it worked great. On my Tacoma I was able to trace the grey antenna wire from the plug on the rs3000 module to where it was wrapped around the steering wheel. I unraveled it and ran it up the A-pillar into the headliner. I didn't even have to splice anything. My taco range after that was so much, that I could hit the unlock and it would automatically lock before I made it to the truck sometimes, because of the 30 second timer you have to open the door.
  29. Feb 7, 2024 at 3:44 PM
    daveeasa
    I’ll open mine up in a little bit and check it out.
  30. Feb 7, 2024 at 3:51 PM
    Why not just ground it to the chassis, then the entire truck will be the antenna?
    des2mtn and FrenchToasty like this.
