SDHQ hybrid under hood power solutions kit
Discussion in '3rd Gen Tundras (2022+)' started by EugeneTRD, Jan 26, 2024.
  1. Jan 26, 2024 at 8:31 AM
    EugeneTRD
    EugeneTRD [OP] New Member
    https://sdhqoffroad.com/products/2022-2023-tundra-hybrid-sdhq-built-under-hood-power-solution-kit
    Hey everyone, I am new to the forum and couldn’t find a thread dedicated to this. I was wondering if anyone had installed this kit and what they thought of it. Is it worth the hefty $1k price tag?
    This seems to be the perfect solution for me. Trying to rig up a few accessories via the Garmin PowerSwitch then run to my Anderson Plug that goes to my dc to dc charger on my camper. Really don’t like the idea of trying to route to the battery under the seat.
    Any thoughts are appreciated.
    Thanks
  2. Jan 26, 2024 at 8:39 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    It's a slick ass set up.
  3. Jan 26, 2024 at 7:30 PM
    Swanie80
    Swanie80 New Member
    B
    2023 Tundra 1794 TRD OR
    3" Lift, 35" Tires, Fuel Rims
    How does that kit work exactly? It's not very descriptive on the site.
    Kap1 likes this.
  4. Jan 26, 2024 at 7:56 PM
    EugeneTRD
    In essence, moves the battery terminals back under the hood to sit right above the master cylinder.
  5. Jan 26, 2024 at 8:18 PM
    lavern23
    lavern23 New Member
    Chad
    So does this kit get the battery from under the seat and relocate it so we could have under seat storage?
  6. Jan 26, 2024 at 8:23 PM
    EugeneTRD
    If only!
  7. Sep 24, 2024 at 6:43 PM
    ReCKzX
    ReCKzX New Member
    2023 Tundra TRD Pro Ice Cap
    Just wondering if anyone has updates on this? Has anyone ran a power tray setup with this as well?
  8. Sep 29, 2024 at 9:24 AM
    EugeneTRD
    I did end up putting in the SDHQ Power Solution kit, and I am super grateful I did. It made all my wiring much cleaner and kept me from punching holes into the grommets to get under the battery in the cab. That being said it is a little nerve-racking taking a hole saw to your $60k truck. I replicated Blaze Offroad's example and mounted a ground bus bar to the top of the SDHQ plate and the Garmin Power Switch on the front. You could mount a fuse power tray on the front I'm sure if that works better for you. IMO the Garmin Power Switch is well worth it though because you can control everything with the stock head unit. Let me know if you have any other questions.
    AF555 and Occidentalis like this.
  9. Sep 29, 2024 at 1:23 PM
    ReCKzX
    ReCKzX New Member
    Gonna send you a PM. Thank you!
  10. Mar 12, 2025 at 4:11 PM
    Jflo1794TRD
    Jflo1794TRD New Member
    NorCal
    2023 Tundra 1794 trd off road 4x4
    How hard was it to install this ? I’m thinking of doing the same except I have a switchpro.
  11. Jul 1, 2025 at 7:45 PM
    AF555
    AF555 New Member
    Michael
    2025 Tundra 1794 - Smoked Mesquite
    For @EugeneTRD or anyone else that have done this SDHQ power relocation kit - how are things holding up? I'm looking at adding this to my 25' 1794 Hybrid. Thanks much for any updates!
