Under Tailgate Lighting
Discussion in '3rd Gen Tundras (2022+)' started by 303Gen3, Jan 26, 2024.
  1. Jan 26, 2024 at 3:47 PM
    303Gen3
    303Gen3 [OP] Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    What under tailgate lighting are the Gen3 owners using? I've seen a few listed on the 2.5 thread. Looking for a
    Plug and play LED option. Opt-7 looks nice but their product info is generic as it only shows Toyota and nothing specific to Gen3 Tundra. TIA and pics appreciated!
  2. Jan 26, 2024 at 3:56 PM
    RobertD
    Robert
    DFW, Texas
    Most aren't vehicle specific, they just use the 4 pin trailer connection. Just verify dimensions with your space to see which will fit. I picked up a Curt 7 pin adapter so I could splice into the reverse wire on that and not mess with the actual harness (the Curt adapter connects in line between the plug on the bumper and your trucks wire harness, it also adds a 4 pin connector so you can wire up the tailgate lightbar without affecting the plugs on the bumper).
    https://www.amazon.com/OPT7-Redline-Triple-Tailgate-Sequential/dp/B01HUJW75O?th=1
    https://www.amazon.com/gp/aw/d/B0009FJ38Q?ref=ppx_pop_mob_b_asin_title
    303Gen3[OP] and DRP like this.
  3. Jan 26, 2024 at 4:24 PM
    303Gen3
    Golden Colorado
    ?? So my camper uses the 7pin connector - if I use the 4pin connector stock option on the opt-7 then the reverse light option is not
    functional (ie takes the 7pin to make reverse light work)?
    And if I use the 4 pin for the opt-7 will then 7pin work for the camper at the same time? Sorry for my ?
    Edit: looks like the Mothership managed to make this more difficult for Gen3 - the wiring and retaining clip for the 7pin/4pin hook-up is directly in the middle of the lip and offset to one side - totally f's up where you would want to place the light. Not even a 2 piece option works based on where the conflict is.
  4. Jan 28, 2024 at 5:54 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    I did the vled plate one. It’s just the three dots and reverse bar. Personally don’t like the strip as it’s over done and doesn’t look great to me.
    Toyota has an oem one now.
    1lowlife and 303Gen3[OP] like this.
  5. Jan 28, 2024 at 6:44 AM
    303Gen3
    Golden Colorado
    Thanks for the information - I did not know Toyota had an option for our Gen3 under tailgate lighting. Maybe @ryanwgregg knows more about it and part numbers?
  6. Jan 28, 2024 at 12:59 PM
    Magnetic1
    Magnetic1 New Member
  7. Jan 28, 2024 at 1:07 PM
    303Gen3
    Golden Colorado
  8. Jan 28, 2024 at 1:18 PM
    Magnetic1
    I didn't see a part # either seems like it maybe more prevalent with Toyota Canada?
  9. Jan 28, 2024 at 1:29 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Did you loose access to the spare crank?
  10. Jan 28, 2024 at 1:51 PM
    TundraTT
    TundraTT Full Send
    23 Taco Trail 97 FZJ80 68 Goat
    Ram TRX oe rear marker lights tapped into the trailer harness. I posted a while back with everything involved. I’ll try to find it if anyone’s interested.
  11. Jan 28, 2024 at 1:57 PM
    RobertD
    Robert
    DFW, Texas
    Yes, but my lightbar is attached with velcro so I can remove it if needed.
    1lowlife[QUOTED] likes this.
  12. Jan 29, 2024 at 6:57 AM
    smileytn1
    smileytn1 New Member
    Get you a Putco blade it is all plug and play does stopturn and tail and is BRIGHT !!!
  13. Jan 29, 2024 at 7:08 AM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    PUTCO does not offer a unit for Gen3 Tundra.
  14. Jan 29, 2024 at 7:15 AM
    jctmundra
    Northern VT
    Do you own a Gen3? The space available between bed and bumper is tight as the tailgate lip swings through. You will also find the tailgate bottom is not straight with least clearance at center and then there is the spare crank port. Good luck finding a decent bar that will span. That Is, a decent light will have a metal body/heat sink that's unlikely to fit in the center without the tailgate contacting/almost contacting it.
    At this time, I'm waiting for someone the find the Toyota PN.
    303Gen3[OP] likes this.
  15. Jan 29, 2024 at 7:22 AM
    RobertD
    Robert
    DFW, Texas
    If you looked at my post that had pictures, I obviously don't have a gen 3. Which is why I stated to take measurements and very dimensions. All I tried to point out is that a lot of these tailgate lightbars are not vehicle specific and more universal, so its important to find one that has dimensions that fit your available space.
    Yes, you definitely don't want it contacting the tailgate when you open it. Hopefully there is enough space and some options. I very much like having that additional brake lights and turn indicators because a lot of folks aren't paying attention on the road.
    jctmundra[QUOTED] likes this.
  16. Jan 29, 2024 at 7:27 AM
    jctmundra
    Northern VT
    I had some morimoto parts in the mod bin from other projects. The 5 lamp is stop lights that I have a modulator connected. Looks goofy, but if it keeps from be ended, all that matters.
    The other bars are backup lamps I installed prior to relocating the fogs from front to back. They are heat sinked, about 5/16 in height. When the gate swings, about 1/8 clearance.
    If the toyota PN is available, it will replace all the morimoto.
  17. Jan 29, 2024 at 8:09 AM
    Ipaddick
    Ipaddick New Member
    Canada
    https://www.vleds.com/shop-products/lp-series/lpx-13-red-white.html
    This would be an easier, similar solution. They have a harness where you don’t need to tap into anything.
  18. Jan 29, 2024 at 8:28 AM
    jctmundra
    Northern VT
  19. Jan 30, 2024 at 12:21 PM
    Hunter1699
    Hunter1699 New Member
    strange that this is only sold by one vendor that I can see??? Cost is high but it is OEM.
  20. Jan 30, 2024 at 12:48 PM
    jctmundra
    Northern VT
    Ouch $400. Will need to see in person before I can justify the coin. Must be narrow to run below the spare tire service hole.
    Ryan: Thanks for the PN.
    303Gen3[OP] and ryanwgregg like this.
  21. Jan 30, 2024 at 6:13 PM
    Magnetic1
  22. Feb 1, 2024 at 10:58 AM
    Hunter1699
    Emailed Jackson Toyota in Canada-quick response and provide the install directions. Looks simple enough. Now to ask when they go on sale:fingerscrossed:. Magnetic-post pics when you get it done:thumbsup:.
  23. Feb 1, 2024 at 11:09 AM
    jctmundra
    Northern VT
    hmm... similar LED to the morimoto at 10,000 ft (~3KM) view. The morimoto go for $90 each, looks like the Toyota is three units. $400 not that far off.
    Black widow TRD likes this.
  24. Feb 1, 2024 at 11:23 AM
    Magnetic1
    You can order them now from Jackson Toyota I spoke to them this morning. Shipping looks like its a bit to come south of the border. I think they would look nice for sure
  25. Feb 1, 2024 at 1:40 PM
    303Gen3
    Golden Colorado
    Lots of instructions. Looks like the electronics and ecu modual make the install a little involved - pnp but not what I was expecting. I will give others an opportunity to test it out over a few years. Maybe by then we will know how well it holds up and the price will drop 50%. Will be keeping an eye out for user reviews.
    jctmundra likes this.
  26. Feb 3, 2024 at 8:59 AM
    Ipaddick
    Ipaddick New Member
    Canada
    How does it seem involved? I think it actually looks quite simple.
  27. Feb 3, 2024 at 9:55 AM
    303Gen3
    Golden Colorado
    look at the Opt7 - I expected it to be a simple adapter plug (no ecm module) for the back side of the existing 7 pin connection. Makes me wonder if the Opt7 and others really don't have the same functionality as the Toyota specific one shown on this thread since they don't use a separate ecm module. Don't think @TundraTT had to add module to control features - only had to tap taillights.
  28. Feb 3, 2024 at 10:11 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Not sure why it has an ecu. Maybe it’s to prevent any codes for ones with sequential tails. But it’s still a simple install by the looks of it. I’m not sure why the ecu would dissuade someone from installing it.
    edit: I bet the ecu also prevents trailer codes. I have a few things hooked up through 7pin harnesses (DD reverse kit, DD hitch pod, and VLED x-lp). Once in a while the dash will show trailer not detected or something similar.
    303Gen3[QUOTED][OP] likes this.
  29. Feb 3, 2024 at 11:41 AM
    303Gen3
    Golden Colorado
    Makes sense...agree with your analysis and reasoning. Count me in when they drop to $300 usd.
  30. Feb 3, 2024 at 12:28 PM
    Magnetic1
    Agreed, it
    Don't hold your breath
