Key Programmer for 2014 Tundra Platinum
Discussion in '2.5 Gen Tundras (2014-2021)' started by JayKay, Jan 27, 2024.
  1. Jan 27, 2024 at 10:52 AM
    JayKay
    JayKay [OP] New Member
    Hi Everyone! Just checking to see if anyone ever gotten any luck getting this key to work on a 2014 Tundra Platinum? If yes, which key programmer did you use? I'm tired of the key and remote bulging up my pockets. I also have the flip key but it's also too big.
  2. Jan 28, 2024 at 6:18 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    From what I have researched, there is no way to get that key to work with your year of tundra. I believe it will only work with 2018 to 2021. I ended up with a euro style switchblade type of key.
  3. Jan 29, 2024 at 4:19 PM
    JayKay
    Thanks, I also have that same key. Was hoping to get the other key to work but looks like it won't.
