Aux lighting switches?
Discussion in '3rd Gen Tundras (2022+)' started by SDHNTR, Feb 1, 2024.
  1. Feb 1, 2024 at 2:47 PM
    SDHNTR
    SDHNTR [OP] New Member
    Planning on installing a lightbar. Can I use one of the empty switches on the same switch bar as the hazard lights? There seems to be some unused switches there so would be nice to use them vs drilling new holes. How hard are they to access?
  2. Feb 1, 2024 at 3:34 PM
    MaxPayne3
    MaxPayne3 New Member
    2024 Lunar Rock SR5 Crew Cab
    Just starting out but never will be done
    Unfortunately no. I had my center console apart and the switch panel is one large enclosed module with a single plug. It's not like the switch panel to the left of the steering column that has individual switches and plugs. Do you not have any blanks on the panel left of the column? There are some aftermarket switch companies that make switches that fit in those blanks.
  3. Feb 1, 2024 at 3:54 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    left of the steering wheel -
  4. Feb 2, 2024 at 7:53 AM
    MaxPayne3
    you have no pic posted
  5. Feb 2, 2024 at 8:13 AM
    MaxPayne3
    Here is how I set mine up
  6. Feb 2, 2024 at 8:16 AM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Find any 24 Tacoma part numbers yet?
  7. Feb 2, 2024 at 8:56 AM
    SDHNTR
    Is that panel only on the TRD Pro?
    ryanwgregg likes this.
  8. Feb 2, 2024 at 8:59 AM
    SDHNTR
    OK, thanks. I assume that panel is easy to pop out and gain access to the back? And where did you find the individually labeled switches? Looks clean.
  9. Feb 2, 2024 at 9:02 AM
    SDHNTR
    Sorry, you're right. That question should've been directed to @MaxPayne3
    ryanwgregg[QUOTED] likes this.
  10. Feb 2, 2024 at 9:12 AM
    MaxPayne3
    Very easy to pop out. I got all the switches except the TRD light switch from Air On Board 4x4- https://www.aironboard.com/online/products/switches/toyota-push-switches.html?p=2&toyota_model=454
    They illuminate as close to OEM as I have found. The TRD light switch was from a different vendor whom I won't name because it was advertised as a direct fit and that vendor has a pretty bad reputation on this forum (I had already bought the switch before joining this forum BTW), but I had to do a lot of modification to get it to fit.
  11. Feb 2, 2024 at 9:16 AM
    SDHNTR
    Thanks! Very helpful.
    MaxPayne3[QUOTED] likes this.
  12. Feb 2, 2024 at 9:19 AM
    SDHNTR
    Does anyone happen to have a pic of that switch panel from a 3rd gen 1794 edition?
  13. Feb 2, 2024 at 9:29 AM
    jctmundra
    Northern VT
    Post 3 is 1794
  14. Feb 2, 2024 at 9:41 AM
    MaxPayne3
    The switch panels have the same "skeleton" panel for all trim levels, but have different switches based on the trucks options, see @ryanwgregg post above. If you have blank switch spots available then you can use the aftermarket AOB 4x4 switches (with the exception of the auto headlight and TRD Light bar or auto steps switch location as they are a different size)
  15. Feb 2, 2024 at 9:54 AM
    jctmundra
    Northern VT
    Does this?
  16. Feb 2, 2024 at 10:02 AM
    SDHNTR
    Great. Thanks all!
