  1. Jan 28, 2024 at 9:07 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    It would be really nice if they made a 275/75 or even a 265/85 tire. But that's like trying to find a pair of 33-33 jeans...
    I think there is more to getting the wheel "right" than the tire, when it comes to the fitment. Obviously every experience and truck aren't the same as the next guy, but a lot of my research led me to stick with a 16x8 wheel at 0 offset. I was dead set on 17's initially, but ultimately felt that could get more tire and still have a better chance at minimal rubbing with 16's.
    But, the variable that bites most of us is matching a wheel size + a design we like. Seemed like a huge portion of the kick-ass-looking wheel market is, at minimum, 17x9 -12 offset. That can put the buyer at a disadvantage for fitment, right away.
    The swing in offsets per mfg can be drastic, too. One wheel you like could be -25, then the next option is +25, with 0 being the in-between. It's frickin madness. If I could have my pick, I would have chosen my same wheel as a 16x7/0 or even 16x8/-5. But, you know, 33-33 jeans lol.
    Again, no alignment yet and I've yet to off-road her (just done a few deep, speed dips, with wheels turned, at different speeds), so I'm sure some gremlins will turn up.
    Now, time to go change the oil. Do you guys know which oil is best for our trucks? LOL JK! Don't answer that.
    oscardog86 and 455h0le_dachshund like this.
  2. Jan 28, 2024 at 9:08 AM
    F7E0E6F5-C249-4103-843C-9ECC5BACD4D7.jpg Did some night wheeling at box canyon
    Voss, oscardog86, RUSTYNUTS and 11 others like this.
  3. Jan 28, 2024 at 9:09 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Thank god for those chase lights otherwise @AZBoatHauler might have gotten lost
    RUSTYNUTS, shifty`, bmf4069 and 3 others like this.
  4. Jan 28, 2024 at 9:10 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    :rofl::rofl::rofl:
    Adam at the start
  5. Jan 28, 2024 at 9:13 AM
    The very beginning of the run, the road was super dusty and couldn’t see anything, im sure our convoy was quite the scene blasting down the road lumens up! Later in the trail it got more moist so it wasn’t as dusty, but all the lighting was nice to see all the terrain better
  6. Jan 28, 2024 at 9:18 AM
    metalpete
    ID
    Super jealous right now. :hattip:
  7. Jan 28, 2024 at 9:20 AM
    Anytime your out here let me know, we have it all in AZ, mild to wild to go fast
    oscardog86 likes this.
  8. Jan 28, 2024 at 9:40 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    One route I was thinking about was getting 17x9 / 0offset and a .25” spacer. I’ve seen some run 285/70r17 and it seems -6mm offset is a good starting place. IMO it’s easier to add the proper spacer than find the perfect wheel offset. But stick out is pretty cool so………maybe I’ll still go -12mm and cut and smash
    also just did the TPMS ground today. Found it was easier to pop out the radio and the glove box. Used a sketchy splitter, piece of speaker wire and viola.
    455h0le_dachshund likes this.
  9. Jan 28, 2024 at 9:45 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Are y'all at that Hammer event I keep seeing?
  10. Jan 28, 2024 at 9:48 AM
    NAw we’re here in AZ, KOH is in Johnson valley CA, right near big bear.
  11. Jan 28, 2024 at 9:49 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Some Toyota folks I live around the corner from are there now.
  12. Jan 28, 2024 at 9:56 AM
    AZBoatHauler
    So.Arizona
    Voss, bmf4069, Jack McCarthy and 2 others like this.
  13. Jan 28, 2024 at 10:00 AM
    metalpete
    ID
    True, this is the one instance where it's probably easier to add to something instead of taking away.
  14. Jan 28, 2024 at 10:30 AM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Current status the truck from the dead breathing life into the 400hp car that needs a clutch
  15. Jan 28, 2024 at 10:31 AM
    VR6T
    Also operation ball joints rework has commenced..... FUCK YOU MOOG
  16. Jan 28, 2024 at 10:45 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Hey, real quick, what kinda toe am i looking for? And does anyone know how many degrees 1/16" is?
  17. Jan 28, 2024 at 11:23 AM
    metalpete
    ID
    .0625x360 = 22.5 degrees? I'm no mathematician, so that could be wrong.
    I'd have to find an older alignment sheet to see the toe, no idea there.
  18. Jan 28, 2024 at 11:28 AM
    Got e-spares, now off to plant some trees.
    Voss, oscardog86, bmf4069 and 5 others like this.
  19. Jan 28, 2024 at 11:33 AM
    VR6T
    Well for all that noise the drive side was making..... Sure dont look to bad
  20. Jan 28, 2024 at 11:37 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    According to the how big is yours i got about 2" of lift with the springs on the lowest setting. Sitting pretty level @ 22" (+- 1/4") on all 4 corners. I'll find a more level spot in the driveway after a little test run and get a better measurement.
    settled down to 21.5. Level across the front.
    oscardog86, BroHon, shifty` and 5 others like this.
  21. Jan 28, 2024 at 11:37 AM
    metalpete
    ID
    It's great preemptive maintenance, anyway. Maybe the clunking is actually the lca bushings?
    des2mtn likes this.
  22. Jan 28, 2024 at 11:39 AM
    metalpete
    ID
    You painted your yoo-hoos gold? Nice.
  23. Jan 28, 2024 at 12:10 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Well shit. I know the steering shaft seal has been addressed before, but can I just shove steel wool around it as a quick fix?
  24. Jan 28, 2024 at 12:29 PM
    metalpete
    ID
    Sure, why not? It's amazing how well that stuff works as a deterrent.
  25. Jan 28, 2024 at 12:39 PM
    Steel wool is not what I'd pick. One member that was too lazy to replace the seal used fiberglass insulation.
    shifty`, Mater and FrenchToasty like this.
  26. Jan 28, 2024 at 12:46 PM
    Are you releasing him/her at a coworkers or neighbors house?
    We always take squirrels to a park a few miles away. The boys love watching it run away, little do they know he will probably die anyways due to no shelter, predators, lack of resources and being dehydrated in the first place from the trap……..
  27. Jan 28, 2024 at 12:48 PM
    If you saw how bad my intermediate shaft coupler was rusted to the bolts holding it together, you’d do the same.
  28. Jan 28, 2024 at 12:49 PM
    Did you use it too? I was referring to PHM.
  29. Jan 28, 2024 at 12:50 PM
    I was the one who came up with the idea. He didn’t believe it until I posted a pic of it if I recall correctly.
    shifty` and FrenchToasty like this.
  30. Jan 28, 2024 at 12:58 PM
    Yeah you're right. I found the old posts. PHM also caulked his.
