DK's 1st Gen Build
Discussion in '1st Gen Builds (2000-2006)' started by khooiii, Jun 25, 2023.
  1. Dec 3, 2023 at 2:56 PM
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Final verdict for 305/70’s… she rubs haha
    not enough to where you can’t wheel it, but there ain’t a single wheel that doesn’t rub when fully stuffed. Local off-road park rates trails on a scale of 1-5. Spent most of the day on 2’s and 3’s. Very surprised, but getting acclimated to this truck was a trip. I’m used to being in the bigger truck and way up on 37’s. Very pleased.
  2. Dec 13, 2023 at 9:36 AM
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Well I finally found enough time to get all the pieces moving for this. Tentatively on the books for early February. Plan is to run this temporarily until I go SUA and go ahead and get the front LT started.
    Originally was going to do the archive garage rear shock relocate, but my new fab guy said he’d rather just build his own.
    Changing out the pintop mount to the standard eyelet, but it’s going to be nice to have some bypasses on the truck again.
    The Black Mamba likes this.
  3. Dec 13, 2023 at 12:08 PM
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Today’s not so fun project.. killing some of this rust
  4. Dec 15, 2023 at 7:47 PM
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Always wanted yellow calipers. Here we are since the wife is out with some friends.
    Weagle and rock climber like this.
  5. Jan 4, 2024 at 4:50 PM
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Leather wheel out of a GX470, but I’m inclined to say sienna. Doesn’t match, but was cheap enough for me to just get it anyways.
    10 minutes and no more torn up rubber wheel.
  6. Jan 4, 2024 at 5:00 PM
    bfunke
    bfunke Tundra Curmudgeon
    You’re OEM airbag fit that leather wheel?
  7. Jan 4, 2024 at 5:24 PM
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Yeah almost all the Toyota wheels are interchangeable for early 2000’s models.
  8. Jan 24, 2024 at 3:52 PM
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    New wheels are here and the lip on these things are insane.
    Raceline monster beadlocks
    17x9.5 -32
  9. Jan 26, 2024 at 5:43 PM
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Beadlocks installed! Didn’t need balancing and steering feels a lot better. That extra 1/2” width on the wheel is really noticeable even with 305’s.
  10. Jan 27, 2024 at 12:02 PM
    vst
    vst New Member
    Scott
    2005 DC 4wd
    Those look sweet doesn’t look like you got much poke with the -32 offset
    khooiii[OP] likes this.
  11. Jan 27, 2024 at 3:12 PM
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    They definitely poke. They have the same poke as the last set of wheels except they're wider, but that's all on the inside barrel.
  12. Feb 11, 2024 at 9:41 PM
    amireles04tundra
    amireles04tundra New Member
    Any other pics of those fogs? Mounting? Cutting? Sturdiness? I would like to do that to my tundra.
  13. Feb 12, 2024 at 6:34 AM
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    They’re sturdy, but you have to gut almost the whole fog pocket to get it to work. They mount just like anyone else who’s put pods in the fog pockets these are just bigger and more expensive. I’d stick to the smaller pods if you’re not willing to cut the bumper up a ton. Don’t have any pics of it unfortunately
  14. Feb 12, 2024 at 8:13 AM
    amireles04tundra
    I like how they fill the pocket up, so it just mounted to the plastic of the bumper?
  15. Feb 12, 2024 at 8:49 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Clean!
    khooiii[QUOTED][OP] likes this.
  16. Feb 12, 2024 at 7:34 PM
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Correct, but you have to cut basically the whole fog pocket to fit it. If you wind up spending the $440 for the pair and put it in the pocket you'll figure out pretty quick where it needs to be cut.
  17. Feb 16, 2024 at 4:37 PM
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Small update:
    -Bypasses rebuilt, new top caps, new shock shafts with lower mounts. Waiting on the fab shop.
    -Ride height adjustment in the front. Cranked in the front and slight squatted, but I don't mind.
    kodyquist21, reywcms, GOJIRA and 3 others like this.
  18. Feb 25, 2024 at 6:17 PM
    GOJIRA
    GOJIRA New Member
    LJ
    Lexus TX470
    I'm a little jealous of this.
  19. Feb 25, 2024 at 6:33 PM
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Well worth the investment if you have multiple lights or accessories. I used 5/8 slots already.
  20. Feb 25, 2024 at 6:34 PM
    #50
    GOJIRA
    GOJIRA New Member
    LJ
    Lexus TX470
    I wonder if it would work with an e-locker. What all do you currently have connected to it?
  21. Feb 25, 2024 at 6:37 PM
    #51
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    It should. Guys use them for ARB lockers all the time. They have different size fuses for different accessories.
    Personal preference, but I’d put a standalone switch for a locker and utilize the switch blank. I really only use these for lighting since I don’t care for a winch and I only need an LSD.
    Weagle likes this.
  22. Feb 25, 2024 at 6:40 PM
    #52
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You have lots of goodies on this rig. I'm here for it. I'd love to actually find non busted trucks at the JYs for crackie parts
  23. Feb 25, 2024 at 6:46 PM
    #53
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    If it fails I typically upgrade. I push trucks really hard and do a ton of camping so it makes sense to spend the money. Also just love building vehicles and off-road trucks have become a passion for me. This one being my 4th Toyota truck I’ve really got my eyes set on a goal so I’ll just keep spending haha.
    you just have to live on marketplace. Stuff goes fast!
    Tundra2[QUOTED], reywcms and GOJIRA like this.
  24. Feb 25, 2024 at 6:53 PM
    #54
    GOJIRA
    GOJIRA New Member
    LJ
    Lexus TX470
    I'm on my 5th Toyota. I only modified 4 of the 5 and I'd only really consider 2 of those to be "builds."
    khooiii[QUOTED][OP] and Tundra2 like this.
  25. Feb 25, 2024 at 7:19 PM
    #55
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    With two kiddos, and two/four guaranteed days off a month, I'd rather spend time with them, than wrench nowadays. Shocker IYKYK.
    Sweet truck though! Crackie will be there one day when I can wrench WITH my kiddos
    khooiii[QUOTED][OP] and GOJIRA like this.
  26. Feb 26, 2024 at 5:11 AM
    #56
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    This one definitely is just getting started. Last truck is documented on here and was pretty built. Lot of phases which I’m not doing with this truck. Just being patient and not compromising on this truck.
    GOJIRA[QUOTED] likes this.
  27. Feb 26, 2024 at 5:12 AM
    #57
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Married, but no kids yet. The truck plans will all come crashing down soon enough haha
    Tundra2[QUOTED] and FishNinja like this.
  28. Mar 3, 2024 at 6:54 AM
    #58
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Should’ve washed the truck since I brought the camera with me lol.
    Filthyphil, G_unit3000 and KNABORES like this.
  29. Mar 20, 2024 at 8:41 PM
    #59
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Just some recent pics. Custom shock relocation on 3/28. I’ve been waiting too damn long for this thing.
    G_unit3000 likes this.
  30. Mar 31, 2024 at 5:51 PM
    #60
    khooiii
    khooiii [OP] 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    OCD4WD Dash mount. Pairs nicely with the sunglass auxbeam mount. Whipped up an ABS plastic bracket for the midland radio. I like hard mounted solutions, but this felt like the best mount for the money at $65 shipped and you’re not drilling holes in the top of your dash.
