Propeller shaft (ujoint) maintenance
Discussion in '2.5 Gen Tundras (2014-2021)' started by blaserdude, Nov 3, 2020.
  1. Nov 3, 2020 at 10:41 AM
    blaserdude
    blaserdude [OP] New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    Greetings,
    I was looking at my next scheduled maintenance (30K) on my 2019 tundra. It mentions lubrication of the propeller shafts. My truck does not have zerks like the older model did. How would you lubricate the U joints? I think they are pulling my leg for $.
    Regards,
    bc
  2. Nov 4, 2020 at 8:44 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    This is something you can do without greasing anything...crawl underneath and check if there is any loose-feeling bearing movements around the carrier bearings...if there is, I'd bring it in for their decision, if not, ask them not to "worry" about them...nonetheless, you should have and be under warranty to address any issues, including the scheduled maintenance...it's speculative at their discretion...
  3. Nov 4, 2020 at 8:54 AM
    thrustmaster
    thrustmaster New Member
    Joel
    dallas
    2016 Tundra Crewmax MGM 2WD
    lazy technical writers at toyota that didn't get all the update and therefore didn't change the manual
    HulkSmurf14 likes this.
  4. Nov 4, 2020 at 9:00 AM
    spn4125
    spn4125 New Member
    Don't worry they probably wouldn't grease it even if you did have zerks. I had them explain to me what the 30k maintenance entailed and was told it's just a oil change and new air filters for $200+. Never again.
    BTBAKER likes this.
  5. Nov 4, 2020 at 11:02 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Yep, those ass clowns wont do it anyway. I agree with you 100 percent.
    Black Wolf likes this.
  6. Nov 10, 2020 at 4:24 PM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    I just crawled under the back of my 2017 DC Limited.... no zerks on the main driveshaft at all the U-joints are sealed at the differential and at the Cardin. Even the Cardin joint appears to not have a zerk, and I had a good look at it.
    update: I did find zerks at both ends of the front axle driveshaft. They are a pain to get to, but it’s doable if you are patient.
  7. Jan 23, 2024 at 5:54 PM
    rpmcgarvey
    rpmcgarvey New Member
    2020 Blue CrewMax Tundra TRD
    My 2020 tundra crewmax 4x4 mentions librication of the propeller shaft. How there are no zerks. Is the entire drive shaft sealed ?
