ABS light on, 4hi low and heater failed
Discussion in '1st Gen Tundras (2000-2006)' started by Lantz 06, Jan 27, 2024.
  1. Jan 27, 2024 at 4:02 PM
    Lantz 06
    Lantz 06 [OP] New Member
    2006 Tundra
    ABS light, on 4hi low not working , heater not working , found a couple blown fuses replaced what could cause?
  2. Jan 27, 2024 at 4:05 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  3. Jan 27, 2024 at 4:40 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Well, let's see...
    ABS light: Bad wheel speed sensor, broken wires, other braking problems.
    4WD not working: Bad actuator, bad switch, transfer case oil, broken drive line...
    Heater not working: Mixing valve, fan motor, air in cooling system...
    Blown fuses: Indicative of other problems.
    As you can see, there are a multitude of things that COULD cause you problems. You should probably give some more information, or limp it over to your nearest mechanic and have them diagnose the problems.
  4. Jan 27, 2024 at 4:48 PM
    Lantz 06
    2006 Tundra
    All lights come on at same time after battery change. Wondering if there is one fuse that would cause all to quit working?
  5. Jan 27, 2024 at 4:59 PM
    ATBAV8
    Tempe, AZ
  6. Jan 27, 2024 at 5:08 PM
    Did you, even for a minute, hook the battery up backwards? Because all the things you're saying are what have happened to others who flew in here looking for solutions after their battery got hooked up backwards.
    ATBAV8 likes this.
  7. Jan 27, 2024 at 5:40 PM
    Lantz 06
    2006 Tundra
    No battery was not even for a minute hooked up backwards
  8. Jan 27, 2024 at 6:04 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Only the people in the PM you're in can see the pic
  9. Jan 27, 2024 at 6:06 PM
    Huh. I wonder if THAT is why none of TBM’s pics are showing lately :rofl:
  10. Jan 27, 2024 at 6:08 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Maybe. But Bob saw it
  11. Jan 27, 2024 at 6:09 PM
    That’s because he’s Bobniscient.
  12. Jan 27, 2024 at 6:11 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    And now you can see it too
    Bob, ATBAV8 and shifty`[QUOTED] like this.
