  1. Feb 6, 2024 at 3:08 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    All your stuff came in today?
    Mr.bee[QUOTED] likes this.
  2. Feb 6, 2024 at 3:14 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    kinda bland. Not sweet like my red & tacky.
  3. Feb 6, 2024 at 3:14 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    bmf4069 and RUSTYNUTS like this.
  4. Feb 6, 2024 at 3:14 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    probably moly grease then
    VR6T likes this.
  5. Feb 6, 2024 at 3:22 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    No moly specs in it. Just gonna follow tradition & assume i'm right. Pass side inner tie rod was definitely my wiggle. I noticed it was looser, but didnt feel the play, but after wiping off some chunky grease, she's all wallered out.
    anyone got a quick link to the rack bushing replacement? Am i gonna be able to get the old bushings out with the rack in the truck? The vertical bolt is the one i'm most worried about.
    nvm. Gonna shelf these bushings until im forced to replace em.
    oscardog86, bmf4069, VR6T and 2 others like this.
  6. Feb 6, 2024 at 3:31 PM
    It’s also carcinogenic, but then again, everything is nowadays.
  7. Feb 6, 2024 at 3:32 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    the package didnt warn me. Can i sue?
  8. Feb 6, 2024 at 3:40 PM
    He’s not in Cali, it should be fine
  9. Feb 6, 2024 at 3:50 PM
    I need to quit procrastinating and get this done. What's the best tool for removing them from the rack?
  10. Feb 6, 2024 at 3:55 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i dont have a 40mm wrench, so the smaller adjustable wrench was for the tube on the rack, and the larger adjustable wrench was for the ITR. The hammer & chisel were for the old lock washer and the crescent wrench was to fold the new lock washer over.
  11. Feb 6, 2024 at 3:58 PM
    Pipe wrench. Wrap it over the ball end and whack it with a mallet if it doesn’t come free easily. Need to hold the rack stationary though when it’s done.
  12. Feb 6, 2024 at 6:21 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    I used one the 12" of these: Proferred Plumbing Adjustable Wrench, Black Phosphate Finish, 4 Available Size Options 6-inch, 8-inch, 10-inch, 12-inch - T08004 https://www.amazon.com/dp/B016OK8QNM
    Then broke it loose with ratchet strap attached to the front tow hook on the right side.
  13. Feb 6, 2024 at 6:30 PM
    Mustanley
    Hendersonville, NC
    oscardog86, shifty`, bmf4069 and 4 others like this.
  14. Feb 6, 2024 at 6:51 PM
    VR6T
  15. Feb 6, 2024 at 7:33 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    :ohsnap::curls::muscleflexing::bananadead::rofl:
    Whoa buddy. My skid is 1/4" plate, and has somewhat of a spiderweb of solid steel framing behind it. To be fair, I'm not rock crawling, and don't plan to use my skid as a slider, but it'll do plenty good against desert brush, small trees, and if necessary, protestors blocking traffic.
    TWSS
    oscardog86, bmf4069, BroHon and 3 others like this.
  16. Feb 6, 2024 at 7:37 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Exactly.
    I can't take credit for the mangling of the socket, beyond being the one operating the impact. User error. I use his big mamba impact on the 34mm nut with a single walled socket. Splitsville
    oscardog86, bmf4069 and VR6T like this.
  17. Feb 6, 2024 at 8:09 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Supposed to wipe the assembly/clear/yellow grease off and replace it with the moly grease. Work it into the joint (articulate it) then put the rest of it around the ball socket.
    Blue locktite on the inner threads is good. Especially without lockplates.
  18. Feb 6, 2024 at 11:24 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    artsr2002 and 455h0le_dachshund like this.
  19. Feb 6, 2024 at 11:26 PM
    ToyotaDude
    ToyotaDude Member
  20. Feb 7, 2024 at 4:12 AM
    That socket wasn't a kobalt. It's origins are unknown.
  21. Feb 7, 2024 at 4:31 AM
    FishNinja
    Lee
    06DC2wd
    https://youtu.be/YywcR0E9bM4?si=WX-q1bP1MgneLyZl
    It takes like 30min to an hr if everything goes smooth. Install was harder than anything because of how stiff the new bushings are.
    Don’t be a bitch, do it.
    also stop by Harbor Freight and grab a tube of SuperLube it’s possibly the best lube for PU that is readily available
  22. Feb 7, 2024 at 4:56 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Ok good
  23. Feb 7, 2024 at 5:25 AM
    This is America. You can sue anyone for any reason.
    Doesn't mean it won't get tossed out of court.
    BroHon and 455h0le_dachshund like this.
  24. Feb 7, 2024 at 5:43 AM
  25. Feb 7, 2024 at 6:12 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    the grease inside there is already black. I'll try to add more, but the grease i tried to add to my originals didnt really take.
  26. Feb 7, 2024 at 6:49 AM
    FishNinja
    Lee
    06DC2wd
    you’re probably gonna have to clean it out crazy good and then re-apply or try a stickier grease like red n tacky
    BroHon likes this.
  27. Feb 7, 2024 at 7:20 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Nope. Spent 20 mins on each side greasing the balls as best as i could. Then packed the rest around the best i could. It'll just drip into the bellows.
  28. Feb 7, 2024 at 7:49 AM
    FishNinja
    Lee
    06DC2wd
    Maybe even try an air gun and try to push grease back behind the ball joint
    Mr.bee likes this.
  29. Feb 7, 2024 at 8:28 AM
    That's a lot of time to grease your balls. Let us know how they hold up. Mevotech inner tie rods don't look like a quality part to me since they don't take the time to polish the part, but that really isn't critical to operation.
  30. Feb 7, 2024 at 8:32 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    will do. I was hoping for a mevotech sticker, but no dice. Just glad they fit the ac delco TRE's.
