  1. Jan 18, 2024 at 5:30 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    I have the tools to press them out and what not, but thats a good price for a pre loaded unit. My phoke won't screen grab the web link in the pic fir some reason. Can you send it to me or post it please?
  2. Jan 18, 2024 at 5:32 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  3. Jan 18, 2024 at 5:32 PM
    Ha!
    And yeah, that UBJ on his truck looks all fuckered up. I hate pressing out UBJs with a passion on these trucks. Hopefully it's a lot easier on a 2WD than it was on mine. I'm so glad I've got SPC uppers, UBJ changes will be a snap from here on out. Maybe snap is the wrong word to use here ...
  4. Jan 18, 2024 at 5:33 PM
  5. Jan 18, 2024 at 5:34 PM
    The Black Mamba
    DFW
    Imma keep it stock
    Problem solved
    oscardog86, BroHon, Krewcial and 3 others like this.
  6. Jan 18, 2024 at 5:35 PM
    The Black Mamba
    DFW
    Imma keep it stock
    Teach a man to fish….
  7. Jan 18, 2024 at 5:44 PM
    SQUEAK SQUEAK SQUEAK! ;) :rofl:
  8. Jan 18, 2024 at 5:46 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Kachow. These might be the black bolt, though...
    batman900 and VR6T like this.
  9. Jan 18, 2024 at 5:47 PM
    VR6T
    Brother you and me fucking both. Theyre a twat and a half to press out. Also how much for them u
    SPC UCA's?
  10. Jan 18, 2024 at 5:48 PM
    metalpete
    ID
    I have the camburg uniballs and they don't squeak!
  11. Jan 18, 2024 at 5:50 PM
    The Black Mamba
    DFW
    Imma keep it stock
    Lightning McPete :bananadead:
    metalpete[QUOTED] and VR6T like this.
  12. Jan 18, 2024 at 5:51 PM
    The Black Mamba
    DFW
    Imma keep it stock
    It’s not the unis that squeak, it’s unlubricated bushings
  13. Jan 18, 2024 at 5:51 PM
    VR6T
    Mine do :rofl:
  14. Jan 18, 2024 at 5:54 PM
    metalpete
    ID
    And @The Black Mamba it's definitely the bushings that would squeak. I can't remember where else, but I there's another section that you aren't supposed to grease for that same reason.
  15. Jan 18, 2024 at 6:13 PM
    metalpete
    ID
    Can confirm that my last image was, in fact, the black lbj bolts.
    This image is the part number for the silver bolts w/ the flange...even though the bag contains black bolts. I have a lot of bolts.
  16. Jan 18, 2024 at 6:33 PM
    I went with the SPC arms that come in the Eibach box. I paid around $450/pr, and I think around $45-50 to ship IIRC. That’s up closer to $575-600 now, and SPC in the SPC box are up around $1,000 which is insane to me. Mevotech also sells the SPC uppers but I left and right are sold separately and I forget the part number, and they never seem to have both left and right in stock. I’d buy the Eibach branded ones.
    oscardog86 likes this.
  17. Jan 18, 2024 at 6:33 PM
    albru2
    albru2 Keep it simple stupid
    2002 Tundra Limited 4.7l 4WD AC
    I think I found it :
    they're listed here as 25-40 mm. I have a Parker Hose Shop locally I'm going to call and see if they stock anything like this.
  18. Jan 18, 2024 at 6:38 PM
    Those may be the McMaster Carr part, not sure who makes it. NORMA also has their own smooth band worm drive clamp in that size under the W4 series. The hose shop may be able to look it up.
  19. Jan 18, 2024 at 6:40 PM
  20. Jan 18, 2024 at 6:43 PM
  21. Jan 18, 2024 at 6:51 PM
    albru2
    speaking of abnormal erections - there's something coming out of the side of my LBJ and I can't figure out what it's for
  22. Jan 18, 2024 at 6:56 PM
    I think that’s normal. I can’t recall the purpose unless I go look underneath and it’s dark and cold outside now.
    albru2[QUOTED] likes this.
  23. Jan 18, 2024 at 6:58 PM
    I think that’s what limits the steering rack
    Voss, KNABORES, TX-TRD1stGEN and 6 others like this.
  24. Jan 18, 2024 at 6:58 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Steering stops
    bmf4069, Voss, oscardog86 and 6 others like this.
  25. Jan 18, 2024 at 7:02 PM
    The Black Mamba
    DFW
    Imma keep it stock
    It’s normal
  26. Jan 18, 2024 at 7:11 PM
    albru2
    ah, makes sense, thanks! But can you tell me how these f'ng strings on paper bags work? And don't tell me you just pull one end because that has only worked twice for me, evertaters.jpg
  27. Jan 18, 2024 at 7:13 PM
    bfunke
    bfunke Tundra Curmudgeon
    Standard stitching used for stuff like kitty litter bags.
    des2mtn likes this.
  28. Jan 18, 2024 at 7:14 PM
    des2mtn
    SW
    Tonto cover
    Bougee whirled peas marketing. Cut the whole bag open below the string then use a chip clip to close the bag.
    bmf4069, KNABORES, oscardog86 and 3 others like this.
  29. Jan 18, 2024 at 7:26 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Never opened a bag of feed?
  30. Jan 18, 2024 at 7:31 PM
    albru2
    I usually try the strings for a little bit then give up and cut it open to be honest. But when it works...
