Intake manifold spacer
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jnickoles, Feb 4, 2024.
  1. Feb 4, 2024 at 6:11 PM
    Jnickoles
    Jnickoles [OP] New Member
    2021 Tundra sr5
  2. Feb 4, 2024 at 6:29 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I haven't seen any convincing evidence that TB spacers do anything on Tundras. If you find a conclusive test please share it.
    As far as the intake runner kit increased runner length and plenum volume can improve performance much like headers. I haven't seen one tested on Tundra but I've seen one used on other platforms to make some HP gains.
    Mdl likes this.
  3. Feb 4, 2024 at 6:30 PM
    Jnickoles
    2021 Tundra sr5
    Interesting. I’d be curious to hear about peoples real world results with this
    Mdl likes this.
  4. Feb 4, 2024 at 6:43 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @Mdl, weren't you the one keeping the closest eye on this?
  5. Feb 4, 2024 at 6:44 PM
    Saltyhero13
    This product hasn't been released yet.
  6. Feb 4, 2024 at 7:23 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    An article I saved from awhile back concerning TB spacers. Interestingly I have a spacer of sorts. I have stacked adapter plates for the 95mm TB, about an inch total. I have not noticed ant seat of pants difference but I'm running the SC and non boost drivabilty seems the same.
    https://tundraheadquarters.com/stay-away-from-throttle-body-spacers/
    The AES plenum runner should give some increased low rpm torque. Plus being able to add nos or water/meth injection for each cylinder. They seemvto work on other platforms so I don't see why we wouldn't gain some torque too.
    Wynnded, Saltyhero13 and reywcms like this.
  7. Feb 5, 2024 at 4:46 AM
    Saltyhero13
    Great article. I doubt a TB spacer will do much for a supercharged Tundra for the similar reasons stated in the article. Any swirly air generated by the TB spacer is being manipulated by the rotors/screws of the blower before it gets in the engine.
    On one of the Harrop videos they use it to squeeze out some extra HP.
