19 Tundra roof leak
Discussion in '2.5 Gen Tundras (2014-2021)' started by PJA TUNDRA, Jan 30, 2024.
  1. Jan 30, 2024 at 8:29 AM
    PJA TUNDRA
    PJA TUNDRA [OP] New Member
    '19 Tundra Double Cab
    Had a lot of water in my center console cupholders after a heavy rain. I noticed stains on my headliner front right side and rear. I read that this can be a problem on several different Toyota models which is from the seals on 2 roof trims. Found a good you tube repair clip on it. One thing I'm puzzled about and couldn't find an answer on is there is a small round silver piece on the rear part of the roof that looks slightly bigger than a quarter. Was hoping someone could tell me what it is because it looks like water could be getting in there also. I appreciate any help.
  2. Jan 30, 2024 at 9:26 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    That almost looks like it was the hole for the shark fin antenna, but I don't remember if that was on the '19's or not. I believe the GPS antenna is more towards the windshield.
    Did you buy this used? I'm wondering if someone did an aftermarket mod and this was their reversal.
    PJA TUNDRA[OP] and PomDad like this.
  3. Jan 30, 2024 at 9:30 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    I'm almost positive that the shark fin was a 2020 addition. This looks like some sort of modification...
    PJA TUNDRA[OP] likes this.
  4. Jan 30, 2024 at 9:39 AM
    2019s had an antenna on the front passenger side by the windshield. The shark fin started on the 2020's, but sits further back closer to the 3rd brake light. My guess is that the hole shown was for a CB or ham/GMRS radio antenna.
  5. Jan 30, 2024 at 10:18 AM
    PJA TUNDRA
    I bought the truck used from a dealer when it was 2 years old. I usually put cardboard on the ground and crawl under a vehicle to check everything before buying but in this case with 25k miles I wasn't as thorough. I took another pic which shows the antenna in the front right area, so yea I'm beginning to think previous owner put a cb antenna or something in. The edge of it lifts up easily so I'm probably going to put some good sealant on it to prevent problems. Thanks for the replies.
    SnrDisregardo likes this.
  6. Jan 30, 2024 at 10:33 AM
    SnrDisregardo
    Wade
    IL
    Best of luck to you. Hopefully you can get it to seal. If not, I would say get the shark fin with the gasket and see if that seals it up even if it's just a foe antenna.
  7. Jan 30, 2024 at 12:47 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Yep, just put some clear silicone on it and call it a day.
