Bed Step
Discussion in '1st Gen Tundras (2000-2006)' started by Pastor Herb, Jul 17, 2017.
  1. Jul 17, 2017 at 1:40 PM
    Pastor Herb
    Pastor Herb [OP] New Member
    Herb
    2004 Tundra Extended Cab
    Hi Folks. I just bought and mounted a truck box in the bed of my 2004 extended cab Tundra, but it's not easy to reach inside. So I've been looking at bed steps. I'd like to mount a bed step in front of the rear wheel well, BUT there's a leaf spring mount where I'd attach to the frame.
    Any ideas... or has anyone mounted a bed step there on a good old Tundra?
    :help:
  2. Jul 17, 2017 at 2:33 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    NFAB 6 step nerf bars an option for ya?
  3. Jul 17, 2017 at 3:03 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Herb?? As in formally know as Herbicidal???
  4. Jul 17, 2017 at 5:29 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    AMP research makes them for newer Tundras, but don't list them for 1st gen. Of course north of the rear wheel well, you are starting to get into running board territory. Why not just add some running boards?
  5. Jul 17, 2017 at 5:51 PM
    Pastor Herb
    Herb
    Thanks for the ideas. I was looking at steps as the more 'economical' option, but running boards or 6-step nerfs could work.
    {No, I've never been known as Herbicidal, but in college some called me 'Herb-less'.}
  6. Jul 17, 2017 at 6:13 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Definitely look into AMP
    But personally, I wouldn't mind a third step nerf bar or running board
  7. Aug 8, 2017 at 11:18 AM
    tacoguybill
    tacoguybill The Burrito Bandido
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    I picked up a set of used running boards for $80 on facebook marketplace, otherwise you could probably find some cheap ones on ebay for like $100
  8. Oct 18, 2017 at 10:54 AM
    Black Rollover
    Black Rollover New Member
    2004 Tundra Double Cab Ltd
    I have the AMP bed step. It is from the 2007 up tundras. I have to drill out one hole in the frame a bit more to mount the step. I unbolted the swing down part from the arm and eyeballed it. Found one hole in the frame spot on and drilled for the second hole. I love it. just little foot pressure and it swings down and pull up with my foot and pops back up.
  9. Dec 7, 2023 at 9:39 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Super old thread but instead of starting a new one I searched and found this. Thanks for these details. I want a bed step like this. My dad has one on his Titan and it's pretty useful. Not sure you'll even see this post
    If anyone else has one installed and sees this post, let me know if you use this brand or a different one. I can't seem to find one specifically made for the first gen Tundra, so I'll probably go with this and modify it like you did.
  10. Dec 7, 2023 at 10:06 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I have the same step on my Ford F-150. Very handy and tucks nicely out of the way.
    dirtnsmores likes this.
  11. Dec 8, 2023 at 3:08 PM
    flyfisher
    flyfisher Member
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    I have an AMP bed step on my '05 Tundra. Get the 2nd Gen model and easy to modify. Great to have!
  12. Dec 8, 2023 at 5:03 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
  13. Jan 25, 2024 at 9:30 PM
    dirtnsmores
    Southern CA
    Still looking for one on the marketplaces. Trying to avoid buying brand new but I may have to.
  14. Jan 26, 2024 at 2:04 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Who makes that? I like it.
  15. Jan 26, 2024 at 5:22 AM
    abcinv likes this.
  16. Jan 26, 2024 at 6:39 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Get some custy rock sliders with a kicker it’ll look great AND be super functional
  17. Jan 26, 2024 at 6:44 AM
    dirtnsmores
    Southern CA
    Definitely getting some soon. But I'm gonna have a truck camper on mine and retaining my tailgate so I want something to help step up onto the tailgate quickly
  18. Feb 3, 2024 at 9:09 AM
    PhilSR5
    PhilSR5 New Member
    Phil
    Alabama
    2018 Grey Tundra SR5 TRD
  19. Feb 3, 2024 at 10:15 AM
    dirtnsmores
    Southern CA
  20. Feb 3, 2024 at 10:19 AM
    PhilSR5
    PhilSR5 New Member
    Phil
    Alabama
    Have a look here for parts description
    • 【OE Quality】 HSPSWIFTER Rear Bed Step Lightweight, high-strength aluminum die-cast construction with reinforced nylon step pads, ribbed, non-slip step surface. Hands-free operation and easy adjustment. Capacity 300 lbs. Features weather-resistant, black anodized, and special powder-coated finishes for long-term durability.
    dirtnsmores[QUOTED] likes this.
  21. Feb 3, 2024 at 11:03 AM
    dirtnsmores
    Southern CA
    Thanks. Looks pretty good. I asked because some of the descriptions on other one similar priced say all metal, but then the reviews say there was plastic that eventually broke in some of the small areas
    PhilSR5[QUOTED] likes this.
