A750E Swap Level of Difficulty?
Discussion in '1st Gen Tundras (2000-2006)' started by manshack_one, Jan 23, 2024.
  1. Jan 23, 2024 at 9:37 AM
    manshack_one
    manshack_one [OP] New Member
    2005 Tundra SR5 V6 4x2
    I'm not ready to let this truck go to the salvage yard just yet. I'd been chasing down codes on my '05 SR5 with the A750E that has no forward gears. Swapped a solenoid, checked for ground, etc. I think at this point the transmission is just toast and I'm not about to try and rebuild it.
    For those that have swapped this transmission out on their own, how difficult was it? Other than being heavy were there any special tools, etc that you needed? I don't have a lift but I've got ramps and can make room under it. I'm not scared to unbolt anything as long as I know that I'm unbolting the right thing. I have the service manuals but would like to know from someone with experience if this is beyond something you'd do in the driveway.
  2. Jan 23, 2024 at 9:40 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Haven't done it in truck, but did a few times in passenger car, which is way much more involved (subframe has to come off, engine and steering rack suspended, frozen axles taken out, stubborn transfer case unbolted). Was totally doable. Truck is even simpler. I think you need a transmission jack.
    whodatschrome likes this.
  3. Jan 23, 2024 at 11:41 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
