How much would a good setup to fit 37s cost?
Discussion in '3rd Gen Tundras (2022+)' started by Goodboy, Jan 26, 2024.
  1. Jan 26, 2024 at 12:48 PM
    Goodboy
    Goodboy [OP] New Member
    2022 Toyota Tundra Sr5 TRD off road 4x4
    Hi Everyone
    New here and to being a truck owner. I have 2022 Toyota Tundra SR5 TRD Off Road 4x4. I would love to put some 37's but would like some suggestions on how to go about, Suspension (lift, shocks etc). I use the truck mostly for daily driving but would like to get into off roading and overlanding. what route should I go as a newbie? I want to make sure the ride is still smooth with bigger tires.
    thanks everyone all suggestions/input is much appreciated!!
  2. Jan 26, 2024 at 12:51 PM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    There's a lot of threads on this already. Especially on 37s.
    Budget is a big factor and important because nothing about 37s is cheap
    Bob likes this.
  3. Jan 26, 2024 at 1:04 PM
    Goodboy
    @b6graham
    true lol, I guess a better question would be, how much would I be spending for a solid set up.
  4. Jan 26, 2024 at 1:39 PM
    b6graham
    b6graham New Member
    Suspension can go from a few hundred for a crap spacer lift to $4k or more for Fox/King etc. Plus labor if you can't do it yourself
    Wheels: pick your poison but $300 x 5 is a safe guess. And a way to store the 37" spare
    Tires: 5 x $450 or whatever
  5. Jan 26, 2024 at 1:50 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    If you were to pay retail and have a shop to the install and everything, north of $10K...likely closer to $12K for a "solid set up".
  6. Jan 26, 2024 at 3:59 PM
    Magnetic1
    Magnetic1 New Member
  7. Jan 26, 2024 at 4:05 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
  8. Jan 26, 2024 at 4:06 PM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    Honestly, spend your money on whatever you want and make your truck look however you want. ‘Merica.
    But to answer your question, 33s.
    What do I have to trim to get 33s-35s to not rub is a newbie arena.
    What’s involved with 37s is not. By all means, research, read, ask, emulate, and become not a newbie, and get 37s all day.
    But the short answer is get some 33s on your stock suspension and drive around for a season while you research. Old trucks were easier to cut and and tub and make clearance. Still doable. If you commit to that route post process pictures and have fun!
    b6graham likes this.
