Edit: I did it ! — Pull trigger? 2019 SR5 4x4
Discussion in '2.5 Gen Tundras (2014-2021)' started by MountainTruck123, Jan 14, 2024.
  1. Jan 21, 2024 at 4:54 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    I like the cap with the bars. What is the mileage?
  2. Jan 24, 2024 at 8:38 AM
    mzdaspd
    mzdaspd New Member
    Lincoln, Nebraska
    2016 SR5 CM 4.6L
    TRD Pro Sport headlights, Vision 111 Nemesis rims, iArmor Edge Nerf Boards
    My 2016 SR5 has bucket seats and just the 26 gallon tank. Bought it used so I don't know the particulars around its configuration, other than the previous owner was a retiree that never touched a thing on it other than tires. Was still running on original brake pads and rotors when I changed them at 183K.
    BillyB likes this.
  3. Jan 24, 2024 at 9:25 AM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Curious. Do you have the column shifter? I know the earlier 2nd gens, and even the early 2.5 gen trucks don't have the 38 gal tank. But I think it started in 2015?
    The packages must have been different in 2016.
  4. Jan 24, 2024 at 10:05 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    4.6L didn't get the big tank, i believe.
  5. Jan 24, 2024 at 10:21 AM
    18" TRD Off Road Wheels
    First, congrats on the truck!
    As for tires/sizes, there is no easy one size fits all answer. Too many variables. Are you changing the wheels? If so, what offset? That has a huge impact on what does and doesn't rub and where. On top of that, not all tires with a given size on the sidewall are actually the same size. Prime example, I got the same 275/70R18 size as another member with identical suspension (stock) but I had rubbing and he didn't. Turns out, the brand I bought runs a little larger than the brand he got. Then there's the fact that all the trucks are a little quirky. They aren't precision done, so they don't all have the exact same tolerance in an alignment and tire scenario.
    All that to say, there is no carved in stone "this will fit and will not rub" because of the variables. It's all at a risk of some rubbing. Anyone saying anything but stock size fits fine may not be 100% accurate, so don't be surprised if your truck is a little different.
    I loved the Falken Wildpeak AT3Ws that I had on my Tundra and they did everything well except mud, but no AT tire does well in deep/thick mud. I ran them on ice, wet, snow, dry, and muddy roads and they were great. Just remember that heavier tires reduce your payload, and will hit your MPGs.
    For sizing you can refer to this, but keep in mind the tidbits mentioned earlier. https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations.9762/
    If you don't know what offset/backspacing is, read up on it and what changing it does to the suspension components and alignment, etc. https://www.tundras.com/threads/wha...an-when-considering-aftermarket-wheels.88937/
  6. Jan 24, 2024 at 10:23 AM
    Pretty sure the 38 gallon tank was introduced in the 2016 MY, and no column shifter got it. Had to have the convenience or upgrade package, IIRC, to get it and they came with the center console.
  7. Jan 24, 2024 at 6:33 PM
    mzdaspd
    mzdaspd New Member
    Lincoln, Nebraska
    2016 SR5 CM 4.6L
    I have the console shifter and the 4.6L. Sure wish it had the large tank, though. I got this for $19,700 in June of 2023, with 179K on it, so there was little that would have deterred me from buying, in terms of features.
    GODZILLA likes this.
  8. Jan 24, 2024 at 7:47 PM
    You can put the larger tank in it. :spending:
  9. Jan 24, 2024 at 11:37 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Stock 255/70-18 show 38 lbs on tire rack, and my 275/70-18 KO2 show 57lbs. I’m going to try General Grabber APT for next set. It got 275/70-18 on SL and only weight only 44lbs, I might get 2 mpg back…lol
    It don’t matter if your gas is $2 but cali gas is too high for 10 ply…lol
    HulkSmurf14 likes this.
  10. Jan 26, 2024 at 10:25 AM
    RI2021Platinum5.7
    RI2021Platinum5.7 New Member
  11. Jan 26, 2024 at 10:52 AM
    mzdaspd
    mzdaspd New Member
    Lincoln, Nebraska
    2016 SR5 CM 4.6L
    H'mm, clicked into this post because I was looking at spending some money, but not on a tank. What was it? I think it was X-Remote, but now I don't see it anywhere in here.
  12. Jan 26, 2024 at 11:16 AM
    mzdaspd
    mzdaspd New Member
    Lincoln, Nebraska
    2016 SR5 CM 4.6L
    I don't know if this helps, but I put -25 offset wheels on my 2016 SR5 CM and kept the stock tire size of 275/65R18, and ended up with an occasional rub of the front, forward mud flap, under certain circumstances. My solution is to replace the stock shocks with the Bilstein 5100 Adjustable Leveling Shock Kit, BIL0719TUNFRKIT. Still waiting to get the fronts put on...
    Still have the stock aluminum wheels to sell, if anyone's interested.
    Looks like this:
  13. Jan 26, 2024 at 11:29 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Most people just take them flaps out, it don’t help anything
  14. Jan 26, 2024 at 11:30 AM
    mzdaspd
    mzdaspd New Member
    Lincoln, Nebraska
    2016 SR5 CM 4.6L
    Right. Well, I wanted to level it, as well. Or at least I do now that I'm faced with thinking I'm an idiot!
  15. Jan 26, 2024 at 12:53 PM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    I’ve had good luck with my KO2’s so far. Rotating them every 5,000km. Great in the snow, decent in rain and good on the highway.
  16. Jan 26, 2024 at 1:34 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    We all know you use them mud flaps to do a lift, I do that as well to get approval from wife…lol. I installed the coil over and take them flaps out at the same time…
  17. Jan 29, 2024 at 8:20 AM
    Florida AF
    Logan
    North Florida
    Congrats and beautiful truck! I cannot help with your questions as of yet, but I see lots of the regulars checked in with you. Enjoy!!
  18. Jan 29, 2024 at 11:43 AM
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    Welcome to the Quicksand club!
  19. Jan 29, 2024 at 5:30 PM
    grussell
    grussell New Member
    Garry
    Florissant, CO
    2021 Tundra SR5w/ Leather
    My 2021 SR5 CM came with leather and the 38 gallon tank.
    HulkSmurf14[QUOTED] likes this.
