  1. Feb 2, 2024 at 7:44 AM
    I need receipts on that. I never bitch about mileage. Well, unless it's lack of getting it. I'm half tempted to drive my truck to work half the week to put miles on it.
  2. Feb 2, 2024 at 7:49 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Could've sworn you were complaining about MPGs last night. Had a chart and everything. 12mpg on one tank, 9mpg on another
  3. Feb 2, 2024 at 7:49 AM
  4. Feb 2, 2024 at 7:54 AM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Please be sure to post the order of the bushings gromets washers amd caps when your done please.
  5. Feb 2, 2024 at 7:55 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I'm probably just going to do em in what ever order Casey did em in haha. I might crawl under my 06 and try to see how I did my 5160's.
  6. Feb 2, 2024 at 7:56 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Maybe
  7. Feb 2, 2024 at 7:59 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Well, rear OEMs that were pretty worn at around 80k when I started building the truck, Toytec Boss 10" (possibly rebranded Eibachs?) which had decent valving, and those did me well and lasted a few years until they started to leak. Replaced them with Billy 5100s as a band-aid and absolutely hated the valving on them; took them off after one trip. Have been running 8" Fox 2.0s for awhile now, and they're doing the job.
  8. Feb 2, 2024 at 8:39 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    please please please tell me 'chassis ears' is code for small children. @metalpete I think I may know someone that would gladly lend you a couple for the task
    Hey, you might wanna either shim or strap your known loud ass clunk,when clunk searching... just a thought.
    And WTF is a transfer case?
    Unless they're premium shocks, then they get rebuilt
  9. Feb 2, 2024 at 8:44 AM
    VR6T
    Must hate your truck I do mine every 10,000 miles (said with a pinky out on beer bottle nose in air attitude)
    :rofl::spending::rofl:
    artsr2002 and oscardog86 like this.
  10. Feb 2, 2024 at 8:47 AM
    VR6T
    Apparently I never ordered a new driver side headlamp as well. I just got done going through my garage looking for the other one I swore i bought. Apparently I did not buy a set.
    You know youre loosing your mind when youre looking for things in places they couldn't possibly be. Hour and a half ill never get back.... So that shit along with the brake pads will be here Monday
    455h0le_dachshund and oscardog86 like this.
  11. Feb 2, 2024 at 8:55 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Peasant, how doth one order a lamp to be delivered in solitaire?
  12. Feb 2, 2024 at 8:59 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    You know you're losing your mind when you find shit in places it shouldn't possibly be. Like a set of keys in a toolbox, or the daily mail in a fridge. Just don't use your phone light to search for....your phone
    bmf4069, JasonC., BroHon and 3 others like this.
  13. Feb 2, 2024 at 9:03 AM
    One of my old habits was searching for my pen while it was tucked behind my ear.
    bmf4069, VR6T and oscardog86 like this.
  14. Feb 2, 2024 at 9:04 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Transfer case is a vestigial organ, of sorts, nothing to worry about ;). I was in a hurry to test out the camera before it started to get dark. Besides, I knew it was my tailgate... you was just guinea pigs, the final draft will be handed in by Monday. :cool:
    Also, my boy is just brave enough to ride under the truck while in motion. I'll ask him!
  15. Feb 2, 2024 at 9:07 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Today is "Get off my ass and fix some little annoying shits that been on my list for entirely too fucking long" Day.
    First up are dash bulbs.
    Already knocked out the blinking climate control LED on the 06 this morning. Replaced it with an incandescent for now. I didn't like how the green led made the cold/hot section look anyways. The others can remain green LED, so everything still matches. I almost put the green condom on he incandescent bulb, but didn't. Also installed the missing bolt to my head unit while in there.
    Next is replacing a red LED behind the right side of gauges on the 03. I had a bunch leftover from the previous T100 and Tacomas, and I already tested the two im considering using. So now I just gotta make sure I know how to take apart the tundra dash properly. It's just a little different from the previous trucks, but similar. I just don't want to break any plastic bits.
    I might remove the PO's CB/PA set up while I'm in there. Hell I might rip out the stupid Windows touch screen and install my Pioneer while in in there..
    Hell maybe I should replace my. Tailgate handle and wire the backup camera while I'm at it.
    Then I gotta install my replacement Desert Armor yellow LED pod.
    Maybe the 5100's will show up before I run out of gas.
    oscardog86 likes this.
  16. Feb 2, 2024 at 9:11 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Ok apparently it's about 100% easier to get our tundra gauges removed than on my previous Toyota trucks haha
    The Black Mamba and VR6T like this.
  17. Feb 2, 2024 at 9:18 AM
    If you know you're losing your mind, it suggests you still have some mind left.
    BroHon, CodyP, VR6T[QUOTED] and 2 others like this.
  18. Feb 2, 2024 at 9:26 AM
    VR6T
    Tis a great question me Lord.
    RUSTYNUTS[QUOTED] likes this.
  19. Feb 2, 2024 at 9:30 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    and he's gonna say "sounds like its comin from the tailgate dad!"
  20. Feb 2, 2024 at 10:12 AM
    metalpete
    ID
    LOL! Honestly, that would make me the proudest papa to hear him say that.
    He pretends to work on his tractor and fire truck sometimes... "Dad, I think it's the ball joints...Could be the axle... do you think it's in the front end?"
    :headbang: Raising him right.
  21. Feb 2, 2024 at 10:52 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Damn thats pretty cute lol
  22. Feb 2, 2024 at 11:34 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Dash light fixed. The issue was there wasn't a bulb!
    CB deleted.
    Windows radio is out.
    Pioneer radio is ready to go. Just have to wire the harnesses together.
    But I did run into a weird issue. The mounting for the radio is holding me up, because the bolts from the previous radio won't fit the holes of the new one.
    This radio was in my other truck before without issue. I've never had a problem with this part before. Any advice?
  23. Feb 2, 2024 at 11:53 AM
    VR6T
    What pioneer did you go with?
  24. Feb 2, 2024 at 11:53 AM
    Pics of said bolt holes. Like the side of the radio where the brackets mount, the bolts don’t have the same thread size? Or the holes are in the wrong location?
    BroHon likes this.
  25. Feb 2, 2024 at 11:56 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    The one that's been in my 06 already, then back into my parts pile for a different Pioneer. I been planning to put it in my 03 for a couple years... No big deal.
    VR6T[QUOTED] likes this.
  26. Feb 2, 2024 at 12:00 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Different size thread on the holes. The bolts I have won't even start. I might have to remove my 06's Pioneer and pull one of its bolts then run to the hardware store. The shitty thing is I was already in that trucks dash this morning!
  27. Feb 2, 2024 at 12:00 PM
    VR6T
    Hoarding I see lol
  28. Feb 2, 2024 at 12:05 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    So the Pioneer currently in the 06 is and AVH4000NEX and the one I'm wanting to install in the 03 is an AVH601EX
  29. Feb 2, 2024 at 12:08 PM
    And the brackets are on the right side and in the right position?
  30. Feb 2, 2024 at 12:09 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Yeah the bracket are good. Looks like I need these:
    Any idea what that means? Haha
