Getting gears in this next week.. LSD or not?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Marshwalker, Dec 10, 2023.
  1. Jan 30, 2024 at 5:20 PM
    centex
    centex New Member
    Gained a solid 2mpg towing my sxs going from stock 4.30 to 5.29’s. Before I couldn’t hold 5th gear and had to run in s4 to maintain 65 on flat ground. Now I set the cruise at 70 in s5 and it just does its thing.
    bflooks, Saltyhero13 and FrenchToasty like this.
  2. Jan 30, 2024 at 5:53 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Be mindful that there are the first 500 miles break-in procedures, then there is a separate break-in procedure for towing. It's about an hour or two total, but I can't recall if it required a fluid change.
  3. Jan 30, 2024 at 6:35 PM
    centex
    centex New Member
    I drove 300 miles around town, drained and filled, and then hooked up the trailer and sxs and did a 200 mile trip, drained and filled, then did another 200 mile trip. Still going strong several months later. Shop nor supplier said anything special about a towing break in procedure. If things are going to go wrong with gears, it’s not going to be in a 1000 miles. It’ll be within the first 100 miles or less.
  4. Jan 30, 2024 at 7:09 PM
    d33pt
    d33pt New Member
    I plan on putting on 275/70-18 vs the stock 275/65-18. I don't think I'd go any bigger than that, since I don't want to lift it. Probably no need to regear right?
    What size tires are you guys putting on for 5.29 gears?
  5. Jan 30, 2024 at 7:23 PM
    centex
    centex New Member
    I’m on 34’s.
  6. Jan 31, 2024 at 4:33 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm on 275/70/18s. I did it for towing. Being able to go up in size is just an added benefit in my situation.
  7. Jan 31, 2024 at 4:39 AM
    bflooks
    bflooks New Member
    Metrowest MA
    May be a difference in brand and requirements, but here is the wording direct from Nitro.
  8. Jan 31, 2024 at 7:10 AM
    d33pt
    d33pt New Member
    It makes sense if you tow often. How much MPG did you lose going to that combo?
  9. Jan 31, 2024 at 7:21 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I can't stress enough that these are only my numbers, with my payload, my driving habits and my scenery. YMMV
    Loss was overall negligible when considering the performance increase. Combined (Falken Wildpeaks and regear), daily driving in town went from 15'ish to 13.5'ish. All highway went from 16/17 to right around 15.
  10. Jan 31, 2024 at 9:08 AM
    Marshwalker
    Marshwalker [OP] New Member
    Z
    I had those before tall skinny 35’s.. wasn’t much power loss and towing. Once I broke the 35 mark it did change things
  11. Jan 31, 2024 at 9:11 AM
    d33pt
    d33pt New Member
    What size are tall skinny 35's? How much lift did you get to fit them?
    I run 255/85-16 on my Tacoma. I love tall skinny tires. I did regear that Tacoma to 4.88's though.
  12. Jan 31, 2024 at 9:44 AM
    Marshwalker
    Z
    285/75/18 had bilstein 6112 but switched to dobinson
  13. Jan 31, 2024 at 10:03 AM
    Marvthehamster
    Marvthehamster New Member
    Tom
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI Armor, OTT Tune
    So what drives the need for a "break in" period with new gears? I don't hear anyone talking about breaking in brand new trucks this way, and they've got new gears in them, right?
    I hear guys talk about elaborate "break in" procedures for all sorts of shit (rifle barrels, for instance) but there seem to be differing opinions. Does it really matter?
  14. Jan 31, 2024 at 10:19 AM
    centex
    centex New Member
    Heat cycles and bedding the gears. I’ve never broken in factory gears but always aftermarket. Not certain they have the same qc as oem. Although technically you are supposed to break in new vehicles for 500 miles or so. I never have and have never had an issue.
    Marvthehamster and bflooks like this.
  15. Jan 31, 2024 at 10:34 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm not an expert, but at 2500-5000 bucks, I'll follow the manufacturers procedures.
    I agree with @centex on his recent posts, both about heat and an earlier one about likely failure windows.
    Don't pick up your rig and go ripping at 80mph in the event they bind or disintegrate. Don't tow heavy in the event the pattern is garbage and they disintegrate. There's also the idea that any ridges will wear down quickly and therefore make catastrophic failure less likely (insert previous comments about getting them rem polished).
    It all makes sense, but again, I'm not an expert and only speculating. Aftermarket gear manufacturers also can't trust the installers, so I'm sure there's some liability concerns baked into their procedures.
    My .02
  16. Jan 31, 2024 at 2:21 PM
    Marshwalker
    Z
    200 miles in.. off the line acceleration is day and night. Can also pass again quickly
    2mchfun and bflooks like this.
  17. Mar 27, 2025 at 9:40 AM
    Marvthehamster
    Tom
    CO
    2018 CM
    Hey @Marshwalker,
    I think 2025 might be the year for my 5.29's. I was planning to call the guys at CO axle and gear to get a quote. Couple questions for you:
    - Would you still recommend them for the work? Any issues with the install now that you've had them a while?
    - Would you still do the powertrax LSD?
    2mchfun likes this.
  18. Mar 28, 2025 at 5:20 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Do it!!! You’re going to love your truck so much more with the lower gears. I’m still very happy with my Powertrax, FWIW. Zero issues, totally streetable, and hooks up nice when you want to party.
  19. Apr 23, 2025 at 6:11 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Powertrax is definitely worth it. Helps in town iyn wet roads too.
  20. Apr 24, 2025 at 8:06 PM
    #50
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I’m having my 5.29’s installed as we speak. Ended up with a grip pro in the rear and an Eaton e locker up front. Nobody needs a traction device until you do!
