OEM FOG LIGHT REMOVAL
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Bayou Spartan, Jan 30, 2024.
  1. Jan 30, 2024 at 3:32 PM
    Bayou Spartan
    Bayou Spartan [OP] New Member
    Black 2019 TRD PRo
    None
    It’s seems the blue tab is holding it but how do you get it out
  2. Jan 30, 2024 at 5:17 PM
  3. Jan 30, 2024 at 5:23 PM
    AZBoatHauler
    So.Arizona
    I’ve always just pried the housing out the front. Use a trim removal tool and it’s pretty easy.
  4. Jan 30, 2024 at 6:31 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Thanks all
    I greatly appreciate it.. i had to goto dinner with the wife so I will have to get back to it tomorrow. I had a metal plate come out and I will have to find out where it went
    I am in no rush ( will I have three days ) but I need to order some new fog lights by tomorrow
    Diode dynamics pro are on the top of the list rigid industries D series and one other but i am indecisive at the moment and I am looking at the pros and cons of them all
  5. Jan 30, 2024 at 6:35 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    had time to read through the link,,
    clear and concise.. thanks.. even the bracket was covered!!
    RobertD and Tundra234 like this.
  6. Jan 30, 2024 at 6:39 PM
    Savmikey47
    Savmikey47 New Member
    If you go DD ss pros you’ll need the oem led circle bezels
    Bayou Spartan[OP] likes this.
  7. Jan 30, 2024 at 7:14 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Message sent
  8. Feb 7, 2024 at 2:43 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Thanks so much guys
    got a different problem
    where does this metal bar go? It does not line up with the two holes on the side
  9. Feb 7, 2024 at 2:44 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Going to get them taken care of shortly
    Thanks
    I decided to go DD but the ones above the pro line
  10. Feb 7, 2024 at 2:45 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    FYI
    I looked on the parts website for a diagram and couldn’t find it. Went to a local dealership and well here I am
  11. Feb 7, 2024 at 5:50 PM
    Savmikey47
    That goes on the bumper for the front mud flaps
    1lowlife and baron like this.
  12. Feb 7, 2024 at 5:50 PM
    Savmikey47
    On the bottom on the bumper where you take off the 10mm and there’s 2 12 mms
  13. Feb 7, 2024 at 5:52 PM
    Savmikey47
    It’ll line up on the bottom of that slapsh guard you have off
  14. Feb 7, 2024 at 6:38 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Good Evening all
    Thanks.. I was wasnt even thinking about that thing. I am going to just put it on just to cover everything up until the lights arrive.
  15. Feb 8, 2024 at 2:26 AM
    Savmikey47
  16. Feb 8, 2024 at 2:28 AM
    Savmikey47
    521270c060
  17. Feb 8, 2024 at 2:29 AM
    Savmikey47
    I just searched 2018 tundra bezel
  18. Feb 8, 2024 at 6:58 AM
    White 2.5
    White 2.5 New Member
    Mt P, SC
    2020 White DC
    Be sure to zip tie the DD’s down when you install them. They’re going to want to bounce around in there and they’re even more noticeable than the factory fog lights. Poor design by Toyota on the housing.
    Rob's Inferno likes this.
  19. Feb 18, 2024 at 2:06 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    I cant just be me. Lord knows I tried today.. I got the DD square bezel in and changed them out.
    Went to put the DD SS3 Pros in and guess what.. My brackets are not like all the others that I have seen on the internet
  20. Feb 18, 2024 at 2:19 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    it is not possible to mount the lights on to this bracket
  21. Feb 18, 2024 at 2:27 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Yes
    The TRD Pro square housing is set up differently than the round ones that everyone makes brackets for - the tabs and interface are way different
    you will either need to order round ones or you’ll need to make something that will mount to the stamped metal bumper sub-frame and hold the lights in position
  22. Feb 18, 2024 at 2:40 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Thanks.. i was going for the square face look which is why I ordered the squared bezels. I thought I had did all the reading and research that I need to do..
    kinda sucks being having to go back to the round. I will resist and find some alternative. Thanks for reaffirming my suspenion.. Seem like DD would recognize that not everyone wants the round bezel especially that price point. right now i have nothing in place
  23. Feb 18, 2024 at 3:11 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I just swapped in some BD fits this weekend and switched to the round inserts (they only offer the fog trim with a round bezel). So the comparison of mounting points is fresh in my mind.
    It would be easy enough to fabricate something that attaches to the stamped metal frame.
  24. Feb 18, 2024 at 4:03 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
  25. Feb 18, 2024 at 4:04 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Thank You.. I really appreciate it.. Especially being a new comer to this community, your help, guidance, ideas and support is greatly appreciated
  26. Feb 18, 2024 at 10:52 PM
    Savmikey47
    Gotta re-use the brackets from the rigid fogs
  27. Feb 22, 2024 at 4:09 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Went a different route altogether
    They will be installed on Monday but my local shop whose done plenty of work for me
    Can’t wait to see it all done using the oem SQUARE housing. These guys are smart
    Tripleconpanna likes this.
  28. Feb 22, 2024 at 5:32 PM
    Savmikey47
    Ooo please post it when you’re done
  29. Feb 27, 2024 at 9:45 AM
    Bayou Spartan
    Black 2019 TRD PRo
    None
  30. Feb 27, 2024 at 9:58 AM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Fully functional with back lighting
    Tripleconpanna and WFD473 like this.
