Reverse light LED bulbs
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sleeper16plat, Feb 3, 2024.
  1. Feb 3, 2024 at 6:35 PM
    Sleeper16plat
    Sleeper16plat [OP] New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Finally got around to replacing the reverse lights with LED bulbs.
    Driver side is LED, passenger is oem.
    AggieSigGuy likes this.
  2. Feb 3, 2024 at 7:44 PM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    Which bulbs did you use? I have tried two different brands and both fit really lose in the socket.
    Toyotaloyalgal and AggieSigGuy like this.
  3. Feb 3, 2024 at 8:51 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
  4. Feb 4, 2024 at 4:05 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
  5. Feb 4, 2024 at 6:27 PM
    Psam
    Psam New Member
    Philadelphia
    2019 Tundra Trd Pro voodoo blue
    I can’t see a difference lol. It must be the lighting.
    Retired...finally likes this.
  6. Feb 5, 2024 at 12:49 PM
    Sleeper16plat
    Near Vancouver
    Ya, sorry, not the best time of day to take pictures oflights. You can see the color temp difference in the pic. The LED is a colder white, the OEM bulb looks yellowish compared to it. Can confirm that the LED's do improve lighting for backing up at night!
    Can't even remember, I ordered them off Amazon so far back that they don't even show up in my orders.
  7. Feb 5, 2024 at 5:02 PM
    agrestic1
    2016 CrewMax
    Mine. Before and after..
  8. Feb 6, 2024 at 5:30 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I put LEDs in my reverse lights and they do a good job to the sides but not straight back where I need the light. I think reverse lights are primarily a warning to other drivers that the vehicle is backing up. I added 4" pods in my bumper and there is a huge improvement to visibility in reverse.
    ConcordCarlos likes this.
  9. Feb 6, 2024 at 7:55 AM
    OhioCBtundra
    OhioCBtundra New Member
    New 2021 calvary blue CM SR5 owner and was curious if you can just replace the reverse lights w/ LEDs (mine is halogen) without needing any harness or wiring additions for proper use
  10. Feb 6, 2024 at 10:53 AM
    Sleeper16plat
    Near Vancouver
    Yes, absolutely can. LED bulbs just plug in. Takes 5 minutes. Two torx bolts to remove the tail light assembly and get access to the bulbs.
  11. Feb 6, 2024 at 12:17 PM
    OhioCBtundra
    Perfect thanks for the info and will be doing it for sure!
    Toyotaloyalgal likes this.
  12. Feb 6, 2024 at 12:32 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    When I had OEM tail lights, I used Sylvania Zevo LEDs and they rocked.
  13. Feb 6, 2024 at 1:15 PM
    agrestic1
    2016 CrewMax
    Hardest part is pulling off the tail lamp assembly. Also don't forget the LED bulbs are polarity sensitive, meaning they will light only when installed one way..positive and negative..
  14. Feb 6, 2024 at 5:58 PM
    Sleeper16plat
    Near Vancouver
    yes, tail lights pull away from truck to side to remove, not to the back like you would expect. yutoob a vid to see where the pins are and which way they point.
  15. Jun 23, 2024 at 6:55 PM
    Skoosavich
    Skoosavich New Member
    I just changed out the backup lights. That was easy but when I bought led bulbs for the brake light, the bulb did not fit the housing like the halogen. Way too loose. Curious what brand any of you may have gotten off Amazon for this? Changing out all bulbs. Least I could do after front, rear brakes, shocks, rack pinion and ball joints. Sheessh but 310,000 miles and going strong
  16. Jun 24, 2024 at 8:11 AM
    BushBandit
    BushBandit New Member
    2021 Tundra Limited TRD
