  1. Jan 27, 2024 at 3:22 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    I start mine tomorrow, I work Tuesday to Saturday.
  2. Jan 27, 2024 at 3:25 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Got it! At least one anyway.
    Voss, oscardog86, bmf4069 and 7 others like this.
  3. Jan 27, 2024 at 3:25 PM
    VR6T
    But I did 7 out of 8 things today, #7 got done last week. Also I cleaned the MAF sensor, did a test drive, no more System Bank One to low CEL. Well see how long that lasts. If not were gonna start replacing vacuume lines
    oscardog86, bmf4069, JasonC. and 4 others like this.
  4. Jan 27, 2024 at 3:25 PM
    VR6T
    Peanut butter and glue, never fails
  5. Jan 27, 2024 at 3:27 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  6. Jan 27, 2024 at 3:29 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    You can swap the hinge from the new door onto the old door if you still have it. Just have to bend the tabs out, then you still have the paint matched door without having to deal with painting the new one. That's the route I went after someone else recommended it (I forget who)
  7. Jan 27, 2024 at 3:29 PM
    artsr2002
    'Yonder
  8. Jan 27, 2024 at 3:32 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    wait 2 miles.
  9. Jan 27, 2024 at 3:33 PM
    VR6T
    I think you may need to excuse yourself and ummm handle that
  10. Jan 27, 2024 at 3:37 PM
    Did it poop on the cheese? :rofl:
  11. Jan 27, 2024 at 3:40 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    When trying to articulate you're just more likely to hit the wheel wells and there may be some body flex, that's it. But no, a suspension lift kit doesn't change whether you'll hit the top of the wheel wells or not.
    With a suspension lift you are changing the static ride height and the range of motion, or the ratio of down-travel to up-travel. If you crank up your ride height a bunch, you'll limit the amount of down-travel available, but at full up-travel the tire will still go to the same place in the wheel well.
    Most aftermarket shocks do have a little bit of extra travel, but that just allows you to go to a slightly higher ride height from what stock would provide, while keeping the same ratio of down-travel to up-travel.
    Spacing your bump-stops with bigger tires will prevent you from hitting the top of the wheel wells, but then you're limiting the amount of up-travel you have. Combine that with cranking the ride height and you're really limiting the shock's usability range.
    Stock ride height with 33's will rub much sooner than 3" ride height lift and 33's, but lifting doesn't prevent you from rubbing at all.
    More of a choosing the right wheel or wheel spacer issue than a suspension thing. Also remember, the space between the UBJ/spindle and tire does not change while the suspension moves.
    Here's a very useful video:
    https://www.youtube.com/embed/33VewJFda1Q
    Voss, oscardog86, JasonC. and 3 others like this.
  12. Jan 27, 2024 at 3:47 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    shifty`[QUOTED] likes this.
  13. Jan 27, 2024 at 3:51 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    I picked up some used gear today, too!
    I'm just keeping the knuckles, so if anyone wants/needs stock ucas and abs sensors from an 05, hit me up.
    oscardog86, JasonC., VR6T and 3 others like this.
  14. Jan 27, 2024 at 4:07 PM
    metalpete
    ID
    It was open for so long I think that's what finally gave up, but I still have the other pcs so I'll check it out! Good idea.
  15. Jan 27, 2024 at 4:10 PM
    metalpete
    ID
    BroHon, 455h0le_dachshund and VR6T like this.
  16. Jan 27, 2024 at 4:16 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    another useful video: 4 tips to ACTUALLY fit tires on Toyota IFS. 33’s no BMC
    https://youtu.be/LAYGdcKSA3o?si=EOJjq6sd-Wv5QoTF
  17. Jan 27, 2024 at 4:17 PM
    Hold onto those damn sensors, they cost a fortune. If you plan to toss 'em, I'll cover the ride.
    Pestilence.
  18. Jan 27, 2024 at 4:24 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Noice! :fistbump:
  19. Jan 27, 2024 at 4:26 PM
    Replaced my intake manifold gaskets. AGAIN. Ironman is back up to sub-par again. Of course my serpentine belt started squeaking. Took about 3 hours going slow and taking pics. I had to pull the manifold 3 times cause my stupid ass dropped a bolt into the valley. TWICE. I was thinking of doing a detailed write up if y'all wanted.
    oscardog86, KNABORES, shifty` and 4 others like this.
  20. Jan 27, 2024 at 4:28 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I forgot one more variable, spring rate. I think I mentioned preload.
    Anyways I feel like we're saying the same thing for the most part. I'm just not that good at explaining stuff haha
  21. Jan 27, 2024 at 4:28 PM
    metalpete
    ID
    You could probably recite it from memory, sorry you been to hell and back @bmf4069
    bmf4069 likes this.
  22. Jan 27, 2024 at 4:32 PM
    PenderBen
    2003 Tundra AC 4x4
    Yeah, never failed with PB. This is one of those multi traps where they can keep going in but not out, one time in an old car I set one and forgot to check for a couple days, when I did check there was one greasy deranged looking mouse in the corner and two or three half eaten bodies around it, it had the taste so I let it go ;-)
  23. Jan 27, 2024 at 4:33 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Voss, oscardog86, KNABORES and 4 others like this.
  24. Jan 27, 2024 at 4:35 PM
    metalpete
    ID
    I don't have a need for them, but definitely won't toss em. I made the mistake of throwing away other parts before.
    Fool me once shame on me, fool me twice can't get fooled again.
    oscardog86 and shifty`[QUOTED] like this.
  25. Jan 27, 2024 at 4:46 PM
    des2mtn
    SW
    Tonto cover
    Changing spring rate or adjusting preload does not allow you to clear bigger tires either.
    Preload and the equipped springs determine your ride height. What preload measures, is the amount of spring that is still compressed at full extension of your shock. Kings for example use 14" springs. If you want to determine the preload, jack a tire off the ground and measure how long the spring is. 14" minus your measurement results in your preload amount.
    Tundras have a motion ratio of around 2.0, meaning for every inch of preload that should lift the truck by two inches. If you don't get the desired ride height from whatever preload you set at (for 5100s, this is the perch settings), then you need to change the spring rate and get heavier springs.
  26. Jan 27, 2024 at 4:51 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Shouldn't that be expessed the other way around? 1.5 or 2:1 ratio. I got about 3/8-1/2" of lift with a 1/4" leveling spacer.
  27. Jan 27, 2024 at 4:52 PM
    I split the intake open too. Gross. I really, really wanted to put it in the dishwasher, but I just wanted to get it running again. After looking at my injectors, I think it's time to give Keith a call. So I'll get to pull the intake again. I think I'm going for the "removed intake manifold the most" record at this point.
    Look at how rough the ports are!
    Voss, oscardog86, BroHon and 10 others like this.
  28. Jan 27, 2024 at 4:53 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Might be time for the plastic manifold too.
    metalpete and bmf4069[QUOTED] like this.
  29. Jan 27, 2024 at 4:55 PM
    I've been thinking about it. I haven't done enough research on it yet. God that would make it easier to pull out though.
  30. Jan 27, 2024 at 5:05 PM
    metalpete
    ID
    The good news is that you won't have to pull the manifold to do the injectors.
