How to display tire pressure
Discussion in '3rd Gen Tundras (2022+)' started by 4lo Toys, Feb 5, 2024.
  1. Feb 5, 2024 at 3:05 PM
    4lo Toys
    4lo Toys [OP] New Member
    Andrew
    My truck doesn’t display the correct psi, how do I fix this?
  2. Feb 5, 2024 at 3:14 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    It takes a few minutes, usually you need to be moving then it pops up. Enjoy your new Tundra
  3. Feb 5, 2024 at 3:36 PM
    4lo Toys
    Andrew
    OK, I am familiar with TPMS taking a while to register once driving but I took this pic after about a 15min drive so I thought maybe there was more to it. Couldn't find anything in the settings though.
  4. Feb 5, 2024 at 3:42 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    So those are the rims and sensors from your stock truck?
  5. Feb 5, 2024 at 3:53 PM
    4lo Toys
    Andrew
    Yes, but I did get new tires installed.
  6. Feb 5, 2024 at 4:38 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Don't know who did your new tire install but if the readout does not show readings after time stated I'd say your shop f'd something up.
  7. Feb 5, 2024 at 4:56 PM
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    I think I read in the manual you can reset the dash but I don't recall the process. It might have been unplugging the battery for a certain amount of time. The old unplug and plug it back in.
    I did a quick Google search but everything was just for the maintenance reset.
    4lo Toys[OP] likes this.
  8. Feb 5, 2024 at 6:25 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    On your guage cluster go to the settings which looks like a gear, scroll down to “vehicle settings” and hold ok, then go to “TPWS” and hold it, then go to “identifying Each Wheel and location”. That’s all I got
  9. Feb 5, 2024 at 6:28 PM
    4lo Toys
    Andrew
    I found that but didn't know what to do next.
  10. Feb 5, 2024 at 6:50 PM
    Tom
    Tom New Member
    If you are still on your oem stock wheels then nothing is needed to be done. No reset no nothing. After 20 minutes of driving if it’s not showing numbers then the tire shop f something up like didn’t put your sensor back in.
    NOEYEZ and Hella Krusty like this.
  11. Feb 5, 2024 at 6:55 PM
    Hella Krusty
    Hella Krusty New Member
    I know mine takes about a good 45 minutes when on the app on the phone. IE adjust the pressure and it will reset on the app 45 minutes later
  12. Feb 5, 2024 at 7:05 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    I can get mine to pop up after a long idle sometimes but definitely within the first mile. If yours aren’t popping up at all then your tire shop did something. I think if they were broken or not there it might be a different symbol. If your tire shop can’t reset with a computer then you will probably have to go to your dealer and they can quickly reset them I’m sure
  13. Feb 6, 2024 at 5:30 PM
    4lo Toys
    Andrew
    On my drive today they popped up within 5 minutes, so guess all is well.
