SR5 Footwell lights?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Tiggrdj, Jan 28, 2024.
  1. Jan 28, 2024 at 9:30 PM
    Tiggrdj
    Tiggrdj [OP] New Member
    2017 Inferno Crewmax SR5
    Not Yet
    I'm intending to install some better interior lighting, specifically in the footwells. I found the post in the "mods and tutorials" about it but my question is about the driver's footwell light. My truck does not appear to have an existing footwell light to attach to so my question is whether or not the 2017 Crewmax SR5's all come with a footwell light or if that is only on the higher trim levels?
  2. Jan 28, 2024 at 9:52 PM
    Corsa1
    Corsa1 New Member
    2021 Cavalry Blue Crewmax
    French Avocado likes this.
  3. Jan 28, 2024 at 9:58 PM
    RobertD
    Robert
    DFW, Texas
  4. Jan 28, 2024 at 10:09 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    Did you buy the truck new or used?
    Your SR5 should have the little tiny foot well light on the driver's side under the dash.
    If not, I'd bet there is at least the wiring for it..
    It's a very small plug with a beige and lilac wire.
    WFD473, bulldog93 and French Avocado like this.
  5. Jan 28, 2024 at 10:10 PM
    Tiggrdj
    Not Yet
    Thanks Corsa1, I did a little digging and found mine, burned out and not in the position it was intended to be in. Time to order some LEDs. Thanks Again
    1lowlife- I bought the truck used with <55k on it from my son-in-law. He isn't bothered by little things not working properly but my OCD is not letting me leave stuff un-repaired. Initially I assumed that I didn't have a footwell light because there was nothing in the hole in the dash but I found it up under the knee cover so I have a place to start.
  6. Jan 28, 2024 at 10:12 PM
    French Avocado
    Utah / Wyo
    VLEDs work great. Nice kit for front and back
    WFD473 and 1lowlife like this.
  7. Jan 28, 2024 at 10:21 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Glad you found it.
    I just used some cheap Amazon strips for the front and some small LEDs for the rear.
    If I had it to do over again, I would probably go with VLEDs as @French Avocado suggested..
    They make awesome stuff..
    14-21 TOYOTA TUNDRA LED FOOTWELL KIT (vleds.com)
  8. Feb 2, 2024 at 4:15 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
  9. Feb 2, 2024 at 5:07 PM
    biebs96
    PA
    I used two led strips meant for inside of a pick up bed. Very bright, and they fade on/off because I wired them to the little bulb plug on the driver side.
