AT tire size for stock 23 platinum
Discussion in 'Wheels & Tires' started by 23tundra75002, Jun 26, 2023.
  1. Feb 5, 2024 at 8:52 PM
    #61
    Jalzate44
    Jalzate44 New Member
    San Antonio TX
    2024 Tundra SR5 Crewmax 4x4
  2. Feb 6, 2024 at 4:33 AM
    #62
    smith2335
    smith2335 New Member
    I have a 23 trd off-road with trd lift installed on a 1794
    I added the Nitto recons 285 65 20 s and have slight rub at full lock
    The info on the lift said this size would have been a no problem issue however here we are
    I kept the wheels and love them so I’ll deal until I need new tires then I size down to 275 and hopefully that’ll do it
    Love the truck
  3. Feb 6, 2024 at 5:23 AM
    #63
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Check the skid plate, some have found alittle bend will cure this.
  4. Feb 6, 2024 at 5:35 AM
    #64
    smith2335
    Took skid plate off when they installed the lift at the dealer
    But thanks
  5. Feb 6, 2024 at 6:32 AM
    #65
    tallg53
    tallg53 New Member
    2024 CMLB 1794 TRD OR
    Just getting started...
    Where is the rub? Fender, lining, sway bar? I am waiting on delivery of a 1794 with the TRD Lift and initially wanted to do 295/65 20 but may back it off to 275/65 20 if the width is the issue.
  6. Feb 6, 2024 at 6:51 AM
    #66
    smith2335
    The dealer said it was the sway bar
    Of course when I asked about the contradiction in the lift kit explanation they just shrugged
    I also took it to our local off road shop and they said sway bar too
  7. Feb 6, 2024 at 7:20 AM
    #67
    EOTundra
    EOTundra New Member
    Los Angeles
    2023 CM WCP Platinum 6.5
    Did the local shop offer a solution?
  8. Feb 6, 2024 at 7:26 AM
    #68
    tallg53
    tallg53 New Member
    I don't recall where I saw it, but I have seen some saw switching to the TRD Pro sway bar was a solution. I don't have my truck yet (3 weeks til delivery) so I cannot confirm if there is a difference in the design / structure of the sway bars to allow the clearance. I'll probably stick to the 275/65 20 Recons and hope it clears.
  9. Feb 6, 2024 at 7:57 AM
    #69
    smith2335
    The only solution they offered were different wheels or spacers which in our area will not pass inspection
    so I’ll just deal until I switch tires
    EOTundra and tallg53 like this.
  10. Feb 7, 2024 at 9:45 AM
    #70
    tallg53
    tallg53 New Member
    I saw this in another thread and made me think of our exchange. It seems the TRD Sway Bar spacer might be too large and the Icon Spacer Kit is a good substitute. Once I take delivery of mine, I will be looking into this further.
    Thread: https://www.tundras.com/threads/22-tundra-trd-suspension-lift-kit.112901/page-34#post-3462052
    Icon Kit: https://www.amazon.com/dp/B0B8H23S54/?coliid=I3KHXPW1OEWBLS&colid=2U8MLMALFWV5P
  11. Apr 12, 2024 at 11:59 AM
    #71
    Tundraman479
    Tundraman479 New Member
    2024 Tundra Crewmax TRD Sport Lunar Rock
    TRD Pro Suspension 275/60r20 Wildpeaks
    Just for a datapoint I have a 2024 Tundra TRD Sport I was planning to install 285/65/20 Falken Wildpeaks with no leveling kit yet. But when they mounted the first tire up it was rubbing the upper control arm.
    Not sure if it’s the TRD Sport wheel offset or something else, but I guess it’s either new control arms or a smaller tire.
  12. Apr 12, 2024 at 12:00 PM
    #72
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    or wheel spacers
  13. Apr 13, 2024 at 7:12 AM
    #73
    Aggiesdm
    Aggiesdm New Member
    Derek
    2016 Crew Max Platinum 4X4; '25 Limited 4X4
    '16: 2" lift and Retrax bed cover
    im running 285/65R20 BFG KO2’s and they look great with no rub. Don’t have a before-lift pic at the moment, but I’ll try to post one later.
