2021 Headunit w/Nav & CarPlay
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by charliebison, Jan 27, 2024.
Thread Status:
Not open for further replies.
  1. Jan 27, 2024 at 12:54 PM
    charliebison
    charliebison [OP] New Member
    SOLD…..Selling my 2021 non-JBL headunit. Has CarPlay, Android Auto and factory navigation. Like new. Can be installed in a 14-19’ model with the conversion harness sold at autoharnesshouse.com. $490 shipped.
    Part #86410-0C390
  2. Jan 27, 2024 at 6:01 PM
    redrum448
    redrum448 New Member
    Will the nav work in a 2021 "non-nav" sr5?
  3. Jan 27, 2024 at 6:34 PM
    charliebison
  4. Jan 27, 2024 at 7:54 PM
    Unrighteous
    Unrighteous New Member
    2018 SR5 Sports Package
    4" Lift, 18" Fuel Shok on 35 Mickey Thompsons, NorCal mod.
    Just upgraded my 2018 SR5 non nav to one like this with the harness from autoharnesshouse.com. Works like a charm, great upgrade if you want to keep the stock look and a great price. Good luck with sale, will probably go quick at that price!
  5. Jan 27, 2024 at 8:44 PM
    Selcouth
    Selcouth New Member
    Josh
    2019 Smoked Mesquite 1794
    What would I need to make this work in a JBL ‘19 1794? I know the JBL version requires also replacing the amp with the ‘20-21 version.
  6. Jan 27, 2024 at 9:05 PM
    shmabs
    shmabs New Member
    PM sent
  7. Jan 27, 2024 at 9:48 PM
    Unrighteous
    I researched quite a bit and did read that if you have a JBL unit already and wanted to upgrade to a 20-21 JBL it requires you to purchase a 20-21 JBL amp for that unit to even work. Unfortunately I did not see much on downgrading to a non-JBL unit. Autoharnesshouse.com does advise you that a JBL unit model will not work with the harness they sell and they ask you to call them.
    Also, if you do purchase a harness from them, I highly suggest you spend the extra money on the Entune 2.0 to 3.0 adapter. It completes the upgrade on your USB plug on the dash near your outlets which will work with the new head unit and allow Apple Carplay or Android Auto wired.
    Then if you want to go wireless, go on Amazon and buy a wireless adapter which plugs into the USB. That adapter will sync with your phone wirelessly and will then run Android Auto or Carplay.
  8. Jan 28, 2024 at 4:41 AM
    lstallent
    lstallent New Member
    Lance
    I’m interested as well
  9. Jan 28, 2024 at 5:15 AM
    Hoosier33
    Hoosier33 New Member
    2019 Cement Tundra Limited
    How much is the harness at autoharness? And how long did it take to switch out and install the new head unit?
  10. Jan 28, 2024 at 5:39 AM
    redrum448
    Im guessing a GPS antenna would be needed though?
  11. Jan 28, 2024 at 5:43 AM
    ScottsTundra
    ScottsTundra New Member
    2017 SR5 Crewmax
    Headwaters seat covers, Undercover Flex
  12. Jan 28, 2024 at 7:31 AM
    Unrighteous
    The harness was a bit pricey, $190 harness alone, $60 for USB 2.0 to 3.0 adapter. Took not kidding about 5-10 minutes to do the swap. Just be aware, there are no instructions for the new harness. It's all plug and play and they all fit where they are supposed to. I plugged everything into the replacement stereo, then took out my old head unit and just plugged everything else to the other end of the new harness.
  13. Jan 28, 2024 at 7:38 AM
    Unrighteous
    So it depends. My former head unit had no GPS, but was the Entune system with Scout GPS. If you have this unit, then your vehicle has GPS wired already, but no GPS head unit. You should be ok if this is your case.
    If you have the basic Entune, small screen unit, with minimum features, then you have no pre wire for GPS and would more than likely need an antenna.
    Here is a video that provided me all that info:
    https://youtu.be/fSbvyp8iuyE?si=outOiGyIsbUdTIlV
  14. Jan 28, 2024 at 6:53 PM
    charliebison
Thread Status:
