3rd Gen Tundra Diff Breather/Axle Vent
Discussion in '3rd Gen Tundras (2022+)' started by CORam, Jan 22, 2024.
  1. Jan 22, 2024 at 10:05 AM
    CORam
    CORam [OP] New Member
    I read on here about the rear diff on the 3rd gen Tundras being a simple vent on top of the differential, and I was able to locate it on my truck and and will be relocating it to a higher position. My question is about the front differential. Does the front differential breather have a hose relocating it up higher than the top of the diff? Does it even have a breather? I can't seem to find any information about the front diff breather online. I am hoping that someone has investigated this on their pickup. I would go look at mine real quick, but with the skid plates it is hard to get in there to investigate it.
  2. Jan 22, 2024 at 12:11 PM
    TundraTT
    TundraTT Full Send
    17 Pro, 94 70series LC
    No real need to do anything up front. The breather is extended and mounts up a bit higher on the body. IMG_3484.jpg IMG_3485.jpg
  3. Jan 22, 2024 at 1:08 PM
    CORam
    That is great info, thank you! Interesting that they would extend the front breather up but not do the same with the rear.
  4. Jan 22, 2024 at 3:37 PM
    virgilus11
    virgilus11 New Member
    2022 Tundra Capstone
    1/2" front spacer 37" Cooper ATX
    Can you please post some pics after you extend the rear diff breather ? Thank you.
  5. Jan 22, 2024 at 3:50 PM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
  6. Jan 22, 2024 at 4:05 PM
    TundraTT
    TundraTT Full Send
  7. Jan 22, 2024 at 4:08 PM
    virgilus11
    Thank you very much guys
  8. Jan 22, 2024 at 6:07 PM
    CORam
    Yeah I'll see what kind of pics I can get when I do it. I pulled the factory breather off and measured the threads and it appears that it is 1/8-28tpi BSP threads. I initially thought it might be 1/8-27tpi NPT threads but it was not. I can post the components that I used once I complete it.
  9. Feb 25, 2024 at 9:58 AM
    CORam
    I got the diff breather relocated finally. I'll post links to the products that I used. I ordered the hose barb with 1/8 BSP threads off of Amazon because I could not find one locally, due to the BSP threads. The hose barb at the axle is for 1/4" hose and the breather has a 5/16" hose barb, so I got an adapter. I ran 1/4" fuel hose from the axle to the adapter right near the breather, but then I added the adapter to transition from 1/4" to 5/16" right before the breather. If you can find an 1/8-28tpi BSP fitting with a 5/16" hose barb that would be ideal, and could avoid the need for the adapter. But this should work fine.
    1. 1/8-28tpi BSP hose barb: https://www.amazon.com/dp/B07CX58JBP?ref=ppx_yo2ov_dt_b_product_details&th=1
    2. Breather: https://www.amazon.com/dp/B06XHBY38X?ref=ppx_yo2ov_dt_b_product_details&th=1
    3. 1/4" to 5/16" hose barb adapter: https://www.amazon.com/dp/B07PMQDLZ6?ref=ppx_yo2ov_dt_b_product_details
    4. 10 ft of 1/4" low pressure fuel hose. I used just over 8 ft of it.
    5. Hose clamps (I had a random assortment laying around).
    *EDIT - 6. Short length of 5/16" fuel hose.
    Now for the pictures.
    The full circuit laid out and loosely attached:
    The original breather:
    Now with the new hose barb:
    And with the hose attached:
    The finished breather hose with slack in the line and secured to the electrical cable:
    Routing it over the frame crossmember toward the rear of the truck:
    And the finished breather inside the taillight opening. The picture was taken through the opening of the taillight with the light removed. I should have gotten one while standing back a bit farther.
  10. Mar 4, 2024 at 3:12 PM
    gearnuts
    gearnuts New Member
    Joel
    Greer, SC, United States
    thanks for the info @CORam
    only place i can find 5/16 barb BSP fitting is MacMaster Carr
    https://www.mcmaster.com/catalog/130/342/1075T307
    Brass Barbed Hose Fitting for Air and Water, Straight Adapter for 5/16" Hose ID x 1/8 BSPT Male
    1075T307
    $11.77 + $8.28 shipping
    $20.76
    Would be interested if anyone can find the Toyota Union, screw in barb fitting part number like we've used on previous generations 90404-51319
    Edit: just get Toyota part noted by @TundraTT (sorry missed your post above) much cheaper. Anyone with previous Yota truck/suv should be familiar with this part it’s been the same for 60 years
    BDATundra likes this.
  11. Mar 4, 2024 at 3:55 PM
    TundraTT
    TundraTT Full Send
    Read above… same union fits
    BDATundra and gearnuts[QUOTED] like this.
  12. Mar 4, 2024 at 4:00 PM
    CORam
    Interesting about the McMaster part. I originally thought that the breather was 1/4" hose and when I looked on McMaster I saw that the 1/8" BSPT x 1/4" hose barb was $20 + shipping for a pack of 10 of them, so I looked elsewhere. Now that you point that out, I would probably go with the McMaster part that you posted and then could skip the 1/4" to 5/16" hose barb adapter. That would be cleaner. Thanks for posting that.
  13. Mar 4, 2024 at 4:04 PM
    CORam
    TundraTT, that is good if you confirm that that Toyota union fits. I had seen that part on Amazon early on but couldn't confirm the threads on it, so again I looked somewhere else to ensure that I got the right BSP threads. And I don't think I saw the link in your post before - that would have saved me some time.
  14. Apr 16, 2024 at 5:20 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Thanks for the write up. Did this today with the Amazon toyota union, reused the original breather vent.
    CORam[OP] likes this.
  15. Apr 18, 2024 at 2:02 PM
    CORam
    An interesting observation from when I relocated the breather. As I unthreaded the OEM breather from the axle there was a very distinct "pffft" sound as I got toward the final threads. Gases obviously passed by the breather as the threads opened up. I couldn't tell if the gases flowed into or out of the axle, but it is quite concerning and has me believing that the OEM breather is defective. It happened twice - once when I removed the breather to measure the threads, then I put the breather back on. Then weeks later I pulled it again to actually relocate it and it did it again. Both times the truck had been sitting in my shop for days prior without having been driven.
    This came to mind as I saw that several of you on this thread re-used the OEM breather and I hope you don't have the same issues with yours. I have not opened up the new breather to check for a release of gas, but I plan to check it for the same issue at some point.
    Did anyone else experience this release of gas upon removal of their OEM breather?
    22whatwedo likes this.
  16. Apr 18, 2024 at 2:41 PM
    jctmundra
    Northern VT
    No noises when I pulled mine. Checked the OEM before putting at hose end - all good.
  17. Sep 28, 2024 at 12:26 PM
    nimblesartorius
    nimblesartorius Scruffy looking nerf herder
    2022 Limited OR in blueprint
    so I had ordered this same Toyota union off Amazon, but it seems very hard to screw in. I’m worried the thread pitch isn’t correct. Don’t want to strip anything out.
    Was yours hard to screw in?
    considering getting the barbed union brass fitting shown up above by CORam.
    Tundrastruck91 likes this.
  18. Sep 28, 2024 at 12:31 PM
    virgilus11
    Take the oem breather and find a nut that matches the rivet. Test both of them on the same nut.
  19. Sep 28, 2024 at 12:43 PM
    nimblesartorius
    great info and very clearly laid out in the pictures thanks!
    as you can see I mentioned above I had ordered and tried to use that Toyota Union 90404-51319 and I could only advance it a couple of turns before it became much more difficult that I felt comfortable with. Don’t want to strip out the threads.
    This made me concerned that the thread pitch may not be correct, and I don’t know if a good way of measuring thread pitch other than, “if it doesn’t go, don’t force it because it’s probably wrong”. I’m glad to see you found that brass 1/8” hose barb had the right pitch at 28 tpi. Good thing is Amazon can get one of those to me cheap by tomorrow so I will try that instead.
    I did have one other question for you though. Your picture of the assembled breather tube shows two separate pieces of tubing connected together. The are I circled in red below. Is there any reason in particular you did it that way? Was it just that your first piece of hose wasn’t quite long enough or is there something I’m missing?
    Thanks again for sharing the tips on the breather relocation.
    Yaboy likes this.
  20. Sep 29, 2024 at 7:13 PM
    CORam
    You bet! I pulled the OEM breather out of the axle and measured the diameter of the threads and used thread gauges to measure the thread pitch. When I first pulled the breather I assumed that it was 1/8" NPT threads, which are 27 tpi, but the thread gauge for 27 tpi clearly was not correct, but 28 tpi was correct. That is how I determined that it was BSP threads and not NPT. They are so similar in diameter and in thread pitch that it is difficult to tell the difference without thread gauges. Your experience leads me to believe that the fitting mentioned above from Amazon may actually be an NPT fitting and not BSP, which is what I feared.
    I considered buying that union off of Amazon, but I could not find the thread pitch specs for it so I decided to go a different route in fear that it would not be the correct pitch. I wanted to buy parts that were exactly the correct parts, per the stated specs. The BSP fitting threaded in nicely.
    As for the 1/4 to 5/16 transition - the hose barb at the axle is for 1/4" hose and the breather has a 5/16" hose barb, so I got an adapter. I ran 1/4" fuel hose from the axle to the adapter right near the breather, but then I added the adapter to transition from 1/4" to 5/16" right before the breather. @gearnuts found an 1/8-28 tpi BSP to 5/16" hose fitting on McMaster, part number 1075T307. I would go this route if I did it over again. The problem was that I thought that the breather was for 1/4" hose when I bought it, so I planned everything for 1/4" hose, but then the breather turned out to be designed to accept 5/16" hose, so rather than return the fittings and hose, I just picked up the adapter to 5/16" hose and ran a short length of 5/16" hose to the breather at the end. Plan everything for 5/16" hose from the start and you are golden. Or find a breather that has a 1/4" barb. Or do what I did and it will work but won't be as clean.
    If I did it over again, this would be my revised parts list (much simpler!):
    1. 1/8-28tpi BSP hose barb (for 5/16" hose):
    https://www.mcmaster.com/1075T307/
    2. Breather:
    $6 Dorman 924-284 Front Differential Vent Breather Compatible with Select Lexus / Toyota Models
    3. 10 ft of 5/16" low pressure fuel hose.
    4. Hose clamps
  21. Sep 29, 2024 at 11:03 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Old post but I definitely heard a pressure release when I cracked open the fill plug on my 22. Truck had been sitting for hours too, diff was cool to the touch. Replaced the gear oil so I cracked open the fill plug first, noticed the pressure and then drained the oil. Never dawned on my that the breather might be stuck.
  22. Sep 30, 2024 at 7:17 AM
    CORam
    Interesting that you had a similar experience. I haven't heard of issues with axle seals or anything on these Tundras, so I am not sure what to make of it. But I don't like the idea that the axle is sealed and holding pressure. I still need to check my new relocated breather to see if it is working.
    Tundrastruck91 and eddiefromcali like this.
  23. Sep 30, 2024 at 7:48 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    I did my rear dif oil on Saturday, and same pressure release. I will need to check that breather. Pretty weird.
  24. Sep 30, 2024 at 8:29 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
  25. Oct 1, 2024 at 10:11 AM
    eddiefromcali
    Eddie
    100% Stock
    was it pressure or vacuum release? I just remember the hissing but now that I think about it, I'm not sure if I felt air coming out.
  26. Oct 1, 2024 at 7:18 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    Officially I would think the thread is either M10-1.0 or 1/8" BSP but its close enough for gov't work :)
    NPT = National Pipe thread Tapered, and it is 0.407" (10.2mm) OD with 27 TPI (threads per inch)
    M10-1.0 is 10mm OD and 1.0 mm thread pitch (or 25.4 TPI)
    BSP = British Standard Pipe thread, and it is 0.407" (10.2mm) OD with 28 TPI (threads per inch)
    So you can see the three are VERY close and for the few threads in the housing and the fact that pipe threads are tapered (meaning the male thread starts out small and gets larger in diameter as it threads in, female thread is the opposite) an 1/8NPT thread fits fine for this low pressure, low stress application, YMMV.
    For an even better fit, run a 1/8" pipe thread tap down into the housing, apply grease to the tap to hold the few metal shavings it'll cut.
    Toyota 90930-03136: 5/16” Barb
    Toyota 90930-03031: M10 x 1.00 Thread Pitch
    Toyota 90404-51319: M10 x 1.00 Thread Pitch, 3/8” Barb
    Toyota 90404-51026: M10 x 1.00 Thread Pitch, 1/4” Barb
    Nissan 38323-C6010: M10 x 1.00 Thread Pitch, 3/16” Barb
    At first I started with a Nissan breather, I didn't discover the Toyota breather with the barb till later. I personally use the Toyota 90404-51319 with the 3/8 barb. I drill out the hole as large as possible to increase flow in the event gear oil does enter the line.
    This mod is good but can also cause problems if not done properly. The purpose of the vent is to allow excess pressure to escape the housing, if you have a plugged breather the pressure will force its way out of the axle seals causing a leak at the diff end.
    Gear oil is thick as hell, in the winter it's as thick as molasses. Any amount of gear oil in the line will essentially clog the line.
    The one thing I would not do is reuse/use the stock fitting after extending the line. The fitting has a spring and a rubber disc under the cap. The spring keeps pressure on the rubber disc forcing it down to seal off the fitting from water/contaminates from entering the housing. The springs rust and over time get stuck, some open, some closed. As an avid off roader when I extend breather lines on my trail trucks I finish it off with a small engine gas filter like this.
    On my competition buggy I've gotten rid of extending the line and presently use something like this. After rolling over and having the truck sit on it's lid I've clogged up those extended lines with gear oil. The bellow type breather allows the gear oil to only have to travel through the fitting, not a 3' line.
  27. Oct 2, 2024 at 8:39 AM
    22whatwedo
    The Open Road
    There was hissing. Hard to tell if air was rushing out. It was odd though, very distinct. I had the spare still in there when I took the fill and drain out. So access was tougher. I ended up removing the spare to fill.
  28. Oct 2, 2024 at 8:43 AM
    eddiefromcali
    Eddie
    100% Stock
    yeah, space is tight with the spare up there. I used amsoil bags, so I was able to squeeze them like a toothpaste tube. :rofl:
    22whatwedo[QUOTED] likes this.
