Tundra 2000 no pasa de 3000 RPM
Discussion in 'New Member Introductions' started by j.lo81, Jan 29, 2024.
  1. Jan 29, 2024 at 10:18 AM
    j.lo81
    j.lo81 [OP] New Member
    tundra 1 generacion
    suspencio n
    Ojalá me puedan ayudar tengo una tundra 2000 4.7 y se limita a las 3000 rpm marca codigos P0101 Y P0100 ya puse sensor maf nuevo y cambie la garganta y el problema sigue que consejos me dan
  2. Jan 29, 2024 at 10:32 AM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    “I hope you can help me, I have a 2000 4.7 tundra and it is limited to 3000 rpm, it marks codes P0101 and P0100. I already installed a new maf sensor and changed the throat (throttle body) and the problem continues. What advice do you give me?”
    Mr.bee likes this.
  3. Jan 29, 2024 at 10:34 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Check coil packs and plugs.
    edit: does anybody know what those codes mean?
    double edit: OP are there any other symptoms that your truck is exhibiting?
  4. Jan 29, 2024 at 10:38 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. Jan 29, 2024 at 1:05 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome from Texas! Replace intake manifold gasket. Check the advanced search function for 1st gen threads and you find plenty of posts on the topic.
  6. Jan 29, 2024 at 3:06 PM
    Bienvenido de NY.
