Interchange 8in for 14in display?
Discussion in '3rd Gen Tundras (2022+)' started by SoCalJose, Jan 1, 2022.
  1. Jun 21, 2023 at 9:04 PM
    #151
    Calc30
    Calc30 New Member
    Jeff
    Arizona
    2022 Tundra SR5
    2” coilovers (RC M1) 34” Falcon Wildpeak (295/70r18) Custom 18x9 wheels Fender color match Bumpers and mustache color match E1 running boards (Go Rhino) Retrax PowertraxOne
    I’m not keen on the idea of purchasing a unit and then owning a paperweight, or losing a chunk of money if the return is even accepted.
    I’ve heard from some aftermarket sellers stating the backup camera will work;however, you need to use their camera. As far as Sirius/XM option it’s not available, but you can us the app on your phone, or download the app directly on the unit itself.
  2. Jul 18, 2023 at 2:23 PM
    #152
    Arkytundra
    Arkytundra New Member
    2022 Tundra
    Has anyone tried this? I can’t find a 361 that isn’t damaged.
  3. Jul 31, 2023 at 4:12 AM
    #153
    Roziere3
    Roziere3 New Member
    So on another thread the OP did use a JBL head unit and seems to have connectivity…everyone says the non JBL are the ones to use but are difficult to find now. Can anyone confirm if they have had luck with the JBL head units as well?
  4. Jul 31, 2023 at 5:33 AM
    #154
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    Anyone that swapped to the 14in do you guys get any navigation fault codes or brake codes?
  5. Aug 2, 2023 at 5:01 PM
    #155
    Mattrulez
    Mattrulez New Member
    Finally got my hands on one. Has anyone else had to have Toyota unlock the radio? Mine is stuck in guest mode.
  6. Aug 3, 2023 at 7:38 AM
    #156
    Newtonfb
    Newtonfb New Member
    I've had mine installed for months now, I also have the guest issue. Not sure if it toyota locked them out or not. It doesn't concern me. I only use Android Auto and not the navigation. I also dont have power mirrors or power seats to adjust. I love the swap.
  7. Aug 3, 2023 at 8:01 AM
    #157
    Mattrulez
    I assume you don’t use the radio?
  8. Aug 3, 2023 at 8:03 AM
    #158
    Newtonfb
    Newtonfb New Member
    The actual radio tuner? yes it works. I use it for local football games at times, thats about it. Everything works as it should, its just logged into guest mode and I cant subscribe to navigation, which I wouldn't anyways since I use AA 99% of the time
  9. Aug 3, 2023 at 8:08 AM
    #159
    Mattrulez
    I can’t subscribe to Sirius Xm. It will not pull up the radio code.
  10. Aug 3, 2023 at 8:13 AM
    #160
    Newtonfb
    Newtonfb New Member
    Gotcha. I dont use Sirius either. Theres a Sirius App for AA or Carplay, whichever you have as an option. Have you tried a full factory reset?
  11. Aug 3, 2023 at 9:47 AM
    #161
    brutalitybob
    brutalitybob New Member
    Mine too is stuck in guest mode. Called Toyota and they dont know how to unlock it and told me to take it back to the dealer. Anyone find a solution outside of wasting time at the dealership? Have tried every reset possible.
  12. Aug 3, 2023 at 9:57 AM
    #162
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Not that I can help, but I'm curious about both of your situations:
    • Did you both have a non-JBL 8" head unit that you replaced with a JBL 14" head unit?
    • Or, are having this issue after you installed a non-JBL 14" head unit?
    On a side note: Thanks for confirming my suspicions on the SiriusXM availability, @Mattrulez. That sucks. I know a lot of folks poo poo on sat radio, saying it's easily replaced with Apple Music/Spotify/Amazon Music. However, I rely on quite a bit. In the vast expanses of Nevada, it's very easy to be without cell coverage and I mostly use SiriusXM for that reason. I wonder if people with the aftermarket head units from AliExpress can subscribe to SiriusXM? I assume you could, but none of the people who have made the aftermarket swap use it and can't weigh in on it.
  13. Aug 3, 2023 at 10:02 AM
    #163
    brutalitybob
    My situation i was told was rare but I had the non-JBL 8" head unit and had the truck for less than a week and the radio had an internal short-smoke came out the dash and the dealership replaced the same a new 8" head unit. I told them to replace it with the 14" as I do not trust the 8" head unit not starting a fire/electrical short again...
    When i recieved it back I hadnt noticed it was stuck in guest mode until a few days later. Hate to take it back in to the dealership and waste my time but its looking like ill have to do that. Andriod Auto works alright but do get connectivity issues with it. Hoping an update will fix my problems with it.
  14. Aug 3, 2023 at 10:11 AM
    #164
    Newtonfb
    Newtonfb New Member
    I got mine off ebay but if you got yours straight from Toyota its not a lock, its something else. Like I said, I personally dont care but hopefully it gets fixed in an update. I honestly thought there would be more updates for the headunits.
    You can see the serial numbers and radio id in the About tab, would that help for Sirius?
  15. Nov 26, 2023 at 8:05 PM
    #165
    Ethansamlol
    Ethansamlol New Member
    Ethan
    2024 White Tundra
    Hi T315, I did the same thing as yours, but I couldn't find the wire harness to plug into the volume assy, is it hidden somewhere? Have you figured out how to sign in or it's stuck in the guest mode?
  16. Nov 27, 2023 at 9:12 AM
    #166
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Have the part numbers been updated? See the non-JBL screens now as 86100-0C401
  17. Jan 13, 2024 at 8:53 PM
    #167
    Kam888
    Kam888 New Member
    Edy
    Sr5 TrD
    so,,can we go to dealer to synchronize?
  18. Jan 14, 2024 at 7:05 AM
    #168
    Kam888
    Kam888 New Member
    Edy
    Sr5 TrD
    are u go to dealer for synchronized the unit to the vins for not get black listed?
  19. Jan 20, 2024 at 9:46 AM
    #169
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Any difference in the 360 and 361 units? Some of this guys eBay listings specify different years but I don’t know which one for a 2024 (or if it even matters)
  20. Jan 20, 2024 at 11:20 AM
    #170
    terraj66
    terraj66 New Member
    Las vegas
    Just ordered the 401 for non jbl fingers crossed
  21. Jan 20, 2024 at 11:21 AM
    #171
    Newtonfb
    Newtonfb New Member
    Agreed. I did the swap back in the spring and have had zero issues. The only thing is its stuck on guest. Doesn't matter, everything else works and I use Android Auto 99% of the time anyway
  22. Jan 20, 2024 at 1:21 PM
    #172
    Kam888
    Kam888 New Member
    Edy
    Sr5 TrD
    Are yours can update the software?
  23. Jan 20, 2024 at 3:49 PM
    #173
    KroppDuster
    Bilstein 5100s
    So your remote start still works after the swap?
    As for the blacklisting issue, I think @ryanwgregg can explain better than I what that means.
  24. Jan 20, 2024 at 4:52 PM
    #174
    Kam888
    Kam888 New Member
    Edy
    Sr5 TrD
    If u not sync the vin,,will not work coz u cannot connected to your account,,but remote key fob still work fine
  25. Jan 20, 2024 at 4:54 PM
    #175
    Kam888
    Kam888 New Member
    Edy
    Sr5 TrD
    I just worries about the updates software,,are still can updates
  26. Jan 20, 2024 at 4:57 PM
    #176
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Man this vid really makes me appreciate the Pro's blacked out vents! Which would be a better option to order instead of time sawing the silvers down.
  27. Jan 20, 2024 at 5:25 PM
    #177
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    Works been crazy so finally got around to posting. Bought a unit off of AliExpress last summer and a 360 camera system to go along with it. I wouldn’t recommend it to anyone unless you feel pretty good about wiring, installing cameras, and troubleshooting. Wireless Apple CarPlay works great, the side view cameras come on automatically when I put on my turn signal, and the reverse camera (not factory) works when I put the truck in reverse.
    It also has all the benefits of being an android head unit (Netflix, YouTube, etc.)
    Black widow TRD and Kap1 like this.
  28. Jan 20, 2024 at 5:28 PM
    #178
    Roziere3
    Roziere3 New Member
    I just did the swap with the 361 head unit….takes minutes. Yes I’m stuck in guest mode as well but don’t really care. Actually one upside of not registering is my XM radio still works and I’m well past my free 3 month trial….im thinking they may not be able to track my head unit :)
    The only feature I can’t figure out is my alignment grid for the reverse camera isn’t showing…have to keep playing to see if I get get it on. The old 8” unit had the lines and a zoom feature.
  29. Jan 28, 2024 at 12:22 PM
    #179
    Mark1234
    Mark1234 New Member
    How did you install the extra cameras? Sounds like a great upgrade.
  30. Jan 28, 2024 at 8:34 PM
    #180
    terraj66
    terraj66 New Member
    Las vegas
    Confirmed working. Now onto the volume knob add on. Any vids up for it?
    Woocawachie likes this.
