20”/35’s 23 Pro question
Discussion in '3rd Gen Tundras (2022+)' started by Coachcleats90, Feb 3, 2024.
  1. Feb 3, 2024 at 8:24 PM
    Coachcleats90
    Coachcleats90 [OP] Solar Octane
    Brad
    Bend, Or
    23 Pro Solar Octane
    OEM Console safe Bed Tie downs Tactillian flag & Bear flag AJT key fob CBI covert bumper More to come
    Anyone know if I could put 20” rims w Mickey Thompson 35” on my pro w no rub or lifting? Maybe someone has done this…
    Found a good deal on some MT’s. Would like to find a good deal on some Methods to complement them..
    Thanks for any productive info.
  2. Feb 3, 2024 at 8:43 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    teab likes this.
  3. Feb 4, 2024 at 2:15 PM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    You might be the first person to try and put 35" tires on a third gen!!! If only there was a way to search for such a question.
    Fotnot likes this.
  4. Feb 4, 2024 at 2:22 PM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Pro owners are lucky not to get 20s.
    doublethebass likes this.
  5. Feb 4, 2024 at 2:41 PM
    Breathing Borla
    Northern Illinois
    Why would you take off the bbs forged pro wheels and put on aftermarket 20”s?
    FISHN43, chaztizer and b6graham like this.
  6. Feb 4, 2024 at 3:13 PM
    Coachcleats90
    Brad
    Bend, Or
    23 Pro Solar Octane
    so much thanks!
    I’ve see so many 18” w 35’s. Not much about 20” w 35’s
  7. Feb 4, 2024 at 3:15 PM
    Coachcleats90
    Brad
    Bend, Or
    23 Pro Solar Octane
    just had a thought w some new methods it would be a cool look.
    See a lot of 18 or 17’s w the 35’s.
  8. Feb 4, 2024 at 4:09 PM
    Breathing Borla
    Northern Illinois
    no, forget methods, the trd pro wheels are great wheels, not typical oem crap, bbs are legit
    just put your 35s on those and have a really nice sidewall !
    teab and Fotnot like this.
  9. Feb 4, 2024 at 4:29 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Wheel diameter is irrelevant a 35” tire on a 20” wheel is the same size tire as a 35” on an 18” wheel.
    teab and Breathing Borla like this.
  10. Feb 4, 2024 at 4:33 PM
    Breathing Borla
    Northern Illinois
    yes and no, the sidewalls are much different so the wheel size does matter, but I get what your saying about overall diameter
  11. Feb 4, 2024 at 4:37 PM
    Danman34
    Danman34 New Member
    Danny
    I understand all of that. But OP asked if he could run 35s on 20s without rubbing or lifting. In this case, he’s not concerned about side wall, only diameter. Which is obviously vague because changing wheels will most likely change offset and introduce a whole other set of issues. But that’s a whole different rabbit hole lol
  12. Feb 4, 2024 at 4:39 PM
    Breathing Borla
    Northern Illinois
    yup, understood, just trying cover all the bases
    op, there , forget the 20”s lol.
    just keep in mind the 35s are going to be load e and heavy as hell so don’t come back bitching about mpg or impact on the hybrid system, you have to pay to play if you want that big tire look
    teab likes this.
  13. Feb 4, 2024 at 5:11 PM
    teab
    Ty
    Denver
    You're so much welcome!
  14. Feb 4, 2024 at 6:18 PM
    Coachcleats90
    Brad
    Bend, Or
    23 Pro Solar Octane
    That is my confusion. I was thinking I couldn’t put the tires found on my BBS wheels since they are 20” and mine are 18”. So I was thinking I needed to get new 20” wheels. Ignorant on this whole tire concept so trying to figure stuff out. Obviously 18” - 20” is 2” difference, so it doesn’t make sense.
  15. Feb 4, 2024 at 6:22 PM
    Breathing Borla
    Northern Illinois
    ok, didn’t realize where we are at with this
    you can absolutely get 35” on an 18” wheel. It’s just a matter of what you like
    so don’t get rid of your pro wheels , there is a massive tire thread here on this.
  16. Feb 5, 2024 at 6:13 AM
    teab
    Ty
    Denver
    Ahhh well OP @Coachcleats90 that makes more sense now..... the actual question was. "I don't understand how tire size and wheel size are related." See below for some reading. Putting a 35" tires on a 20" rim is very common on here, its just more common to put them on an 18" or 17" rim to maximize sidewall for a better ride off-road with lower air pressure.
    Offset of wheels is another lesson. Will a 35" tire work on a 20" rim? yes it will. That all depends on how wide the tire size is and the offset of rim. There are many threads discussing this topic...hence the maybe you're the first to consider this.
    https://www.tirerack.com/upgrade-garage/how-do-i-read-my-tire-size-on-my-sidewall?gclid=CjwKCAiAq4KuBhA6EiwArMAw1BzmUeMXXg9J4Nf5ctfqoprLLtRWiVDHYndSADzlxseBg1QtvZ5AYhoCN1cQAvD_BwE&ef_id=CjwKCAiAq4KuBhA6EiwArMAw1BzmUeMXXg9J4Nf5ctfqoprLLtRWiVDHYndSADzlxseBg1QtvZ5AYhoCN1cQAvD_BwE:G:s&s_kwcid=AL!3756!3!354820920464!e!!g!!tire sizes explained&gclsrc=aw.ds&gad_source=1
    You can compare tire size at that site above here is a comparison of the 20" and 18" tires that come on say a limited vs a PRO and how they compare to each other (285/65/18 vs 265/60/20).
