Brake Hold System
Discussion in '3rd Gen Tundras (2022+)' started by Execkid, Jan 22, 2024.
  1. Jan 22, 2024 at 2:31 PM
    Execkid
    Execkid [OP] New Member
    My 2023 Tundra seems to be activating the brake hold system automatically when I drive in 4H. When starting out in reverse or drive it feels like the brake is on until I push the accelerator pretty hard, then it shudders a little, smooths out and drives fine until I stop again. No issues in 2H and I have turned the brake hold system off. Is this normal?
    doublethebass likes this.
  2. Jan 22, 2024 at 2:41 PM
    Breathing Borla
    Northern Illinois
    are you turning after you switch to 4 hi? what conditions, snow and ice, dry pavement?
    raylo and DFS like this.
  3. Jan 22, 2024 at 2:44 PM
    Execkid
    Wet pavement, cold (<45 degrees) and yes now that I think of it, it does happen when I am turing - not when going straight.
  4. Jan 22, 2024 at 2:52 PM
    Breathing Borla
    Northern Illinois
    ok, your not in slippery enough conditions for a part-time 4wd system. Whats happening is your drive line is binding and by pushing the gas harder, your powertrain is overpowering the driveline.
    STOP doing this, you can break stuff.
    part-time 4wd systems need a good amount of slippage to work right, just use 2wd in wet conditions, 4wd is not needed.
    think snow, mud, or ice for 4wd
    Mattedfred, 4genRunner and in_the_mud like this.
  5. Jan 22, 2024 at 2:53 PM
    Execkid
    Thanks!
    Breathing Borla likes this.
  6. Jan 22, 2024 at 2:56 PM
    doublethebass
    doublethebass New Member
    Minneapolis
    2017 Tacoma TRD Pro 6MT
    Yep that’s driveline bind
    Mattedfred likes this.
  7. Jan 22, 2024 at 3:09 PM
    Execkid
    Drivers manual; states to drive in 4 wheel drive for 10 miles a month to keep front system lubricated. So I assume that is only while going straight and not stopping?
  8. Jan 22, 2024 at 3:15 PM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    Yes. Or drive on a snow covered or dirt road where turning is OK. In my experience you don't need 10 miles. I just pop it on for a 1/4 or 1/2 mile stretch of straight road every month or so. That kept my Tacoma 4wd working fine for 15 years. This winter the problem solves itself with all the snow we have had.
  9. Jan 22, 2024 at 3:21 PM
    Breathing Borla
    Northern Illinois
    yes, I usually do that on a county highway , I don't do a full 10 miles, just pop it in and out a few times going straight.
    if you feel it bind at all, BACK OFF, and straighten out the wheel to relieve the pressure on the driveline
    raylo likes this.
  10. Jan 22, 2024 at 5:38 PM
    Execkid
    Thanks
