3rd Gen Suspension Lift - MEGA THREAD
Discussion in 'Suspension' started by KroppDuster, Jun 10, 2022.
  1. Jan 22, 2024 at 9:25 AM
    #1621
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    did you do that bottom hole for 1inch?
  2. Jan 23, 2024 at 5:57 AM
    #1622
    Rampking01
    Rampking01 New Member
    Had a dealer quote me $3,700 to install the TRD 3" lift. Seems a bit much from others I've seen on here. He did tell me I could order the kit myself and save me about $300. That would put it in the $6,400 range for complete install. UGH! I think I will look around the DFW area more and see if I can find a better deal.
  3. Jan 23, 2024 at 5:59 AM
    #1623
    abgiles
    abgiles New Member
    2022 CrewMax Limited - Wind Chill Pearl
    TRD Grille w/Rough Country LED, Tuffskinz products,
    Are you sure that isn't with the lift purchase included? I'm currently in Mississippi and the local dealer quoted $4150 purchase and install..
  4. Jan 23, 2024 at 6:15 AM
    #1624
    Rampking01
    No that was total. I calculated 2 men x 2 days so it would be about $115 hr for labor. Seemed extremely high from others I have heard from. Maybe I need to run up to Mississippi and get it installed! I'm definitely looking around to see what others in this area are charging.
  5. Jan 23, 2024 at 6:48 AM
    #1625
    abgiles
    abgiles New Member
    From what I've read here and on Facebook, 1200-1500 average for installation. The dealer I went to was going to discount the lift to $2550 and charge $1250 for installation. I've seen people here talk about doing it by themselves in their garages in 2 days, and they don't have the tool access, lift, etc. 2 guys for 2 full days is nuts.
  6. Jan 26, 2024 at 4:23 PM
    #1626
    tamadabee128
    tamadabee128 New Member
    Just got mine. What are the biggest differences you notice with it?
  7. Jan 29, 2024 at 8:55 PM
    #1627
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    Installed my Dobinsons IMS kit . 3” from and 2” rear with the Dobinsons trac bar, JBA upper control arms and extended the rear brake lines and the front ones next weekend . Icon front sway bar drop and bump stops. I did it in my garage in about 8 hours taking my time . Not a hard install really except for rear springs . To aid in that I unbolted passenger side upper control arm since it hits gas tank at that drop . I had a preload collar lift before and that is a nightmare ride compared to this . Truck sits great
    mayan, iiawah808, youthinasia and 6 others like this.
  8. Jan 30, 2024 at 5:17 AM
    #1628
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    For me the UCA install is way more pain in the ass to install than the rear springs. Finagling with the plugs and the long bolt, very time consuming.
    SC4333 and Durtywrench like this.
  9. Jan 30, 2024 at 12:10 PM
    #1629
    Durtywrench
    Lou
    23 Tundra platinum
    None
    I had a different experience . Probably only an hour to do upper control arms but rear springs I just needed an anchor and a ratchet strap to pull down . I was lucky on passenger side , I used my leg to pull down axle and bench pressed the spring in lol
  10. Jan 30, 2024 at 1:12 PM
    #1630
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    Got in Dobinson 2/1. Going to try to get them on in the next month. Anyone know if you need Dr. KDSS with just a 1inch lift in rear? Brake lines?
    TundraTT likes this.
  11. Jan 30, 2024 at 2:36 PM
    #1631
    TundraTT
    TundraTT Full Send
    23 Taco Trail 97 FZJ80 68 Goat
    Good choice. With 1” I wouldn’t worry about pan hard bar correction. Extended brake lines are a good idea if you think you’ll be doing anything past medium flexing. Otherwise that kit is completely bolt on and go
    Durtywrench and Brian422[QUOTED] like this.
  12. Jan 30, 2024 at 2:38 PM
    #1632
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    No its going to be my Tacoma hauler/ Daily. Probably will only ever see dirt roads or forest service roads. The Tacoma is the trail rig.
  13. Jan 30, 2024 at 3:30 PM
    #1633
    TundraTT
    TundraTT Full Send
    Then you’re all set! Extended rear bumpstops or spring helpers will help you out with towing. That’s the only other thing I can think of
    Brian422[QUOTED] and Durtywrench like this.
  14. Jan 30, 2024 at 4:06 PM
    #1634
    Slowbuilt
    Slowbuilt New Member
    Oregon Coast
    24 Limited Off Road
    I installed the dobinsons ims 2/1” last weekend. Haven’t measured to be sure but seems more like 1 1/2” or even 2” in the rear. Brake lines and speed sensor wires need some love for sure. Super tight at full droop. I made some relocation brackets, spaced wire mounts up and tweaked stuff around until I felt good about it. I’m adding icon sway bar spacer because the links seemed a little bound even sitting on the ground. The shock performance is much preferred over my wife’s trd kit or stock.
    dagsom, mayan, Dfrink and 2 others like this.
  15. Jan 30, 2024 at 5:39 PM
    #1635
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    What size tires?
  16. Jan 30, 2024 at 6:07 PM
    #1636
    Slowbuilt
    Oregon Coast
    24 Limited Off Road
    315 70 17 Bfg ko2. (basically 35x12.5 but about 10% lighter). Same as my wife’s.
    dagsom and Brian422[QUOTED] like this.
  17. Jan 30, 2024 at 8:05 PM
    #1637
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    Wow that’s same setup I’m gonna have lol
  18. Jan 30, 2024 at 9:08 PM
    #1638
    Slowbuilt
    Oregon Coast
    24 Limited Off Road
    It fits easy. Standard procedure :)
    Brian422[QUOTED] likes this.
  19. Jan 31, 2024 at 6:06 AM
    #1639
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    you got any pics from the backside? ;)
  20. Jan 31, 2024 at 7:08 AM
    #1640
    Slowbuilt
    Oregon Coast
    24 Limited Off Road
    Yaboy and Brian422[QUOTED] like this.
  21. Jan 31, 2024 at 7:17 AM
    #1641
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    Black truck have same lift? Looks taller than a 2/1 lol.
  22. Jan 31, 2024 at 7:35 AM
    #1642
    Slowbuilt
    Oregon Coast
    24 Limited Off Road
    She has the trd 3/2. It’s actually more like 2 1/2” in the front.
  23. Jan 31, 2024 at 7:49 AM
    #1643
    81trekker
    81trekker New Member
    2024 Platinum 4x4 iForce Max
    5k miles later and couldn’t be happier with the King 3.0ibp/Built Right combo!
    MartinOffroad, Yaboy and Vipers28 like this.
  24. Jan 31, 2024 at 7:51 AM
    #1644
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    She has a good looking truck, sorry not silver fan... :)
  25. Feb 1, 2024 at 9:52 AM
    #1645
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    Swaybar yanked for a 600 mile off-road trip. Thing is smooooth now.
    KroppDuster[OP] likes this.
  26. Feb 1, 2024 at 10:11 AM
    #1646
    KroppDuster
    KroppDuster [OP] A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    Bilstein 5100s
    I might yank mine off this weekend and give it drive to see how/if it smooths a few areas out.
    I've got a vibration that is driven by road feedback in very specific situations/sections of roads, usually around 40-45mph. It's occurred from the beginning from the stock suspension all the way up today. It's really not a big deal, but it's something I've chased off & on since I owned the truck. At this point, my current theory is the sway bar is amplifying this road feedback.
    I've swapped various suspension components including coils and shocks, road force balanced my tires multiple times (& rotated them front to back & cross), and had the truck aligned by 2 different shops. It's not a ball joint issue so my next step is to see how it rides without the sway bar. :)
  27. Feb 2, 2024 at 10:02 AM
    #1647
    Morning_Rock
    Morning_Rock New Member
    Nice rig! which coil springs are you running in the rear?
  28. Feb 2, 2024 at 10:07 AM
    #1648
    81trekker
    Factory air ride and it’s probably my favorite part about the truck since I use it to tow my off road truck… truck self levels
  29. Feb 3, 2024 at 6:56 PM
    #1649
    Wmitch352
    Wmitch352 New Member
    Installed Dobinsons 3/2 and set the front to 2.75 to maintain a little rake. I used the panhard bar correction kit for rear and pulled the front sway bar. Need to put it back on for safety but man does it feel nice without. Used the spring compressor attached in the link below which made installing rear springs less of a PITA.
    17x8.5 with 0 offset on 35x12.5
    I need some skid plates but unsure if the talons garage plate is compatible with the icon sway bar drop kit. Looks like talons is made for the TRD lift. Talons couldn’t confirm that it will work via email.
    ABN Coil Spring Compression Tools... https://www.amazon.com/dp/B07S4MV7KP?ref=ppx_pop_mob_ap_shareIMG_9497.jpg IMG_9285.jpg IMG_9523.jpg IMG_9526.jpg IMG_9495.jpg
  30. Feb 3, 2024 at 7:34 PM
    #1650
    KroppDuster
    Bilstein 5100s
    How are was setting the ride height of the front coils? I've heard the Dobinsons are a little bit of a pain to set since (technically) you're not supposed to adjust them on the vehicle. I've read where some guys get by with supporting the front to let the tires droop and then adjusting them that way.
    I want to swap out my front Icons with heavier coils and I've been close to pulling the trigger on Kings, since I can adjust them on the vehicle. However, I run a complete Dobinsons setup in the rear and I've been really impressed. My only hesitation has been setting the ride height.
    Wmitch352[QUOTED] likes this.
