Timing mark alignment
Discussion in '1st Gen Tundras (2000-2006)' started by albru2, Oct 13, 2023.
  1. Nov 3, 2023 at 3:25 PM
    Sorry if I'm missing something, but is the truck running rough after, or have you not fired it up yet?
    If the difference on one cam is less than one-third tooth, I think I'd probably just accept it and fire it up. But I'm not the expert, I haven't done the TB/WP on my 2UZ yet. Defer to input from others.
  2. Nov 3, 2023 at 5:02 PM
    albru2
    albru2 [OP] Keep it simple stupid
    2002 Tundra Limited 4.7l 4WD AC
    yeah that was my approach - I couldn't see how to get it any better so I fired it up. seems to run ok just idles rough. Haven't seen how the fuel consumption is yet though.
  3. Nov 3, 2023 at 5:26 PM
    Was idle rough prior?
    Is idle low, or just rough? If you tap the gas, does it smooth out?
    Any unusual sounds?
    Any codes pending or set?
  4. Nov 4, 2023 at 9:39 PM
    Pnwtundy
    Pnwtundy New Member
    04 DC SR5 TRD, V8/4WD + LSD/Tow
    Man, looking from your pictures your timing marks look beautiful. I mean pictures can be deceiving but it looks like you're less than 1/4 of a tooth off? It looks good. I would bet my money on something else. Re-trace, and re-re-trace everything you did when you did the timing belt and coils. I would not change anything else (at least, i would TELL you not to change anything else, but honestly i would fall for the same trap) until you can narrow it down. IIRC having just done a timing belt change, many of the vacuum lines that you take off are near the passenger side of the engine, make sure you've got all them accounted for.
    albru2[OP], windblown101 and shifty` like this.
  5. Nov 5, 2023 at 5:33 AM
    Found this old picture from when I did mine. Angle is off a little but appears the marks are ever so slightly off on my right cam too. Mine runs great.
    Pnwtundy, albru2[OP] and shifty` like this.
  6. Nov 5, 2023 at 7:52 AM
    albru2
    thanks Pnwtundy, I appreciate the feedback. Good to hear that those marks aren't standing out as a necessarily the problem.
    Pnwtundy[QUOTED] likes this.
  7. Nov 5, 2023 at 7:55 AM
    albru2
    appreciate you posting that, that is more evidence that I need to hunt down all other angles first.
  8. Nov 5, 2023 at 9:13 AM
    If you're positive you've made it thru a relearn cycle, and you're not popping any codes, and it's idling chunky/low, the advice above about poring over (and potentially replacing) every vacuum line is worthwhile. Before that, put your hands on everything you touched, every connector, unplug, check for bent pins, re-plug. Make sure you properly secured the crank position sensor out of harm's way, since it's such a common mistake.
    Pnwtundy likes this.
  9. Feb 1, 2024 at 11:53 AM
    albru2
    Just closing the loop on this thread for future posterity: I ended up making a smoke tester and didn't find any leaks. Was debating between buying a scan tool and seeing if I could find anything with fuel trims and taking it in to a pro. Took it into a great local shop the specializes in Toyotas and they found a misfire in cylinder 7 that was mild enough to not throw a code. They pulled the plug and found that the gap was too tight. Swapped it to another cylinder and the misfire followed. Replaced the plug, (or re-gapped, not sure) and all is well! I must have messed up the gap somehow when installing. Very happy that's all it was and thanks to everyone here for all your input!
    tvpierce, Mustanley, w666 and 4 others like this.
  10. Feb 1, 2024 at 12:58 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    9 times out 10. It’s something simple af
  11. Feb 1, 2024 at 9:12 PM
    Pnwtundy
    Pnwtundy New Member
    Thank you for posting the resolution! :cheers:
  12. Feb 2, 2024 at 7:35 AM
    albru2
    Complexity bias is real
