  1. Jan 30, 2024 at 2:20 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Just in case you're looking for your keys...
  2. Jan 30, 2024 at 2:22 PM
    SAGE63
    San Diego County
    Hey that's where I always leave my keys too....
    D3VA and JMGmanAZ[QUOTED] like this.
  3. Jan 30, 2024 at 3:37 PM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    Molle type visor
    The Marine patch is for my mentor who served in Vietnam 3 division Marine Company
    He was one of the guy who went in the tunnels
    The anchors are from my retirement
  4. Jan 30, 2024 at 4:10 PM
    AZBoatHauler
    So.Arizona
  5. Jan 30, 2024 at 4:16 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    bulldog93 and Tundra234[QUOTED] like this.
  6. Jan 30, 2024 at 4:24 PM
    SAGE63
    San Diego County
    Congrats Senior....
  7. Jan 30, 2024 at 4:50 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Thank You
  8. Jan 30, 2024 at 5:07 PM
    Get one of these if it sits alot.
    https://no.co/genius2d
    Jaypown and bulldog93 like this.
  9. Jan 30, 2024 at 6:18 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Finally upgraded the air system with larger diameter lines, and to each wheel well a schrader valve. The Smittybilt compressor is still under the hood and already runs cooler. I now just carry four short hoses to air up after offroading. I kept the rear quick connect to help others air up when needed. If you do this get nylon lines, I originally used Polyurethane and they didn’t stand up to the heat.
  10. Jan 30, 2024 at 7:58 PM
    Geno, I'm surprised that air line isn't blue.:p
  11. Jan 30, 2024 at 8:37 PM
    sbxx312
    sbxx312 New Member
    Thanks. I hooked it up to the Battery Tender. No one wants to ride in the Taco this winter.
    bulldog93 likes this.
  12. Jan 30, 2024 at 9:17 PM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    From my research, it should be part #55064-0C011-C4. All the descriptions for the search results of that number say, "With leather trim, black/red."
    heyacker[QUOTED] likes this.
  13. Jan 30, 2024 at 9:38 PM
    55064-0C010-C4
  14. Jan 31, 2024 at 3:54 AM
    BlueRibbon4x4
    Geno
    :rofl::rofl:
  15. Jan 31, 2024 at 4:19 AM
    :fistbump:
    BlueRibbon4x4[QUOTED] likes this.
  16. Jan 31, 2024 at 4:59 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    2020 wireless carplay issue:
    like I said earlier, it works great.
    however, when I drive to work, it disconnects every time at this location. both to and from work.
    what type of signals can interrupt a Bluetooth connection?
    the road circled is beltway 8
  17. Jan 31, 2024 at 5:19 AM
    koditten
    Kirk
    Midland of the Mitten
    Interesting. Do other people drive thru there experience the same thing?
  18. Jan 31, 2024 at 5:20 AM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    On way list of things to do to the Tundra in the spring.
  19. Jan 31, 2024 at 5:20 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    no idea. but it is completely replicate-able. happens everyday.
  20. Jan 31, 2024 at 5:23 AM
    Damie Street
    Edsel
    Aliens!
  21. Jan 31, 2024 at 5:39 AM
    centex
    centex New Member
    Probably just high RF interference. Maybe there's a transmission tower or something leaking some signal or something.
  22. Jan 31, 2024 at 5:45 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Noticed a light ping pong sound at high speeds (60mph+). slSeems to be coming from my passenger side. Looked at my air filter and box but didn't see anything. It's like an acorn or something is trapped somewhere and ping pings around occasionally when experiencing a strong enough air flow.
    Also, replaced my battery.
    BlueRibbon4x4 likes this.
  23. Jan 31, 2024 at 5:59 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    There’s a spot near me that does the same thing. I’ve always assumed an industrial park off the highway was using an RF band that caused the interference.
    nobodyintexas[QUOTED] likes this.
  24. Jan 31, 2024 at 6:37 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
  25. Jan 31, 2024 at 6:40 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    good eye.
    I'll make note of that thing when I pass by today.
  26. Jan 31, 2024 at 6:41 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Drove it to work (again), but today we have a Tundra corner in the parking lot.
    I should have paid more attention. To the right, there are two tacos parked as well.
    equin, AGTundra, mgm16trdpro and 10 others like this.
  27. Jan 31, 2024 at 6:41 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    Light pole
  28. Jan 31, 2024 at 6:46 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    I have an aftermarket Android Auto in another vehicle and mine does the same thing every time I hit the curve below so I know the frustration. I believe my culprit it a bit more obvious:
  29. Jan 31, 2024 at 7:11 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Airports. Does it to mine (AA-Wireles) every time.
  30. Jan 31, 2024 at 9:55 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
