  1. Jan 28, 2024 at 1:43 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Iirc:
    2 π r = C
    32" tire /2 = 16 for r.
    2 x 3.14 x 16" = 100.48" for C
    100.48" / 360° = .279" per 1°
    .279" x .0625" (1/16) = approx 22.4% of 1 degree.
    Or 1/16" = 0.224 degrees.
    If tape measure 1/32 - 1/16" total toe is what I'd run. 1/8" is acceptable as some vehicles are spec'd at .40-.50 front toe in.
    shifty`, des2mtn, bmf4069 and 2 others like this.
  2. Jan 28, 2024 at 1:53 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    thank you sir, i'm pretty close to 0* toe, but i need to adjust it again to get my steering wheel straight, and will call tomorrow to schedule an alignment.
  3. Jan 28, 2024 at 1:53 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Seal for what?
  4. Jan 28, 2024 at 1:54 PM
    Lucille
    des2mtn likes this.
  5. Jan 28, 2024 at 1:55 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Ball?
  6. Jan 28, 2024 at 2:03 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    This is a much bigger deal to me vs banging metal. When i take my truck up to the N Ga property I just leave the cruise off. With cruise on, any grade drops gears and as my truck screams at me - RPM's way up. My wife would look at me every time like something was wrong...
    My truck had 275/70 17's on it when I bought it way back when; I thought it was normal until I rode up with a friend of mine in his '06 4wd Tundra. Smooth sailing in his truck...
    Each to their own but be forewarned if this matters to any of you.
    shifty`[QUOTED] likes this.
  7. Jan 28, 2024 at 2:04 PM
    I was $1500 out the door for mine. 255x85xr16 Cooper discoverer st maxx.
  8. Jan 28, 2024 at 2:05 PM
    Well, time to go test it out at T2S!
    oscardog86 likes this.
  9. Jan 28, 2024 at 2:27 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Dude. PenderBen said two posts prior to FGV exactly what seal they're talking about.
    shifty` likes this.
  10. Jan 28, 2024 at 2:42 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    I’m going to cram something in there today, maybe I have some fibreglass insulation around. I’ll have to order a seal, but I want to stop them today.
    We take them far away in the woods, much farther than I’m sure they travel so I’m not worried about them coming back, and my kid likes to let them go and watch them run off. Around here bids of prey probably get a good few.
  11. Jan 28, 2024 at 2:54 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    This is why quotes matter.
    And the mouse pic was distracting lol
    KNABORES likes this.
  12. Jan 28, 2024 at 3:27 PM
    Yup, I can confirm: The clunking coming from my front driver's side is likely not the balljoint. The only other things I can point a finger at now are the steering rack or the coilovers. I suspect it's the f'n coilovers, but I can't for the life of me figure out what/how they could be making all this damn racket. I checked everything on them, it's all tight, there is a little (normal-seeming) movement at the lower bushing, I just don't see anything out of the ordinary.
    At least I know I have two very good OEM spare LBJs now, and the peace of mind I won't need to do this again.
    I also went to deal with my brake-squealing-when-cold issue, only to find there are no shims on my front pads on either side, so no need to re-glue. Fuck. Pads look like they were installed probably months before I got the truck so I'm not hip to just swap them but the squeal has gotten gradually worse over time.
  13. Jan 28, 2024 at 3:29 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Been doing research most of the day, regarding re-gearing and gaining back some mpgs.
    Did the math, thanks @bmf4069 for this thread https://www.tundras.com/threads/re-gear.115068/
    and it looks like 4.10 is where I'm heading (was between 4.15 and 4.20, depending on if I rounded the tire size or not, but that's uncommon).
    Seems like a lot of late 90's Tacomas had 4.10's and should match up with my year, since it doesn't have the bigger flange like the later years. Am I on the right track?
    bmf4069 and 455h0le_dachshund like this.
  14. Jan 28, 2024 at 3:34 PM
    There is a reason Toytech gets really mixed reviews... Hopefully it's something else but even if they are making noise I doubt it's anything other than annoying.
  15. Jan 28, 2024 at 3:38 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Moog quality, 2716 miles since install
    Voss, Weagle, oscardog86 and 3 others like this.
  16. Jan 28, 2024 at 3:40 PM
    metalpete
    ID
    I think I've been chasing the same clunk for a long time. Even before the toytec and ome setups. Thought it could steering rack, was leaking anyway so I replaced it. Nope. Thought it was the old ass, worn out, struts. Nope. Changed lbjs. Nope. Changed outer tie rods. Nope. Aftermarket uca. Nope.
    It's all seemed to get "better" for a minute, but comes back. The only I have yet to change are the lcas and cam bolts. I really think it lies in the lcas. Bushing, specifically.
  17. Jan 28, 2024 at 3:49 PM
    Nope, factory/OEM original.
    My LCA bushings look great. I have my replacement leaf for the rear driver leaf that is definitely causing a clunk. I just need to install the f'n thing. Maybe next weekend. Then see if that solves some or all of it.
    There is, just like Icon. But I mean ... They're Elka. I rarely hear bad reviews about Elka products.
    Yikes.
    Weagle and oscardog86 like this.
  18. Jan 28, 2024 at 3:56 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Get front and rear diffs from a sequoia. They're 4.10's.
  19. Jan 28, 2024 at 4:21 PM
    metalpete
    ID
  20. Jan 28, 2024 at 4:27 PM
    w666 likes this.
  21. Jan 28, 2024 at 4:37 PM
    metalpete
    ID
    Close to that sound. Definitely not the side to side motion. Just more like two pcs of metal bolted together, with no cushion in between them. Maybe I should just invest in a go pro or 2 and strap near where I think the noises are coming from.
    @shifty` my bushings look to pass the eye test, but I've replaced almost everything else in that area.
  22. Jan 28, 2024 at 4:39 PM
    Mr Badwrench
    Mr Badwrench New Member
    Damn! I'm thinking all these off-brand "oem" parts are just garbage these days. I've heard mixed reviews about moog LBJ's. Some people rave about them, but your picture says it all.
    I bought some NAPA CV shafts about 4 years ago. Same issue, the boots disintegrated and now I have to tear my truck apart to replace them. :mad: In fact, I am done with off-brand parts.
  23. Jan 28, 2024 at 4:43 PM
    Azblue
    The Dirty T ( ^_^)_且
    TWSS
    artsr2002, RUSTYNUTS, VR6T and 3 others like this.
  24. Jan 28, 2024 at 4:44 PM
    Mr Badwrench
    I'd probably/definitely be making some calls to moog over that. Especially if you have a stock setup.
  25. Jan 28, 2024 at 4:45 PM
    I'm still suspicious of my Toytec Aluma 2.0s. If it was my LCAs, I would've expect to have heard some level of racket before lifting. It was quiet as a mouse prior to lift. I can clearly see the rack bushings are a bit rough, and there's play in the rack. I'm not lookinf forward to replacing the rack bushings (I'll do it, I don't mind, but without having a lift on-hand, I'm simply not looking forward to the neck strain), but I still am not convinced that's it.
    I'm going to replace the rear driver leaf, since I know it's clunky. Maybe I'm just mis-hearing the sound and it's actually coming from the rear. If I stand on the side step and bounce, I definitely hear clunking coming from out back. I sadly don't have a GoPro to slap in the wheel well and video articulation to see if it would reveal when the clunk is happening.
    metalpete[QUOTED] likes this.
  26. Jan 28, 2024 at 4:48 PM
    Can't share this vid enough:
    https://www.youtube.com/watch?v=RQWwTB8w2Hk
    w666, VR6T, FirstGenVol and 2 others like this.
  27. Jan 28, 2024 at 5:01 PM
    metalpete
    ID
    That's right, I forget that you weren't hearing the noise until after you installed the coilovers.
    Just bought this. Im a pro at spending money now lol. We'll figure this out!
    oscardog86 and shifty`[QUOTED] like this.
  28. Jan 28, 2024 at 5:04 PM
    I guess I may do the same. Just need a strong magnetic mount for it.
    My clunks tend to be more audible when I'm starting my journey. It's almost like they go away after a while? Which again, makes no sense, unless it IS the coilover, and once it warms up after travel, the clunking goes away. I've noticed the clunking has gotten louder lately, which is why I was assuming maybe the suspension upgrades were potentially early-fatiguing the LBJ. But maybe it's gotten louder because it's colder out? Huh.
  29. Jan 28, 2024 at 5:07 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    No marks on the coils or UCAs? I was thinking collision of the two maybe
  30. Jan 28, 2024 at 5:12 PM
    Nope, checked for that today. Checked for clearances with tire on and fully jacked, full droop and wheel up deep into the well. Weird part is, I notice it more on smaller bumps, like dropping off the 3/4" ledge at the edge of my garage while backing out. Then when I drop off the 5/8" ledge where the driveway meets the road. Doesn't matter if in FWD or reverse. I notice it more at slow speeds.
